  My Fiero Project
My Fiero Project by raichuisfat
Started on: 04-18-2020 08:20 PM
Replies: 4 (164 views)
Last post by: steve308 on 04-19-2020 10:04 AM
raichuisfat
Report this Post04-18-2020 08:20 PM Click Here to See the Profile for raichuisfatSend a Private Message to raichuisfatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well..it's here. 1984 Pontiac Fiero 2M4. 4 speed manual, manual windows, no adjustable steering column..which is a bummer since I'm a bigger person but that's fine.
It needs work..quite a bit of work..fuel line leak, clutch isn't working right, and also the brake caliper needs replacing. New paint too probably. I'm unsure how long this will take, since i have to start from essentially nothing. I will keep you guys updated and hopefully..get some help?...I'm unsure. But I am very happy
[This message has been edited by raichuisfat (edited 04-18-2020).]
Modesto
Report this Post04-18-2020 08:42 PM Click Here to See the Profile for ModestoSend a Private Message to ModestoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gotta love a new project! Good luck, I've really enjoyed mine in my whole two weeks of ownership.
RCR
Total ratings: 102
Report this Post04-18-2020 08:55 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to both of you...
Bob
My Build
pmbrunelle
Total ratings: 63
Report this Post04-18-2020 10:31 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like you have a lot of work to do!
Regarding the steering column, Fieros used the GM Saginaw column that was used in zillions of cars of the era.
I think you should be able to find a suitable tilt column and install it into your Fiero, if you really wanted to.
I don't know much about the steering columns... some other members such as (but not limited to) theogre may be able to fill you in on the details.
steve308
Total ratings: 57
Report this Post04-19-2020 10:04 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Suggest you check out you tube. There is a guy who has rebuilt / restored a FIERO and has a mulit-part series on the steps he has taken. It is very well done.
The you Tuber is Ronald Finger --- Fiero Revival (85 2M4)
[This message has been edited by steve308 (edited 04-20-2020).]
