  Crate engine value
Crate engine value by 85fieroguy
Started on: 11-08-2015 09:37 PM
Replies: 22 (971 views)
Last post by: rogergarrison on 11-17-2015 04:49 PM
85fieroguy
Report this Post11-08-2015 09:37 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting article in Car and Driver Sept. 2014 about crate engines as to the power per dollar efficiency. For a Fiero engine transplant..the winner is..Chevrolet 350 290 HP, 326 lb.ft., 352 lbs. $2560. Whats your opinion ??
Khw
Total ratings: 134
Report this Post11-09-2015 01:01 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did it take in to consideration the cost of the adapter plate so you can use that engine in the Fiero? That may change the results a bit possibly. I mean a "basic" kit to make it so you can mount the RWD engine to a FWD transmission is around $1000.00. That changes it from just under $9.00 per HP to just over $12.00 per HP.
[This message has been edited by Khw (edited 11-09-2015).]
Domtech
Report this Post11-09-2015 01:08 AM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
If this is what you are referring to, than it is just a comparison of crate engine values.
It is lacking tons of engines that people commonly swap.
Khw
Total ratings: 134
Report this Post11-09-2015 01:37 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Considering I don't see any of the common V6 swaps on that list, I have to agree.
dobey
Total ratings: 371
Report this Post11-09-2015 09:33 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Of course it's not taking into consideration many of the things which are required to actually make that power. It's only considering peak rated HP (which is a very useless number by itself), and doesn't consider cost of exhaust, carb, mounts, and accessories, needed to make the engine work in the cars it would be swapped into. It's a list of crate motors commonly put into classic cars that are longitudinally mounted front-engine cars, and not an entirely proper comparison.
For a Fiero there are definitely much better options available. If you're building a classic muscle car and only care about straight line performance, then wanking to peak HP might do it for you. But peak numbers don't actually tell you anything about the performance of an engine, or the car it's in, nor about its fuel economy or maintenance cost for the life of the engine.
dobey
Total ratings: 371
Report this Post11-09-2015 09:35 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
dobey
Member since Sep 2001
The list you're referencing doesn't say anything about Fieros. You're taking some overly simplified values and trying to apply them to a case not even considered in the listing, which doesn't work.
Thunderstruck GT
Total ratings: 99
Report this Post11-09-2015 09:38 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many/most "crate" engines have internals that are like a box of chocolates.
You never know what you're gonna get.
jscott1
Total ratings: 415
Report this Post11-10-2015 12:18 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I guess you are not familiar with the crate motor market... good luck finding a V6 on the list. GM used to sell the 3.4 pushrod, but they probably don't anymore. About 99% of the crate motors are V8. Most of the engines people are swapping from the junk yard are no longer in production let alone available in crate form.
Khw
Total ratings: 134
Report this Post11-10-2015 01:08 AM Click Here to See the Profile for KhwSend a Private Message to KhwEdit/Delete MessageReply w/QuoteDirect Link to This Post
There was a post on here in either the tech section or GFC, I don't remember which, with a link to crate 3800's. I did a search and found a link to one pretty quickly although without calling that doesn't mean they still have them.
http://www.crateenginedepot...-89017861-P9427.aspx
I know when I was looking for a engine back in the early 90's there were crate Nissan Z24 4 cylinder engines available for my 84 Nissan 720. The cost was about 3x that of a reman but they were available. Also when I changed engines for a Doctor in his 09 Malibu recently he had me look into engines and get him costs. Crate 2.4 Ecotecs were available but with the cost difference he chose to go with the 22,000 mile used engine instead.
I get what your saying though, V8's may be the most common but that doesn't mean only V8's are out there.
[This message has been edited by Khw (edited 11-10-2015).]
jscott1
Total ratings: 415
Report this Post11-10-2015 01:21 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I guess I should have said that GM no longer sells crate V6... the ones from Crate engine depot are new old stock. They stopped making the 3800 at least 6 years ago. But my point is that there is very small to zero market for a crate V6. The folks out there buying crate motors are buying V8 for front engine longitudinal swaps. Transverse guys like us exist but we are a niche product for sure.
dobey
Total ratings: 371
Report this Post11-10-2015 08:00 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only non-V8 "crate" motor from Chevrolet Performance (GMPP) is the LTG Ecotec. You can still however order up any current or very recent production V6 or Ecotec from a GM dealer. You're just not going to find any old V6 or 4 cylinder engines from the 90s, like the 3.4, from a dealer.
