Hi fellas,
For some time now I have been working on a 95 3.4L swap. I purchased my 86 Fiero two years ago. this one makes #5 I have owned And by far the best.
I started off with my swap by doing lots of research mostly from reading post here on PFF. You all have been great. I would like to say that my swap has gone great but it has not. I had some trouble with the engine. First off i purchased a 95 Camaro engine with 28k miles. I did the swap and the car ran great That is until I noticed that I had a grey/silver sheen in my oil. long story short my cam bearings got chewed up badly. How you ask? Well after I completed my engine I noticed low oil pressure than cam started knocking. So I made up my mind to drop the engine for the third time. As I was tearing things down I noticed what seemed to be sand or gravel on the intake just around the oil fill hole. After looking further it seemed to be gravel you would see on a parking lot. I took the valve cover off and noticed little pebbles on the head. After taking off the intake there were pebbles in the vallies next to the lifters. I was puzzled because I know when I put the engine together the engine was clean I made sure of that. Than I started thinking and remembered that the day after I got things running smooth I took the car to Walmart with the deck lid off. I think some jack A#$ put sand in my engine.
So now I will share with you my newly built engine and the progress so far.
The engine was taken to a local machine shop "jimmies motor machine". Jimmie bored the engine .020 over, he installed fordged pistons reworked the crank rod and main .010 under. The cam was perfect in spec even after the sand it had no deep scratches not even light scratches. It needed nothing however we used a new cam just to be safe
While the engine was being built I took the time to do work on the cradle. I sodablast some parts and after 12 cans of oven cleaner and a few tanks of gas in the pressure washer the cradle was clean as a whistle.
After paint.
I also painted the upper and valve covers with Chrysler red engine paint from autozone and a new fiero sticker from TFS
MY old 2.8 and heads
The new engine, it was wrapped in plastic and tied down. No I did not roll it home like that.
ready to pull her out of the Buick
on the stand
I heard some bad things about fram filters. I did not have a fram filter on the engine when I took it to Jimmies. however he warned me that if I use a fram filter he would void my warrenty.
on the stand again.
MORE PICS TO COME AS I MOVE FUTHER ALONG.
[img]
[/img]
[This message has been edited by Ramon (edited 03-10-2016).]
