  New to Fieros, need guidance
New to Fieros, need guidance by Modesto
Started on: 04-09-2020 04:39 PM
Replies: 16 (414 views)
Last post by: Modesto on 04-10-2020 12:30 AM
Modesto
Report this Post04-09-2020 04:39 PM Click Here to See the Profile for ModestoSend a Private Message to ModestoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Picked up my first Fiero yesterday!
'88 5 speed with 57k and will look nearly new after a solid detail and some paint touch up. I got it relatively cheaply because it makes a thump thump thump sound when you have the clutch pushed in and its idling. It came with a binder full of receipts outlining maintenance and upgrades, and I noticed a "kevlar racing clutch kit" was installed around the same time as the KYB suspension (about 20k ago). Could the higher pressure clutch have anything to do with it?
The seller thought it was either the TO bearing or the thrust bearing, so if I have to pull everything apart am I better off (from a value perspective) keeping it stock or doing a L67 swap? If the answer is L67, do I need wider tires to really take advantage of the power increase? I've got a few other questions but that is probably a good start. I appreciate any input, thanks!
Spadesluck
Report this Post04-09-2020 04:49 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
My opinion would be fix the problem you have and enjoy the car before swapping motors. Once you start that process it may never end and then you wont be driving a nice car. Just put some new tires on the stock rims, that will be plenty enough to drive that car around.
Modesto
Report this Post04-09-2020 04:58 PM Click Here to See the Profile for ModestoSend a Private Message to ModestoEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I'm inclined to do, but the seller felt like for as much work as pulling everything is no one would want to do it twice. Say it is one of the bearings, are we talking a 10 hour job or a 40 hour job? I've got a decently equipped garage and am somewhat experienced (body swaps, motor swaps, etc.).
Report this Post04-09-2020 05:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it make the "thump thump thump sound" as soon as you put any pressure on the clutch pedal... or does it require pushing the pedal to the floor?
Do you have to push the clutch pedal to the floor to disengage the clutch?
Where I'm going with this is I'm wondering if the clutch is simply being disengaged too far. This is possible with a Getrag 5-spd.
Fiero Vampire
Report this Post04-09-2020 05:12 PM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it was me, I would fix the current issue and clean up the interior, dropping the engine and transmission is a job, but no where near what your going to dig your self into if you go with an engine swap, plus it would familiar yourself more with the car, I myself currently have two Fieros one I'm doing a swap on and the other basically stock, the stock one has been way more enjoyable than the on-going swap/rebuild one, but that said everyone is different and it's just my two cents.
Modesto
Report this Post04-09-2020 05:33 PM Click Here to See the Profile for ModestoSend a Private Message to ModestoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its seems to only do it when I push it to the floor and the clutch will disengage before then, but I haven't driven it enough to get a exact feeling of when it releases.
Yeah I've had enough stalled projects to have the same experience. If I were to do it I would take a few weeks to plan it out and gather all the necessary parts, then try and knock it out over a couple weekends/nights. The longer things sit the more comfortable we get with them sitting a little longer...
Report this Post04-09-2020 05:39 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You don't even need to be driving the car to figure this out. While the car is sitting with the engine idling, how far does the clutch pedal need to be pushed in until you can easily shift the tranny into gear? Is the "thump sound " being produced at this point, or do you have to push the clutch pedal in further to produce that sound?
Modesto
Report this Post04-09-2020 06:12 PM Click Here to See the Profile for ModestoSend a Private Message to ModestoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm so the I can shift easily up and down with the pedal halfway down, though I really have to muscle it left to right when going into 1st or reverse. It does have a short throw shifter. I took it for a pretty decent drive but I couldn't get it to make the thumping noise like it did at one point yesterday. There is a very, very slight tick as soon as you depress the clutch and the RPMs dip 100 or so.
Report this Post04-09-2020 08:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the select cable... which is notorious on the Getrag for becoming corroded inside the cable. Rodney Dickman sells a very good replacement.
