  LED conversion?
LED conversion? by tshark
Started on: 05-03-2017 06:58 PM
Replies: 13 (567 views)
Last post by: Dennis LaGrua on 05-12-2017 07:44 AM
tshark
Report this Post05-03-2017 06:58 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by tshark (edited 09-07-2018).]
Fiero Vampire
Report this Post05-03-2017 07:08 PM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
What area is local to you currently your location is blank.
notwohorns
Report this Post05-03-2017 07:10 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
What kind of conversion you talking about?
tshark
Report this Post05-03-2017 07:10 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
notwohorns
Report this Post05-03-2017 07:11 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
tshark
Report this Post05-03-2017 07:14 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post05-08-2017 04:40 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sold your white one Tshark?
tshark
Report this Post05-08-2017 06:10 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Synthesis
Total ratings: 290
Report this Post05-09-2017 02:24 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not local to you, but the wife's 86Coupe is show-worthy (Thanks 2.5 and wife!)...
I know LEDs extremely well, and can photo document everything if you are up for giving a long distance Fiero relationship a try.
tshark
Report this Post05-09-2017 06:09 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
78_elky
Report this Post05-11-2017 04:42 PM Click Here to See the Profile for 78_elkySend a Private Message to 78_elkyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious, what is the LED solution for the headlights? I'm dealing with my lack of visibility at night right now.
Jessica
tshark
Report this Post05-11-2017 05:42 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Synthesis
Total ratings: 290
Report this Post05-11-2017 10:07 PM Click Here to See the Profile for SynthesisSend a Private Message to SynthesisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by tshark:
How would a long-distance Fiero relationship work?
Well, with regards to the LED stuff, that's easy enough for me to figure out from my end. If they are LED arrays that replace socketed bulbs, that's just some creative cutting/adhesive to get them in behind lenses.
I'm getting ready to start my Neopixel LED tail light conversion on my GT, and have built a few LED light fixtures from scratch for the Fiero...
I have 90MM headlight buckets for her car, so could fit two lamps per side.
I couldn't give you a ride due to the distance, but everything would be fully documented otherwise.
[This message has been edited by Synthesis (edited 05-11-2017).]
Report this Post05-12-2017 07:44 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Headlights, turn lights, markers, tail lights, etc. I think the inside lights, also. This would not include any lenses. Just the bulbs. I understand we have/had vendors for these, and nothing against any of them. I'd like to see how the process works, what they can do, etc. I also think that the Fiero presents a lot of challenges. Maybe they can't/won't do it. I was approached by them.
Sounds good as LED's use less power and last a long time, but allow me to relay a story. A while ago I changed just the trunk lamp to an LED. It shines bright, looks nice and draws little power, so little power that my Excalibur alarm system will not trigger when the trunk is opened with the alarm on. If and only if you have an alarm system consider that a work around may be necessary for some LED's.
