  Project car: 1984 Fiero SE IMSA (Page 2)
Project car: 1984 Fiero SE IMSA by FieroMaster88
Started on: 10-02-2018 10:52 PM
Replies: 102 (4059 views)
Last post by: FieroMaster88 on 04-30-2021 09:05 PM
FieroMaster88
Total ratings: 168
Report this Post08-04-2019 11:36 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by IMSA GT:
That's a really good price. I do have a question and maybe this will help others. Does this paint have a heavy chemical smell while spraying or can it be done inside a closed environment with no respirator?
You need to spray in a well ventilated area and wear a respirator.
FieroMaster88
Total ratings: 168
Report this Post08-04-2019 11:41 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroMaster88
Member since Nov 2000
Originally posted by Habanera Hal:
I'm also curious as to what it feels like. Is it "rubbery"? I've never actually seen a plastidipped car. How durable is it? My Fiero has some peeling clearcoat. Would I have to sand the whole car or just those "bad" areas?
Thanks!
It’s been on almost a week now. It feels pretty smooth, not rubbery. I’ve sprayed it with spray wax which helps with the feel and durability. I had one of my kids open the passenger door right into a metal handle of a lawn mower today and it didn’t leave a mark. They have bumped into it with bikes and it’s had a basket ball hit it with no issues. You would have to smooth the areas that are peeling if you didn’t want it noticeable when you were finished.
FieroMaster88
Total ratings: 168
Report this Post08-08-2019 10:05 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Had 46k on it when I got it.
88 Coupe: 2.0L Turbo 4 Cylinder, W2A, T25 Turbo, water/meth injection
84 Indy #64: Restoration Project
84 IMSA wide body SE: Restoration project
14 GMC Sierra: Daily Driver
Steel
Report this Post08-08-2019 11:14 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great pole building, I wish mine had the high walls like yours!
Car looks great, always wanted an IMSA.
FieroMaster88
Total ratings: 168
Report this Post08-08-2019 10:02 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Had all 3 cars out tonight.
What about Bob
Report this Post09-29-2019 02:04 PM Click Here to See the Profile for What about BobSend a Private Message to What about BobEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey James, she's looking good. I was thinking of a 94 Gran Sport Corvette color, Admiral Blue I think it was. Glad she found a good home. How did you fasten the glass wheel well liners? All 4 were hanging down. I have a few other things you may be interested in. Let me know.
My wife has relented and she suggested we could get a new toy for me. Something that my now limited flexibility will better deal with:
Had it since May. A great smile generator!
FieroMaster88
Total ratings: 168
Report this Post09-29-2019 10:52 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice ride. I love how the new challengers look. I was able to get the fender liners adjusted so they fit better and the mounting holes lined up with the holes in the body. I then used the factory style plastic push pins to hold them in place. Have been good for 2000 miles. What other parts do you have?
FieroMaster88
Total ratings: 168
Report this Post10-25-2019 09:06 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm....what could this be for...
FieroMaster88
Total ratings: 168
Report this Post11-13-2019 09:58 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Collecting parts for the 3800 swap. Should be fun. Ordered mounts, alternator bracket, tensioner bracket and flywheel from Fierorog. Spec stage 3 clutch. Taylor 10.4mm wire kit. Grand national fuel pump. Gasket kit for the engine. Some 2.5” exhaust pipe and a performance muffler. Picked up a DHP power tuner to program the pcm too. Need to get the engine out of the donor car still. The 2.5 from this Fiero is going to go in my Indy Fiero.
FieroMaster88
Total ratings: 168
Report this Post12-01-2019 07:41 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got the 3800 out of the donor car. Going to get it on the engine stand so I can strip it down, clean it and reassemble it with new gaskets. Now to get the cradle out of the Fiero.
FieroMaster88
Total ratings: 168
Report this Post12-27-2019 11:24 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
It’s clean inside for having 200,000 miles. Getting things cleaned and painted. Then we’re going back together with new gaskets.
[This message has been edited by FieroMaster88 (edited 12-27-2019).]
FieroMaster88
Total ratings: 168
Report this Post12-28-2019 11:25 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Putting it back together.
FieroMaster88
Total ratings: 168
Report this Post12-30-2019 01:35 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
It’s mostly back together. Have to order a newer style alternator, new starter and a coolant elbow. Then it’s ready to go in. Time to start pulling the duke out of the car.
Have a youtube video on this project: https://youtu.be/g3PRK7G1As8
FieroMaster88
Total ratings: 168
Report this Post01-04-2020 08:51 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
YouTube video of the swap progress:
FieroMaster88
Total ratings: 168
Report this Post01-12-2020 09:56 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finally has belts. Now to pull the engine out of the Fiero.
FieroMaster88
Total ratings: 168
Report this Post02-11-2020 06:09 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Made some progress today. Got the subframe out. Posted a video on YouTube. I also installed some Mr.Mikes seat upholstery.
Youtube Video
[This message has been edited by FieroMaster88 (edited 02-11-2020).]
Vicophine
Report this Post02-12-2020 09:18 AM Click Here to See the Profile for VicophineSend a Private Message to VicophineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome thread! Enjoy seeing what you have accomplished! Also it's great to see someone (somewhat) local to me do the exact swap I can dream of! I hope to see the car someday!