...but I couldn't get it to make the thumping noise like it did at one point yesterday.
So, bad news that you don't need to pull the tranny?
Could be any number of things. Lifter... cracked exhaust manifold...
Modesto
Report this Post04-09-2020 08:21 PM Click Here to See the Profile for ModestoSend a Private Message to ModestoEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's so odd because I couldn't really notice anything at the beginning of the test drive yesterday, then when I went to pull out to drive it home after paying it was a very audible thumping but didn't notice it again the 65 mile drive home (though it was almost entirely interstate). I guess I'm good to drive it until it starts thumping again? He claimed it did it after it warmed up the entire time he owned it, which was 5 years but under 2000 miles...
Thanks for the tip on the cable, sound like that's exactly what my issue is. The tick is really soft and I have to roll down the window and lean my head out to hear it. It's just weird because it's only when the clutch is engaged.
So I'm assuming for $2800 I did ok then? If in the future I decide to do the L67 swap, is that going to help or hurt the value of the car? Thanks for all the help so far, you guys and this forum are a life saver!
Report this Post04-09-2020 08:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is a very, very slight tick as soon as you depress the clutch...
Which is it... when the clutch is engaged or disengaged?
If it's while engaged in neutral, then it's probably the infamous Getrag rattle.
Modesto
Report this Post04-09-2020 08:51 PM Click Here to See the Profile for ModestoSend a Private Message to ModestoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, the way I worded that is super confusing. It's when depress the clutch pedal.
Report this Post04-09-2020 09:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, it's not the infamous Getrag rattle then.
Thunderstruck GT
Total ratings: 99
Report this Post04-09-2020 10:23 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
6848 1988 GT's built.
After total losses, poor '88 GT's getting cobbed up with backyard mods or mods in general, kit cars, customs and just plain worn out, there probably can't be 1/2 left.
I say keep it stock. It will be a much better and desirable investment.
Modesto
Report this Post04-09-2020 10:42 PM Click Here to See the Profile for ModestoSend a Private Message to ModestoEdit/Delete MessageReply w/QuoteDirect Link to This Post
It does seem a shame to molest such a good stock example, and honestly its plenty quick for me, I would probably just get myself in trouble with more power. I'd be interested in dynoing it at some point just to see what makes it to the wheels.
I took it out again and got it to do it. I then had my wife press the clutch while I listened to the engine bay. The sound seems to be coming about 2/3rds up the engine as you come away from the transmission. I'll pick up a stethoscope tomorrow to get a better idea. It got to where the sound was there all the time idling, but got louder if you so much as rested your foot on the clutch pedal. I would say its more of a tick with maybe a soft knocking quality when you are standing next to the engine. What does that tell us?
PS. I took I short video but I don'y know how to post it here.
Edit: I'm going to start a thread in the tech section about this issue, but I'm glad to hear more opinions on the stock vs L67 front.
[This message has been edited by Modesto (edited 04-09-2020).]
Notorio
Report this Post04-09-2020 11:45 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
For a 50K mile 88GT with only minor issues I'd say you got a steal. If you search the forum you will find many L67 threads with swap cost and time estimates so you can get an idea what you'd be facing. There's a wide range due to different approaches, goals, skill sets, and budget. If it was me I'd fix and enjoy This Fiero and start planning to get a second one someday for the L67 swap. Better yet, you can consider swaps with newer motors since L67s are getting old and hard to find. Which ever swap path you choose for the long-term you can at your leisure amass parts and technical info so you can get fully prepared, and still enjoy driving a rare low-mile 88 that will turn heads (even if it is slower than 90% of the new cars on the road today.) Just my tire-kicker 2c ...
Modesto
Report this Post04-10-2020 12:30 AM Click Here to See the Profile for ModestoSend a Private Message to ModestoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good thoughts, and it is getting really hard to find low mile L67s.
