  EV propulsion adapters for electric conversion
EV propulsion adapters for electric conversion by lou_dias
Started on: 08-03-2016 03:58 PM
Replies: 7 (669 views)
Last post by: Stubby79 on 04-30-2017 02:54 AM
lou_dias
Total ratings: 67
Report this Post08-03-2016 03:58 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.ev-propulsion.com/adapterscouplers.html
There seems to be a Fiero adapter.
Has anyone used this?
Total ratings: 461
Report this Post08-03-2016 06:15 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
"•1980 Chevrolet Corvette (California only)"
Because everyone knows the 49 state Corvette, and all the other years, are so different.
lou_dias
Total ratings: 67
Report this Post08-04-2016 12:43 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found this one too:
http://www.evwest.com/catal...h=36&products_id=114
lou_dias
Total ratings: 67
Report this Post08-04-2016 01:43 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
lou_dias
Member since Jun 2000
Warp 11HV motor capable of 600 ft*lbs with 280v
http://www.evwest.com/catal...ath=8&products_id=53
lou_dias
Total ratings: 67
Report this Post08-08-2016 11:20 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.ebay.com/itm/EV-...V-West-/111095115654
So you can buy electric motors with an output shaft on each end ... this lets you run this type of adapter for running traditional accessories like A/C pump.... Pretty cool.
dobey
Total ratings: 371
Report this Post08-08-2016 12:38 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah. The vehicle application list is a bit weird, and seems to be wildly incomplete. I like how the metric pattern version has cover plates for the starter notch on both sides, so one side needs cut for transverse, and I think the other side might need cut for the 4WD S-truck applications (don't recall how close the forward driveshaft gets exactly).
PePe-LePu_For_2
Report this Post04-29-2017 11:55 PM Click Here to See the Profile for PePe-LePu_For_2Send a Private Message to PePe-LePu_For_2Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have, and I had to grind off an outcropping on one side of it that interfered with the CV joint such that you could not do a clutch job without pulling the axels off.
"88 GT converted to electric drive"
Stubby79
Total ratings: 58
Report this Post04-30-2017 02:54 AM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
These look like CanEV adapters. You can probably find more detailed information on their site, CanEV.com. Supposed to be one of the best built adapters out there.
