  Inner door handle broke. Any more to know about how to fix it ?
Inner door handle broke. Any more to know about how to fix it ? by CoolBlue87GT
Started on: 01-30-2017 12:45 AM
Replies: 5 (588 views)
Last post by: CoolBlue87GT on 01-30-2017 11:16 PM
CoolBlue87GT
Total ratings: 151
Report this Post01-30-2017 12:45 AM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
[ EDIT: There was access w/o removing door panel, do not remove door panel ]
My drivers side inner door handle broke today, have been searching the forum for hints how to replace it. I've copied the various postings from the past few years. Wondering if anyone has any more hints how to do this repair. Thank you in advanced.
Following are the postings members have posted..
It is rather simple. Two screws on the cover of the handle, pry off the cover at the end of the lock rod. Remove armrest then the interior door panel--try not to rip out the clips. Drill out rivet attaching the handle to the door frame. Replace the handle, put new rivit in and then put everything back togther.
There's a pin that holds it in.
Heh.....this just happened to me too. The alignment shop busted my inside drivers door handle.....nice guys!
Anyway, it isn't too difficult to fix, but is involved. You need to do the following:
-Remove the armrest
-Remove the shroud around the handle (2 small screws)
-Carefully remove the inner door panel (those plastic push pins are a pain)
(if this is for the drivers door and you have a manual outside mirror, remove the cable from the holder with a small allen wrench)
-The door handle is held in place with one rivet.....remove that rivet and it will come free from the door
-Remove the rod from the backside and you're done.
-Re-install the new one and you're good to go.
Once you remove the rivet that holds the handle to the door it will pull out enough that you can get to the rod on the back side.
There is a clip you have to release and the rod should come off.
If it's a Z bend then you just take it off.
You should be able to put the handle back on with a small bolt if I remember correctly.
Here's a link to purchace a replacement.
http://www.dormanproducts.c....aspx?origin=keyword
[This message has been edited by CoolBlue87GT (edited 01-30-2017).]
sardonyx247
Total ratings: 219
Report this Post01-30-2017 01:37 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
I see you answered your own question.
That is all there is to it.
Mine broke once on the way home from Burning Man, (playa dust jams/breaks EVERYTHING)
I had to roll down the window to let myself out until I got home.
Edit to add: I just used rivets to reinstall.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
Now on my 11th Fiero
[This message has been edited by sardonyx247 (edited 01-30-2017).]
KissMySSFiero
Total ratings: 111
Report this Post01-30-2017 10:19 AM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just replaced mine for the same reason.
It was pretty straight forward. No need pull the door panel.
I had a rivet gun so I re-riveted it with an aluminum rivet.
I used a 1/4" because that's what I had. I had to drill out some. 3/16" should work and it's more common.
I don't think I'd trust a screw to hold long term and getting a nut in there for a bolt would be a headache.
I'd expect it to be a 30-45 minute job the first time at a casual pace.
I used a handle from a spare door.
SSFiero@Aol.com
KissMySSFiero
Total ratings: 111
Report this Post01-30-2017 10:26 AM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
KissMySSFiero
Member since Nov 2000
I just want to add.
I don't remember removing the door panel. I hate removing them because the metal clips the Christmas tree clips attach to always seem to break. If you've removed a panel, you know what I'm referring to.
I recall this being simple. Try it without pulling the panel. You have to remove the black handle trim regardless.
Feel free to pm me if you have any questions.
CoolBlue87GT
Total ratings: 151
Report this Post01-30-2017 12:12 PM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's what I found, with the black trim removed, drilling out the rivet & removing the assembly took 5 minutes.
KissMySSFiero , Thanks, your correct, discovered there was access w/o removing door panel. Now I have to wait till 1:30 for the auto parts store to get the part from a nearby warehouse. Hope this helps the next person that has one break on them.
CoolBlue87GT
Total ratings: 151
Report this Post01-30-2017 11:16 PM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
CoolBlue87GT
Member since Apr 2001
The Doorman replacement did not have the braket used to screw the trim on to. I drilled out the two rivets & rivited the braket to the new latch assembley.
