  What specifically causes door glass scratches
What specifically causes door glass scratches by cam-a-lot
Started on: 11-18-2019 10:28 AM
Replies: 13 (513 views)
Last post by: da.slyboy on 11-22-2019 12:31 PM
cam-a-lot
Total ratings: 99
Report this Post11-18-2019 10:28 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello
Just had my dew wipes changed, and want to change my badly scratched driver side glass. It has the very common vertical scratches. I do have the new felt pads from TFS and am "assuming" this is the problem area, but am not sure. Can someone tell me why exactly the Fiero door glass scratches and what can be done to avoid it after replacing the glass with a new one
thanks
da.slyboy
Report this Post11-18-2019 10:55 AM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Biggest issues problem is dirt/sand getting trapped in the felts an wipes that can scratch the glass. Old rock hard dew wipes also will scratch the glass. Easy prevention is to keep the glass clean and I occasionally use a old toothbrush to brush the inner part of the dew wipes (window down) to remove any trapped dirt.
cam-a-lot
Total ratings: 99
Report this Post11-18-2019 11:29 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply, but I am not sure that is the main cause. I see one particular spot on most Fieros that results in vertical scratches in the glass- regardless of the condition of the dew wipes. Something inside is scratching the glass in a particular spot, and I want to figure out what it is
cvxjet
Report this Post11-18-2019 11:53 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Window guides on the INSIDE are capable of causing scratches also- They get dirt in them, and also the Felt wears thin. Sadly, you apparently have to cut the door structure to replace the guides. You can clean them a bit.......
Report this Post11-18-2019 05:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Outside "Felt" areas (2 of them) gets more crap that scratches ever when "dew wipes" are new.
Lower the glass some or all the way to get more space to clean the "Felt" parts. Try gently pull/push glass towards inside of car too.
I use a small wood/plastic stick to "comb" out crap when dry.
Wet makes most things stick even when you soap it here.
Mickey_Moose
Total ratings: 145
Report this Post11-18-2019 05:30 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope can be done without any cutting - been there and done that. Not easy but they can be changed out.
As for the OP - dew wipes seemed to be the issue with my car. Installed new wipes and glass. I keep the wipes clean and so far so good.
Quadfather
Report this Post11-18-2019 09:16 PM Click Here to See the Profile for QuadfatherSend a Private Message to QuadfatherEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is possible to remove the felts. You have to remove the glass first. Note: you must then reinstall the felts before reinstalling the glass. I have direct knowledge of this.
cam-a-lot
Total ratings: 99
Report this Post11-18-2019 09:27 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
So the consensus is that the felt pads wear our or catch dirt, causing the scratches? my glass will be getting changed anyway, so hopefully changing the felt pads will help?
[This message has been edited by cam-a-lot (edited 11-18-2019).]
Report this Post11-18-2019 11:49 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Outer felts are part of the dew wipes.
Inner felts can get dirty but often not you problem.
Inners need door cutting or window removed.
Many claim Dew wipes and outers can be replace w/o window removed but most times Window has other issues and best just remove the window and fix all problem at same time.
Like glass moves front/back/tilt moving up/down, slow PW motors often cause by crap/rust on the regulator parts, etc.
8t6fierogt
Report this Post11-19-2019 07:14 AM Click Here to See the Profile for 8t6fierogtSend a Private Message to 8t6fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
on my old 84, the dew wipes were really cracked and worn. the windows got scratched because of small rocks entering into that area. clean out the area with an air compressor.
1Packrat
Report this Post11-19-2019 11:36 AM Click Here to See the Profile for 1PackratSend a Private Message to 1PackratEdit/Delete MessageReply w/QuoteDirect Link to This Post
It will also help some if you WAX the glass. After replacing the windows on mine I do this each time I wax the car. Just know if you use windex it will strip the wax off.
Report this Post11-19-2019 05:52 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
May seem to help but waxes will get on anything touches the window then often hold dirt on them. About same problem as oil/grease on them but those "eat" many rubber/plastic parts.
Besides scratch problems, dirt on seals can let water in the door and cabin.
cam-a-lot
Total ratings: 99
Report this Post11-21-2019 07:15 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies
Just to recap, since my glass IS going to be replaced, and I have new dew wipes on now, and I am changing the felt guides (bought from Fiero Store), this should prevent the new glass from getting scratched- assuming I occasionally clean the dew wipes?
https://www.fierostore.com/...%20%20%204&d=360&p=1
da.slyboy
Report this Post11-22-2019 12:31 PM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, regular cleaning of window and felts will keep glass looking good for a long time. It always bothers me when I see 4 or 5 year old vehicles starting to develop window scratches/marks because they are never cleaned in general.
