  Crankcase Vent
Crankcase Vent by 85fieroguy
Started on: 09-27-2015 02:52 PM
Replies: 1 (171 views)
Last post by: dobey on 09-27-2015 05:20 PM
85fieroguy
Report this Post09-27-2015 02:52 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaning up the 85GT V-6 engine. Can I replace the oil filler cap with a " Crankcase Breather vent/filter , 9mm. WHAT DOES THIS MEAN ???...." it removes the OEM PCV system and relieves pressure. Ebay item from Speed Daddy 4006909975554. Need expert advice from you guys. Thank you.
dobey
Total ratings: 371
Report this Post09-27-2015 05:20 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
No. The oil fill cap and PCV valve are different things. You can replace the fresh air intake side of the PCV system with a breather, instead of the valve and tube that connects to the air intake tube (or to the air filter housing, if your car hasn't had the recall work done on it). That part of the PCV system is on the front manifold, not the rear where the oil fill cap is located.