Formula88
Total ratings: 554
Report this Post11-10-2015 11:55 AM Click Here to See the Profile for Formula88Send a Private Message to Formula88Edit/Delete MessageReply w/QuoteDirect Link to This Post
And typically the crate V6 engines were service replacements that weren't much more than long blocks in some cases. A service replacement 350 would be even cheaper than the 290HP 350 shown in the chart. (less powerful, too since it would have been a pre-LS truck 5.7L service engine most likely)
rogergarrison
Total ratings: 551
Report this Post11-13-2015 09:46 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.google.com/webh...es+for+sale&tbm=shop
just took me 20 seconds to find.
jaskispyder
Total ratings: 205
Report this Post11-13-2015 09:55 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Devil is in the details.... it is easy to use the keyword "crate" in your page content, so it appears on a search from Google Shopping.
The Fiero engine is a rebuild...
http://www.powertrainproduc...LTjckCFYRDaQoduBkFyg
Another engine is USED....
http://www.purzauto.com/Par...HTjckCFQuGaQodD2QOJw
Others are listed as "refurbished".....
None of these are "Crate" engines.
rogergarrison
Total ratings: 551
Report this Post11-14-2015 09:27 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your posts always show up right on my tail. You follow me around all the time. I did not search specifically for Fiero engines...only what they called crate V6 engines. There are 4.3, 3.4, etc all listed. I called some of them and they were new assembled engines and rebuilt ones from factories. So you found 3 or 4 out of a 100. Good job.
Im sure if I spent more than a minute, I could find 2.8s too. The whole point was they said you cant find any replacement (crate) v6 engines. 'Crate' engines do not have to be brand new. Its simply a complete engine, finished to the degree you want...short block, long block, ready to run, etc. In case you need the definition of a crate motor :
http://www.ehow.com/about_5...10_crate-motor_.html
http://www.powertrainproduc...CQkMkCFUM2gQodPmMLig
http://www.erlperformance.c...OQkMkCFdgLgQody0AA6w
http://www.mondellotwister.com/index.htm
[This message has been edited by rogergarrison (edited 11-14-2015).]
Total ratings: 461
Report this Post11-14-2015 11:43 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
LZ9
They also offer remans.
[This message has been edited by Raydar (edited 11-14-2015).]
rogergarrison
Total ratings: 551
Report this Post11-15-2015 07:28 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
There ya go and im sure there are many others if you look for a while. A 'crate' engine simply means an engine thats shipped to you in a crate or pallet. Seems some think its only an all brand new OEM built factory engine.
jscott1
Total ratings: 415
Report this Post11-16-2015 01:33 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry but none of these fit MY definition of crate engine....which is a zero miles brand new engine from the original manufacturer.
[This message has been edited by jscott1 (edited 11-16-2015).]
jscott1
Total ratings: 415
Report this Post11-16-2015 01:36 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
jscott1
Member since Dec 2001
Yes that is the definition that I use... a crate engine is a brand new zero miles engine from the original manufacturer. Yeah sure a junk yard can crate up a used piece of junk and ship it to you but that does not make it a crate engine in my book.
jaskispyder
Total ratings: 205
Report this Post11-16-2015 07:30 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
rogergarrison
Total ratings: 551
Report this Post11-16-2015 06:51 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just stating what the exact definition is. I consider it a crate an engine if built by a reputable shop with all new, not necessarily OEM, parts on a new or seasoned block with heads and pretty much complete - except for exhaust, intake, carb/FI, alternator, maybe water pump. Jasper fpr example makes/sells rebuilt/ crate engines. Jegs amd Summit sell rebuilt/crate engines. Those all fit MY definition. Even though it fits the technical definition, I dont consider any used engine a crate engine in any case.
Thunderstruck GT
Total ratings: 99
Report this Post11-16-2015 06:58 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The term "crate engine" is often over used, over stated and mis-used.
Just like "Rat Rod", "Barn Find", "All Original", and "N.O.S."
rogergarrison
Total ratings: 551
Report this Post11-17-2015 04:49 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are all pretty clear cut to me.
rat rod = homemade car built out of parts of many random parts and all usually in their natural condition.
barn find= a car thats been stored in some kind of shelter and out of sight for 30 years or more. Dont really refer to condition, but generally a pretty much intact vehicle.
All original = car with the vast majority of the parts on it still the same as it came with from the factory. If I remember, Corvette Gold award for an original car, must be at least 4/5 of the body and interior must be the same on it new, and the engine, trans and rear end must be number matching. You could do a valve job, or replace a part like a carb with a new one if that replacement is identical to the one on it from the factory. You could repair like a damaged quarter panel and repaint it (up to 20%).
NOS = is simple. It must be a factory part as installed on the assembly line, and be in an unsold, unused condition...usually in its original packaging. New Old Stock.
[This message has been edited by rogergarrison (edited 11-17-2015).]
