  3D printed sheet metal dies? Yes!
3D printed sheet metal dies? Yes! by seajai
Started on: 08-22-2019 09:23 PM
Replies: 18 (821 views)
Last post by: engine man on 09-08-2019 05:25 PM
seajai
Total ratings: 51
Report this Post08-22-2019 09:23 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently had to drop the fuel tank on my wife's 88 coupe. The clips that hold the A/C and heater lines in place were badly rusted and needed to be replaced, the only problem is nobody makes them.
What to do? 3D printing to the rescue. I took some measurements of the original clip and modeled it in Fusion 360.
I printed the model to check that it was going to fit.
There is an operation in Fusion 360 called "extrude to object", I used that feature to easily extrude a flat part into the positive and negative sides of the model to create a die set to make some new clips. By doing it this way, there is a gap designed into the dies equal to the thickness of the sheet metal blank.
I printed the die set in ABS plastic with a 70% infill and a 1mm top and bottom thickness.
I cut a blank from 22 gauge galvanized sheet metal, coated it in spray wax, and loaded it in the press. I really wasn't sure this was going to work, I thought maybe it would bend the metal a little bit and then the plastic would break. But to my surprise it worked great! The metal blank easily formed into shape without any damage to the plastic die.
So here is a pic of the new unfinished part next to the original piece. The locating tang isn't there but I think it should work just fine without it.
To finish the part I bent up the lip in my brake and drilled a hole for the screw. Here are a couple pics of the finished part next to the old ones.
Spadesluck
Report this Post08-22-2019 10:10 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's awesome, now make me some!
shemdogg
Report this Post08-22-2019 10:28 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats bad friggin arse man good stuff!
shem
Report this Post08-22-2019 11:58 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats awesome!
Good job!
pmbrunelle
Total ratings: 63
Report this Post08-23-2019 08:45 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wanted to do something similar, and I was debating if I needed steel or aluminium dies... apparently for one-offs plastic works too!
J Gunsett
Report this Post08-23-2019 08:58 AM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great job, I love 3D printers.
Jack
Sage
Total ratings: 69
Report this Post08-23-2019 10:04 AM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fantastic!
Have you been using the Fusion 360 for a while, or are you new to it, and either way, how difficult would you estimate learning it to be for a novice to CAD?
I know there's no way to gauge how quick/well somebody else is going to "pick up" a new software, as each of us is different and have different abilities and/or levels of comprehension, but I only asking for speculation.
Curiosity more than anything. Just seems the possibilities are fairly open, your post here kind of supports that. Great innovating on your part!
The entire 3D printing thing is more proof, (at least to me..) that "Today's science fiction is tomorrow's science." Wasn't all that long ago that just the concept of "3D printing" was nothing more than "science fiction".
Great job, thanks for documenting, explaining and posting.
HAGO!
sourmash
Total ratings: 50
Report this Post08-23-2019 10:33 AM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good application of skills and technology put to practical usage.
seajai
Total ratings: 51
Report this Post08-23-2019 11:06 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Sage:
Fantastic!
HAGO!
I've been using Fusion 360 for a couple years. The great thing about Fusion is that it's free to hobbyists and there are a lot of instructional videos on YouTube. I learned by following along with a 3 part how video for beginners put out by a guy named Lars Christensen. The video goes through modeling a simple rectangular electrical junction box and covers pretty much everything you need to get started. Lars works for Autodesk and has a YouTube channel where he does how-to and tips&tricks style videos.
Report this Post08-23-2019 04:27 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'll take some
Sage
Total ratings: 69
Report this Post08-23-2019 09:20 PM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info and taking the time to respond to questions.
Will check it out, though I'm very short on time available and they still tell me..."You can't teach on old dog new tricks!"
But hey....I DID used to be a "digitizer" LOL! :-D
HAGO!
Toddster
Total ratings: 504
Report this Post08-25-2019 11:23 PM Click Here to See the Profile for ToddsterSend a Private Message to ToddsterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not a problem here is California but a big winner for rust belt residents!
pmbrunelle
Total ratings: 63
Report this Post08-25-2019 11:39 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
How big was the sheetmetal blank?
Was it larger than the dies, and then you trimmed the excess?
Or, was the blank pre-cut to the size of the flattened surface?
Report this Post08-26-2019 12:46 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was over at Seajai's place this past weened. We replaced the dew wipes and window glass in a Fiero of mine. I also witnessed the production of a set of 4 of these stainless parts. They are very nice, I am now the first customer, as I bought a set of 4
[This message has been edited by 2.5 (edited 08-26-2019).]
Steel
Report this Post08-27-2019 10:32 PM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's pretty slick. nice work!
There's probably quite a few parts you could reproduce like that.
seajai
Total ratings: 51
Report this Post08-29-2019 12:31 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The brackets are now available in the mall. Can someone with an 84 - 87 Fiero let me know if the brackets are the same as the 88, or are they different?
https://www.fiero.nl/forum/F.../HTML/078036.html#p0
Reallybig
Report this Post08-29-2019 04:13 AM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dude, that's freakin awesome!!!
seajai
Total ratings: 51
Report this Post08-30-2019 12:02 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Made a short video of a blank being formed
engine man
Report this Post09-08-2019 05:25 PM Click Here to See the Profile for engine manSend a Private Message to engine manEdit/Delete MessageReply w/QuoteDirect Link to This Post
that's great
[This message has been edited by engine man (edited 09-08-2019).]
