  JUMP ! In here, need advice
JUMP ! In here, need advice by robert1234
Started on: 03-16-2016 06:54 PM
Replies: 15 (284 views)
Last post by: css9450 on 03-18-2016 10:46 AM
robert1234
Report this Post03-16-2016 06:54 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry everyone,,,,,
But I'm finally checking out my exhaust leak on my 88 Formula
The leak if from a rusted off bolt on the front manifold (yes near window).
What are my options since the others are not good but there ?
Pull the engine ?
Report this Post03-16-2016 07:17 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're already aware of the jig required. I had a couple of broken exhaust manifold bolts in my '86 GT on the back window side of the engine. Not a pleasant repair to tackle. I eventually tipped the back of the cradle down to give me enough room to get a right-angle drill in there. It's a b*tch of a job.
[This message has been edited by Patrick (edited 03-16-2016).]
Thunderstruck GT
Total ratings: 99
Report this Post03-16-2016 07:18 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welp............
If it were me, I'd pull the intake and heads. Others probably would/will argue my way of thinking but you are going to have a nightmare on your hands if you try to do it on the car.
The other advantage to pulling the heads is you can do both manifolds, clean the heads & upper end and reseal the whole upper end. Which on an older engine really isn't a bad idea.
I'm betting you're going to have the same amount of time invested doing it either way and my way will make the engine better.
Report this Post03-16-2016 07:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
My way builds character.
robert1234
Report this Post03-16-2016 07:23 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
I pulled the other manifold two months ago and replaced the gasket on it, now the front one is leaking ...uuuuhhh
I have the drill guide, drill bit and out bit already.
Thunderstruck GT
Total ratings: 99
Report this Post03-16-2016 07:36 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
But.... We own Fieros
Doesn't that make us all "characters"?
Report this Post03-16-2016 07:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Touché.
viperine
Report this Post03-16-2016 08:58 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I picked option "C". Pull the engine. Replace with a 3800. Less aggravating, more rewarding.
robert1234
Report this Post03-16-2016 09:27 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
What about the engine tilter...here
https://www.fiero.nl/forum/A...100421-2-095333.html
robert1234
Report this Post03-16-2016 09:29 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
robert1234
Member since Oct 2015
Id love to replace with a 3800, but need the cash for other things right now.
Report this Post03-16-2016 09:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by robert1234:
What about the engine tilter... here
Although I had even posted in that old thread about the engine tilter, I chose to tilt the cradle when I drilled out my broken exhaust manifold bolts. I don't know for sure, but it seemed to me at the time that tilting the cradle would give more room to work.
robert1234
Report this Post03-16-2016 09:53 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Pat
IanT720
Report this Post03-17-2016 03:15 PM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just drop the cradle. In my 2 car garage with a floor jack and limited tools I can drop it in 1 hour usually. Much easier than messing with removing the heads in the car.
1987 Fiero GTX 3800 Turbo... My Build, ST3 Cam, Lowered, Wheels, and pics enjoy!https://www.fiero.nl/forum/Forum1/HTML/089483.html
Report this Post03-18-2016 08:12 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Plus you can degrease and clean and paint everything up nice in the bay while you are at it.
jaskispyder
Total ratings: 205
Report this Post03-18-2016 10:38 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, pulled the heads. I tried drilling out the broken bolt(S) and also tried welding a nut to them. No go. Took heads to a machine shop and they were able to take care if it. They said they can do this much quicker and I have to agree.
I didn't mess with the rockers and lifter adjustment. I bought a tool to compress lifter and remove rods. Wasn't bad at all.
Replace the bolts with studs and nuts.
Welp............
css9450
Total ratings: 87
Report this Post03-18-2016 10:46 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've long ago resigned myself to pulling the head(s) if I ever have to face this chore.
I've never dropped a cradle so maybe I am unawares if that is in fact easier.