IMSA GT
Total ratings: 253
Report this Post02-12-2020 09:39 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very nice. I'm still jealous of that damn garage (warehouse) you have
blazin'
Report this Post02-15-2020 02:02 PM Click Here to See the Profile for blazin'Send a Private Message to blazin'Edit/Delete MessageReply w/QuoteDirect Link to This Post
That engine is a beaut! What did you paint the SC with?
[This message has been edited by blazin' (edited 02-15-2020).]
NCTyphoonKid
Report this Post02-16-2020 08:45 AM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like you’ve made good progress so far. I like the blue.
anaverin
Report this Post02-16-2020 10:04 PM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
good job rear engine shop
86 SE FASTBACK T-TOPS
88 FORMULA 4.9
87 GT MEDIUM RED METALLIC stockish
EMAIL : Anaverin@gmail.com
FieroMaster88
Total ratings: 168
Report this Post02-16-2020 10:59 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
It’s a high temp wrinkle black paint. I think it was made by dupli-color.
FieroMaster88
Total ratings: 168
Report this Post02-16-2020 11:00 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroMaster88
I plan on taking it to a bunch of car shows this year. 👍
FieroMaster88
Total ratings: 168
Report this Post02-16-2020 11:01 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroMaster88
Thanks! The shop is a dream come true. Hopefully getting a 2 post lift soon. 🤞
FieroMaster88
Total ratings: 168
Report this Post02-16-2020 11:03 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroMaster88
Thanks! I have to get better at editing videos. I’m trying. I need to get that subscriber count up!
FieroMaster88
Total ratings: 168
Report this Post02-22-2020 09:18 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ready to start wiring:
Also another YouTube video:
https://youtu.be/RhFYFCTmUcw
Quad GT
Report this Post02-22-2020 03:11 PM Click Here to See the Profile for Quad GTSend a Private Message to Quad GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
That would look so sweet in my DGP IMSA!
FieroMaster88
Total ratings: 168
Report this Post02-22-2020 07:03 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cleaning up the engine bay:
I also pulled the fuel tank. I should have time tomorrow to install the pump and build the rest of the fuel system.
[This message has been edited by FieroMaster88 (edited 02-22-2020).]
FieroMaster88
Total ratings: 168
Report this Post02-23-2020 09:01 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Today I wrapped the shift cables and throttle cable with heat tape. Painted some brackets also. I got the new fuel pump installed and the fuel lines modified. Started making the 6an fuel lines. The tank is back in the car. The plan this week is to install the firewall insulation and work on the wiring harness. If I get that done the engine will go in!
FieroMaster88
Total ratings: 168
Report this Post02-27-2020 10:00 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tired of me yet? Today I installed the firewall insulation, installed the fuel filter and mostly finished the fuel lines. Only a couple more things to do then it’s engine install time!
FieroMaster88
Total ratings: 168
Report this Post03-01-2020 12:55 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Working on wiring:
FieroMaster88
Total ratings: 168
Report this Post03-01-2020 04:38 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroMaster88
I’ll just leave these here.
FieroMaster88
Total ratings: 168
Report this Post03-05-2020 08:04 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Another video on the YouTube channel:
Rear engine shop on youtube
solotwo
Total ratings: 62
Report this Post03-05-2020 08:16 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Having owned a 3800 I can say you will want to compensate for the heat that engine makes. Some thing I learned is how many people dont check the supercharger oil. Have fun that whine is sweet and so is the power. LOL
FieroMaster88
Total ratings: 168
Report this Post03-21-2020 06:18 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Got everything hooked up on the 3800 swap. Cleaned up the wiring. Made an exhaust. Loaded the tune in the computer. Once the new ignition module shows up it will be ready for its first drive!
FieroMaster88
Total ratings: 168
Report this Post03-27-2020 05:29 PM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Washed the wide body. Have the exhaust together, have to finish weld and heat wrap it still. I got the tach and temp gauges working. I worked on the file for the pcm and got rid of all the transmission codes then programmed the pcm. Relearned the crank position sensor now no ses light. Took it for a ride around the neighborhood, runs great. Hopefully tonight I can finish weld and wrap the exhaust. Still have to wrap the wiring harness too. It’s about 95% complete!
ignorant prodigy
Report this Post03-28-2020 07:45 AM Click Here to See the Profile for ignorant prodigySend a Private Message to ignorant prodigyEdit/Delete MessageReply w/QuoteDirect Link to This Post
jeez man you work fast
nice job
CoolBlue87GT
Total ratings: 151
Report this Post03-28-2020 04:43 PM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice ! Shop & car came out great.
FieroMaster88
Total ratings: 168
Report this Post04-01-2020 12:22 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wrapped the wiring harness. Everything is working. The engine swap is done! Putting insurance on it this week so I can drive it. Another YouTube video coming soon.
FieroMaster88
Total ratings: 168
Report this Post04-09-2020 09:27 AM Click Here to See the Profile for FieroMaster88Send a Private Message to FieroMaster88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Been chasing a misfire, think I have it fixed. Should have a video up later today. I have a friend who does custom body work who’s helping with another project for this car.
