  I want to learn how to overhaul the V6 engine.
I want to learn how to overhaul the V6 engine. by robert1234
Started on: 11-29-2016 05:23 PM
Replies: 16 (428 views)
Last post by: MarkS on 12-05-2016 10:02 PM
robert1234
Report this Post11-29-2016 05:23 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is the best way to do it?
1) Buy an old V6 engine from a GT or Formula and take it apart ? I see them all the time for cheap that has problems.
2) Is there a cheat sheet on what to replace to rebuild one ?
I've never done a rebuild, but mostly done everything else. I need all the information I can get.
I just want to be able to pull my engine one day when it needs it. I like to be prepared.
Ideas welcome....
Thanks
lateFormula
Report this Post11-29-2016 06:06 PM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hands-on experience is great.
But it is better to have a good resource as a guide to help you with any aspects of rebuilding one of these engines. An excellent resource that you should seriously get is this book: https://www.amazon.com/Rebu...&keywords=Tom+Currao
Report this Post11-29-2016 06:37 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by lateFormula:
An excellent resource that you should seriously get is this book...
For sure. Just think of all the forum posts there'd need to be to cover ALL that material.
steve308
Total ratings: 57
Report this Post11-29-2016 07:44 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not to mention all those who would chime in saying the materials instructions are wrong and must have been written by idiots
Report this Post11-30-2016 09:47 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Over the years, we have found errors in ALL the printed material commonly used, even the factory service manuals. The engine rebuild manuals would be no different, but it's the best place to start.
sardonyx247
Total ratings: 219
Report this Post11-30-2016 10:10 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
My build thread has all the info and pics for rebuilding the 60 deg V6.
Link in sig
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
Now on my 11th Fiero
Report this Post11-30-2016 10:46 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Service manual is best place to start.
[This message has been edited by 2.5 (edited 11-30-2016).]
Report this Post11-30-2016 10:47 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
Is there a collection of corrections to the errors? One would think there could be.
Total ratings: 329
Report this Post12-01-2016 07:55 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use to rebuild but considering the parts, labor and machine shop costs, it came out far less expensive to do engine swaps. The last rebuild that I did 15 years ago cost almost $2000.
robert1234
Report this Post12-01-2016 08:28 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, the cost is about $2000.
I'm not going to do it then. Not worth that.
Report this Post12-01-2016 08:32 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depends on what's worn. A set of rings and gaskets (if that's all that's required) would be a lot less than two grand.
[This message has been edited by Patrick (edited 12-01-2016).]
robert1234
Report this Post12-04-2016 08:00 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well after many hours of research and a collection of great videos, I'm sure I can do it now.
So, when the time comes I'll be ready.
Total ratings: 329
Report this Post12-05-2016 10:44 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you were to do this rebuild for less it would have to assume:
the cylinders are not worn to the point of where they would need to be re-bored. Add machine shop costs and a new set of pistons
that the crankshaft is not scored or grooved as that would require regrinding. If its too worn it will need replacement
. that the valve seats are still in good shape.
In all cases a new timing chain, rings, gaskets, bearings
then what about the fuel injectors. Professionally cleaning can cost $100.
Then do you have the tools required like a ring compressor, cylinder hone, micrometers etc. If you want you can buy ours at half price and we even have some new unused stuff in the shop.
If you luck out in the best case, you will need, rings, bearings (don't forget the cam), new lifters, and gaskets but in all the rebuilds that we have done that wasn't the case. Machine shop work and rebuild parts costs added up too quickly to be practical. Those engines were money pitsThat is why few rebuild engines these days..
robert1234
Report this Post12-05-2016 12:21 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dennis,
You got PM
MarkS
Report this Post12-05-2016 02:54 PM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Curious, how many miles are on the engine, why does it need to be rebuilt? Simply rebuilding the heads on my 2.8 was a major improvement at 145K. The bottom end was still pretty tight, oil pressure good and once I had the heads off, there wasn't much of a ridge in the cylinders. While I was there, I replaced my water pump. If I were to do again, I would also do the timing chain and front cover seal.
BR's,
Mark
86 SE V6 Auto
65 Tempest 400 CID
2008 G6 GT "Street" Coupe
2005 Buick 3.6 Rendezvous
2001 Olds Silhouette (AKA The Band Van)
robert1234
Report this Post12-05-2016 08:34 PM Click Here to See the Profile for robert1234Send a Private Message to robert1234Edit/Delete MessageReply w/QuoteDirect Link to This Post
Seems like it has 148K on the engine.
If I pull it I'm doing what I can to it while its out.
It has an exhaust leak and a bolt broken off on the manifold from the previous owner. Yep the hard one to get to.
Its very drive-able but lacks power....expected
I have another manifold already.
[This message has been edited by robert1234 (edited 12-05-2016).]
MarkS
Report this Post12-05-2016 10:02 PM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Going forward, depends on your goals and budget. I can tell you if the bottom end of your engine is tight, pulling the heads for a rebuild can be done with the engine in the car and will allow you to fix the manifold bolt addressing the exhaust leak. At the same time you can port the exhaust manifolds for a few extra ponies. Cost is in the hundreds of dollars. But no step wise increase in power.
