  3800 build
3800 build by Tstang429
Started on: 04-18-2018 02:58 AM
Replies: 10 (703 views)
Last post by: nosrac on 04-24-2018 09:15 AM
Tstang429
Report this Post04-18-2018 02:58 AM Click Here to See the Profile for Tstang429Send a Private Message to Tstang429Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking for someone that is still building and tuning 3800 motors. I tried to reach out to dark horizon with no luck. I am looking for help to get close to 400whp or more from a 3800 motor.
Report this Post04-18-2018 10:34 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's a very aggressive goal for a 3800. AFAIK that goal has been reached but only by boosting the engine with a turbo. ZZ Performance is the preeminent source for engines of this type but forum member Jcircs (Jerry) also had a killer 3800 engine built If you really want to hit 400HP be prepared to spend a considerable amount of money.
wstefan20
Report this Post04-19-2018 01:29 AM Click Here to See the Profile for wstefan20Send a Private Message to wstefan20Edit/Delete MessageReply w/QuoteDirect Link to This Post
400+ whp isn't unreasonable and really doesn't even require that many mods. I've seen guys run numbers like that all day with a 3" pulley, larger injectors/pump, methanol injection, intercooler, cai, and 1.9 rockers easy.
I myself just got into tuning, so not much help in that department. I just got into rebuilding the engines so feel free to ask any questions you have. I have two rebuilt engines still on the road, one of them (in my daily driver) is at over 7000 miles since the rebuild with no issues, the other in a friend's car with 4000.
I think 3800s get a bad wrap for rebuilding not because they are any different than any other engine, but because people cut corners and are surprised when they get burned. Now, I realize that you can cut corners on say a 350 chevy rebuild and it run ok, but try that on these and they'll surely live up to that "500 mile or less engine". The real secret is to partner up with a machine shop you trust.
A few big things people make mistakes on though: believe it or not, these engine's warp slightly when the heads are bolted on, so you 100% have to have a special plate to simulate these loads when the engine is being overbored. I also didn't make a mistake by saying "when" these engines get rebored. I've taken measurements from over a dozen 3800 cores and any over 80,000 miles or so have "eggshaped" cylinder chambers and require bored out to a larger size to correct the wear so the piston rings can seal properly. Which also means you need new pistons and rings gaped properly. Which also means you need to re-balance your crankshaft assembly. Which speaking of balance, requires you need to have a main line hone for these engines to run properly after a rebuild. The connecting rod caps also stretch into an "oval" requiring the caps to be planed to bring back to tolerance, which the crank needs to be checked and polished, and after spending all this money on the low end, you might as well have the valve seats re-cut and springs replaced, and magnaflux the block and heads, and grind valves. The 100% most important part is to replace ALL tty bolts. The head bolts, main bolts, connecting rod bolts, flywheel bolts, torque converter bolts, balancer bolt, camshaft bolt, crank bolt, rocker bolts, cam thrust plate bolts are ALL torque to yield and need replaced. You need the block and heads resurfaced. You NEED every spec checked and rechecked on every bearing and every dimmension. Every bearing replaced, cam checked. Everything assembled correctly with engine lube and inspected and kept clean.
As an example, I pieced together my engine rebuild kit myself and did most of the measurements and all of the assembly by myself and still spent $1500 at a local shop just to rebuild it stock. A performance engine build even if you do your own blueprinting and port work, you're still looking at minimum $2000 and up. There engines are not cheap or easy to rebuild and they are not forgiving of errors.
I would say for your goals, it'd be more worth your money to pick up a more aggressive cam, smaller pulley, n* tb with ls maf sensor, #60 injectors, upgraded fuel pump, methanol kit, and a good tuner.
I have to admit though, for my 3800 I'm going stupid and running forged connecting rods and ceramic coated forged pistons, I'm debating on splurging on aluminum heads, hand porting, hv3 L26 upper intake, n* with ls maf, #80 injectors, dual timing chain, balance shaft delete, and 75mm turbo with 6L75 transmission so I can't say too much! Feel free to ask any questions I didn't answer!
Tstang429
Report this Post04-19-2018 08:34 AM Click Here to See the Profile for Tstang429Send a Private Message to Tstang429Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am going turbo.
AWautoworks
Report this Post04-19-2018 09:21 AM Click Here to See the Profile for AWautoworksSend a Private Message to AWautoworksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check out SCHWA Motorsports. He has done many 3800 SC swaps. Specialized in forced induction of any kind. He did my 3900 swap which is scheduled to add boost before the 35th anniversary show. Ephkay is his name here on the forum.
Here is our current build
T-top widebody
nosrac
Total ratings: 50
Report this Post04-19-2018 05:57 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know a guy in Texas... I'm shooting for 500WHP in mine with a Turbo of course. ST1 cam + Decent Turbo (Precision, Borg Warner EFR series) + supporting mods will get you 400+ easily.
[This message has been edited by nosrac (edited 04-19-2018).]
Tstang429
Report this Post04-22-2018 11:06 PM Click Here to See the Profile for Tstang429Send a Private Message to Tstang429Edit/Delete MessageReply w/QuoteDirect Link to This Post
nosar can you give me some help on my turbo setup. I can not get anyone to help there. the info is all over the dang place.
Tstang429
Report this Post04-22-2018 11:13 PM Click Here to See the Profile for Tstang429Send a Private Message to Tstang429Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tstang429
Member since Jun 2008
current plan
1.6 roller rockers
intense racing stage 2 cam
ls6 valve springs.
l67 block
Camaro intake and throttle body
intercooled.
turbo????
injectors???
removed ac
Removed balancer
Double roller chain with machined front cover.
nosrac
Total ratings: 50
Report this Post04-24-2018 08:56 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Get a Borg Warner EFR 8374 or EFR 7670. The 8374 is a perfect match but if you can go to the next smaller 7670 or larger 9174 size. Get a small turbo cam such as ZZP ST1. Dont get a large Turbo cam it's more trouble than it's worth for a DD street car.
nosrac
Total ratings: 50
Report this Post04-24-2018 09:01 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
Member since Jan 2005
60# injectors. Where are you mounting the Turbo? Rear mount works well and you won't need custom exhaust crossover. However, trunk cutting is needed.
nosrac
Total ratings: 50
Report this Post04-24-2018 09:15 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
nosrac
I am building another turbo car with Gen V m90 UIM and a block off plate. I am using the M90 so I can use the plate style IC as space is limited. I am also using the BW EFR 7670 as or is a street car. If you go too big on Turbo/Cam car will be a Dyno Queen/ Race Car because too much power to use on the street. You will just spin out and never get and traction.
