  Oil leak
Oil leak by Colebrooke Farms
Started on: 06-05-2017 06:03 PM
Replies: 2 (160 views)
Last post by: steve308 on 06-05-2017 09:36 PM
Colebrooke Farms
Report this Post06-05-2017 06:03 PM Click Here to See the Profile for Colebrooke FarmsSend a Private Message to Colebrooke FarmsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello, I just replaced alternator in my 87 fiero v6. It ha a very little oil leak before I started but when I had finished and ran the car for awhile there was a lot of oil under the car. The alternator replace was difficult, bracket bolted on to the motor mount, had to pry engine to line up holes again to bolt together. Any suggestions
Report this Post06-05-2017 08:52 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Colebrooke Farms:
...had to pry engine to line up holes again to bolt together.
An obvious question is what were you prying on? Anything to do with the oil pan and/or timing chain cover?
steve308
Total ratings: 57
Report this Post06-05-2017 09:36 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you poke a hole in the filter or damage the oil pressure sending unit? Lot's of stuff that doesn't like to be poked and pried on in that area.
