  Headlight motor wont stop
Headlight motor wont stop by painandgain99
Started on: 10-03-2015 05:23 PM
Replies: 22 (763 views)
Last post by: theogre on 10-07-2015 11:52 PM
painandgain99
Report this Post10-03-2015 05:23 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
When i close or open my 87' GT headlights the drivers side motor keeps spinning for 5-10 seconds then stops. Can anyone help me out with this?
Also, the dogbone looks kinda crooked, is it alright?
And i wrapped the trim in carbon recently, thought you all might like to see as someone suggested for my console cap peeling back, i clamped it and superglued. Going to clamp a few more spots one i re wrap the trim
87' GT 5 speed 😤 15 years old
[This message has been edited by painandgain99 (edited 10-03-2015).]
IMSA GT
Total ratings: 253
Report this Post10-03-2015 05:48 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You'll need a rebuild from here:
http://rodneydickman.com/ca...h=32&products_id=231
And if you want to replace the 5 speed decal on your shift plate:
http://rodneydickman.com/ca...h=37&products_id=143
painandgain99
Report this Post10-03-2015 05:52 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you very much, ive been looking for thr decal. Im going to re wrap everything first, i did a cruddy job. And is this the only problem with the headlights you think thatd make them do that?
Total ratings: 154
Report this Post10-03-2015 05:58 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You may have some deteriorating engine or transmission mounts causing the dogbone to be a little off.
Good job on the wrap. I used some on my truck after a garage person touched a plastic trim piece surrounding my keypad entry. He must have had brake fluid on his hands because it left his hand print burned into it. Wrapped the plexi trim piece and it looks like it's factory.
painandgain99
Report this Post10-03-2015 06:00 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
You may have some deteriorating engine or transmission mounts causing the dogbone to be a little off. .
How serious is this? Is it something to worry about
jscott1
Total ratings: 415
Report this Post10-03-2015 06:06 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 87-88 Headlights are very reliable. The little nylon bushings are designed to be sacrificial in case the headlights get jammed, but over time they turn to dust. The good news is they are easily replaced and your headlights are good as new. The motor stops after a few seconds and will not run down your battery. The earlier generation has far worse problems that are not as easily repaired. They will run forever until your battery runs down when the limit sensor fails.
Total ratings: 154
Report this Post10-03-2015 09:15 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bad engine or transmission mounts aren't real real serious. The dogbone will keep the motor from falling out on the ground. Seriously, though, you'll start to notice the car chug a little when changing gear or when accelerating and decelerating. The dogbone takes up some of that torque, but the motor and trans mounts help. They aren't all that hard to change if you have a moderate mechanical ability and a floor jack and stands. Look at the rubber in the mounts and if they're oil soaked, they probably should be replaced.
painandgain99
Report this Post10-04-2015 12:37 AM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Based on mine, does it look bad? Do i have a few months before having to fix it you think
Total ratings: 154
Report this Post10-04-2015 07:32 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The engine doesn't always sit perfectly straight. Depends upon how the mounts were positioned. I couldn't tell you if yours need replacing without actually looking at them.
The engine falling out thing was just a joke.
wolf63
Report this Post10-04-2015 10:44 AM Click Here to See the Profile for wolf63Send a Private Message to wolf63Edit/Delete MessageReply w/QuoteDirect Link to This Post
point for reference? this was the motor mount from my 84 duke a couple of years ago. so nasty i had to take a picture :-)
Total ratings: 329
Report this Post10-04-2015 11:22 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
For those looking for headlight motor repair and perhaps longer lasting reliability Cardone now offers new headlight motors for around $85. More expensive than the easy bushing fix but the new motors operate much smoother than repaired motors and may last longer.
Report this Post10-04-2015 11:57 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should be 5-6 sec...
Most likely, Motor "Pins" are bad and motor runs until module's timer turns off.
See my Cave, Gen 2 HL Motor
what the pins do... https://www.fiero.nl/forum/F...HTML/128600.html#p15
You can try to fix them or get Cardone units.
https://www.fiero.nl/forum/F...HTML/136464.html#p13
call or google them because you can find new units for ~$90 each
[This message has been edited by theogre (edited 10-04-2015).]
painandgain99
Report this Post10-05-2015 12:03 AM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the help guys. Now that one headlight wont go up unless i help it, it goes up fine when the hood is up. Just doesnt have the strength to open the cover on the hood alone. Should i not use it until i fix this or will it be ok to open manually?
Total ratings: 154
Report this Post10-05-2015 12:11 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Open the hood and let it go up or help it if needed then close the hood. As Ogre indicted, the relay module will disengage power after a prescribed time, so the motor won't continue to run.
jscott1
Total ratings: 415
Report this Post10-05-2015 02:04 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
you can use it this way indefinitely, but it will continue to get worse until it won't move at all on it's own.
painandgain99
Report this Post10-05-2015 04:15 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Also, funny enough i just realized i had power locks. The drivers side locks and unlocks after 2 or 3 pushes, but the passenger tries to but seems like it cant move enough. Any help?
Total ratings: 154
Report this Post10-05-2015 05:28 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The mechanism inside the doors could use some cleaning and lubrication, but in the meantime, just keep repeatedly pushing the button until you get the result you want.
sardonyx247
Total ratings: 219
Report this Post10-06-2015 11:13 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
no need to order the bushings, they sell them at all auto parts stores, in the "help" section as "ford window regulator bushings"
Dorman 74410
painandgain99
Report this Post10-06-2015 12:05 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dorman 74410
And these fit in the headlight motor fine?
Rodney
Total ratings: 267
Report this Post10-06-2015 12:49 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Ford window bushings years ago were worth it. I'm pretty sure they were turned Delrin or Nylon or similar. No the same thing these days. They are now injection molded something and seem to fail at a much faster rate than the turned Delrin. But from the picture they do look softer so that could be a worthy argument. I've had more than a few order mine (For Ford electric windows and headlight motors) after they used the Help bushings saying they did not last very long. Anyone here have a similar experience using the Help bushings?
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
painandgain99
Report this Post10-06-2015 01:37 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks rodney, love your store im getting your clutch master cylinder soon.
Can anyone link me to a tutorial on how to disassemble and reassemble the headlight motor? Couldnt find a good detailed tutorial.
Report this Post10-07-2015 01:28 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
From 2nd Gen Headlight Pin Replacement This vid claim he contacted Dorman and new clear ones are allot better but didn't try.
Have you or anyone call/email Dorman? Current product is clear plastic. Old one above look about same as OE HL pins. There are allot of old parts still in inventory at many outlets.
I won't trust most people saying Dorman are junk, new or old version of pins, Because other reasons why the pins can break but most people just blame the pins. The Internet is very good at pushing Myths and the bad the better.
Gen2 HL module a bit late on killing power can overload the pins. If the door and/or lift are binding that can overload the pins too. Overloading can break/shear the pins then grind them to dust. While a pain to replace the pins... Is allot easier and cheaper then replace/fix the gear or output shaft.
[This message has been edited by theogre (edited 10-07-2015).]
Report this Post10-07-2015 11:52 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Mar 99
I ask Dorman today what family plastic both versions are make of and they tell me "Thermoplastic polyurethane (TPU) is what they’re made of."
I guess same family/class but different formulas...
You can look up charts etc for this from many sources.
