Linked Bolt are for Only for Factory/ACDelco cables.
If used on Lead cable ends then very likely that bolt is Too Short and will cause problems. Wrong thread length will cause battery problems not covered by most warranties.
If old bolts are bad them very likely cables are bad too.
Your best bet is just get new cables.
Come w/ new bolts.
STANDARD MOTOR PRODUCTS A304D & A354D
ACDELCO 4SD30X & 4SD35X
Same part, standard is a bit cheaper.
Note: For these numbers... I think small wire is a Fuse Link. If true, Do Not Cut It. Splice w/ wire to box under C500 and coat w/ the joint w/ brake or silicone grease.
Might find thru amazon.co.uk cheaper then rockauto
See my Cave,
Wire Service battery cables
