  Electric trunk release works intermittently
Electric trunk release works intermittently by lorennerol
Started on: 03-05-2016 07:06 PM
Replies: 3 (171 views)
Last post by: MRBLUE87 on 03-06-2016 08:28 PM
lorennerol
Report this Post03-05-2016 07:06 PM Click Here to See the Profile for lorennerolSend a Private Message to lorennerolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been working only intermittently (and seemingly randomly) for a couple years now. I figured it was a bad ground in the latch mechanism, but I just took it all apart and cleaning it up (rust), and still no-go. I can hear the relay clicking in the dash, but the piston that releases the latch doesn't move. Not sure what to fiddle with next. Any ideas?
jscott1
Total ratings: 415
Report this Post03-05-2016 11:13 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would check the voltage at the solenoid and see if it's 12V+ every time you push the button. If it is I would replace the solenoid. If not then you have an intermittent wire somewhere between the relay and the solenoid.
Total ratings: 571
Report this Post03-06-2016 11:06 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Trunk Release
just poorly adjusted or dirty latch parts can cause power latch problems.
any switch(es) or relay can cause problems too.
need a simple test light to find what's wrong.
MRBLUE87
Report this Post03-06-2016 08:28 PM Click Here to See the Profile for MRBLUE87Send a Private Message to MRBLUE87Edit/Delete MessageReply w/QuoteDirect Link to This Post
The solenoid grounds through the lid latch. If it fails to operate, have an assistant reach under the lid lip and pull up on the lid. This will force the latch against the striker. Try the switch again and see if the solenoid works. If it does, tighten the striker to hold the lid down more.
