  Engine size vs. power (Page 6)
Engine size vs. power by 85fieroguy
Started on: 09-20-2015 12:58 PM
Replies: 206 (2266 views)
Last post by: dobey on 10-02-2015 10:03 PM
engine man
Report this Post09-29-2015 10:19 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have not played with the 3.4 iron head engine if that is what you are talking about i think the ports of the iron heads are mor the problem from what i have read and not so much the valve size if your going to go with a 60 degree engine go with 3500 or the 3900 way better heads for power
Silvertown
Report this Post09-29-2015 10:36 PM Click Here to See the Profile for SilvertownSend a Private Message to SilvertownEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will they bolt up to the 3.4? I still want to go roller. I want to use the fiero intake.
engine man
Report this Post09-30-2015 08:16 AM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
the 3500 and 3900 both have roller cams as far as i know or the 3400 but not the 3.4 Camaro engine
dobey
Total ratings: 371
Report this Post09-30-2015 10:29 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. The 3x00 are roller cam blocks. The Camaro 3.4 is the same as the Fiero 2.8. Has the same cam and heads I think.
rogergarrison
Total ratings: 551
Report this Post10-02-2015 06:39 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seems like a good place to ask. A friend cracked a head on his S10 with 4.3. He cant find one locally, will a 3.4 head fit ?
engine man
Report this Post10-02-2015 09:29 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
No
dobey
Total ratings: 371
Report this Post10-02-2015 10:03 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
No. 4.3 is 90 degree small block based engine. 60 degree heads won't fit on it. 3800 is a different design, so they won't work either.
