  RX-8 Electric Power Steering Rack Swap into 1988 Chassis , Invisible!
RX-8 Electric Power Steering Rack Swap into 1988 Chassis , Invisible! by anaverin
Started on: 10-05-2020 02:22 PM
Replies: 36 (3029 views)
Last post by: Will on 01-06-2025 08:54 AM
anaverin
Report this Post10-05-2020 02:22 PM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, We have been using West coast fiero's Saturn vue power steering kit. As anyone who has done this swap knows, it kind of interfers with footroom. Given my Client 's is in his 70s, he has an even harder time getting in and out of the car. So we did some research and found that this 2007 Mazda RX8 EPS rack has the motor contained in the rack, and the rack is approx the same 24 inch length between the inner tie rods in the center.
We then made plastic pieces to mock up how we would make the brackets to hold it, and we came up with this design that we had waterjet just out of 1/4 steel.
I got the steel parts back from water jet and tacted them into place. You can see the old Bracket on the Driver side gets repurposed, and the passenger side one gets eliminated.
Here is what we have so far. I am going to explore controlling it with the Saturn EPS controller. Will update when i know more.
86 SE FASTBACK T-TOPS
88 FORMULA 4.9
87 GT MEDIUM RED METALLIC stockish
EMAIL : Anaverin@gmail.com
[This message has been edited by anaverin (edited 10-05-2020).]
Spadesluck
Report this Post10-05-2020 04:45 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Watching, looks very interesting.
Rickady88GT
Total ratings: 200
Report this Post10-05-2020 06:31 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I love the idea of an electronic assist rack. If I do any more power steeing systems in a Fiero, I will look into an electric rack. I am not sure about the electronic controls of it tho.
I will keep an eye on this thread.
Thanks
pmbrunelle
Total ratings: 63
Report this Post10-05-2020 06:36 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have questions about that, I know a thing or two about EPS.
You can always post pics of the connectors and where they go, and we can attempt to figure things out.
anaverin
Report this Post10-05-2020 09:34 PM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am just wondering if i can use the Torque sensors in the Mazda rack, (which i have all the factory service information for) and soder them into the saturn controller. Alternatively I could modify the mazda controller to work, but since we already have the saturn controller working, i would like to try that first. I am going to ohm out the sensors on the saturn rack, to see if they are similar to the 14 ohms of the mazda sensors.
Rest assured though, after spending money on getting waterjet cut parts, I will be figuring out a way to make this work!
thank you for your interest, i will try to upload the service manual stuff for the mazda in case you are curious. I have actually done more research then i was able to convey with the post.
pmbrunelle
Total ratings: 63
Report this Post10-05-2020 09:51 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the Mazda controller already normally works with the Mazda motor and the Mazda torque sensor, then it seems like it would be easier to work with the Mazda controller, but that's just my first impression.
To make the controller work, it needs to think it's in the Mazda. I think it would be easier to make the Mazda controller believe the lie that it lives in a Mazda. This would be telling it the proper lies via the CAN bus.
The other choice is to make the Saturn controller work with "major organ transplants"... the thing is that the Saturn controller can't reject its new friends!
anaverin
Report this Post10-05-2020 10:15 PM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess i am concerned about the mazda controller wanting to talk to the pcm via can bus. The Saturn controller has already been rigged to work via a dial that is nicely installed into the AUX pod. The owner would like to keep that if possible. As far as usability goes, the setup is amazing other then the motor intruding into the footspace and looking ugly. We will see how this goes. Anything is possible, but we will be working until the solution is satisfactory.
anaverin
Report this Post10-06-2020 12:06 AM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
First tests are as follows:
Mazda RX8 TQ Sensor at rest =12 ohms
Saturn TQ Sensor at rest = 5 ohms
currently we use the PWR Steering at less then 50 % assist on the Dial. So being that 12/5= 2.2 maybe that means that we would get the same assist (assuming the motors draw equal power, which is a big if) at 110% on the dial. We will be doing some practical experiments this week but farther research indicates that it has proven very complex to replicate the Can signals needed to make the RX8 module work. so for now, we will be trying to make the saturn module (which is a Denso / KOYO product anyway ) work. will let you know how it goes.
[This message has been edited by anaverin (edited 10-06-2020).]
anaverin
Report this Post10-06-2020 03:08 AM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
anaverin
Member since Aug 2002
Welded everything up, and painted it tonight.
Total ratings: 236
Report this Post10-06-2020 08:45 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you going to be checking for bump steer?
pmbrunelle
Total ratings: 63
Report this Post10-06-2020 12:53 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Huh, cool.
If both torque sensors are variable-resistance output, that could be plug-and-play.
Usually what works to get up and running (at least half the time) is to simply record the CAN bus traffic of an idling vehicle onto a PC (using a CAN to USB interface). If you play back the recording, oftentimes that's enough. If you're lucky, you can sit in someone's idling car and get a recording from the OBD-II port.
Then, to determine which CAN messages are essential, you play back the CAN trace, but with one less message each time. Once you're at the point where taking away any single message causes the EPS to stop functioning, you know you're at the bare minimum.
Getafix
Report this Post10-07-2020 08:20 PM Click Here to See the Profile for GetafixSend a Private Message to GetafixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump steer is not an issue, measurements of '88 and RX-8 racks are nearly identical, no more than 1/8" different, if at all.
Getafix
Report this Post10-07-2020 09:14 PM Click Here to See the Profile for GetafixSend a Private Message to GetafixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Getafix
Member since Aug 2016
Here are the patterns for the water jet service to make the parts for the RX-8 mounts.
NOTE that the bolt holes in the Part 1 graphic ARE NOT to size, so only a pilot hole, maybe 1/4" dia, should be water jet cut.
[This message has been edited by Getafix (edited 10-07-2020).]
Getafix
Report this Post10-07-2020 09:25 PM Click Here to See the Profile for GetafixSend a Private Message to GetafixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Getafix
Jig for aligning the mounts for the RX-8 EPS to the '88 Fiero suspension. Two 1/2 aluminum "L" rails with alignment jigs are taped into place. Those jigs locate the notches in parts 2, 3, and 4. After those parts are tack welded into place, the "L" rails are removed and the two parts 1 are tack welded onto the parts 2 (x2) and parts 3+4. The part 1 that has the 1/4' milled out goes onto parts 3+4 with the "milled" relief facing up to clear the RX-8 EPS.
Getafix
Report this Post10-08-2020 06:32 PM Click Here to See the Profile for GetafixSend a Private Message to GetafixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Testing RX-8 EPS with temporary connection to Asterix. Yay, It works! Now to create the harness, Alex is up to it!
https://www.facebook.com/br..._processed&ref=notif
[This message has been edited by Getafix (edited 10-08-2020).]
Rickady88GT
Total ratings: 200
Report this Post10-09-2020 12:38 AM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
awesome
RCR
Total ratings: 102
Report this Post10-09-2020 07:50 AM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome work. I did not realize it was capable of steer by wire, or am I missing something in the video.
Bob
anaverin
Report this Post10-09-2020 02:16 PM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
All EPS racks provide assistance when they get steering input which would cause them to seem like steer by wire if they were getting their steering input from a wheel not connected to the steering shaft.
pmbrunelle
Total ratings: 63
Report this Post10-09-2020 06:08 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suppose that both setups (Mazda and Saturn) use a 2-wire DC motor. This is easy to interface compared to a 3-wire motor.
[This message has been edited by pmbrunelle (edited 10-09-2020).]
anaverin
Report this Post10-10-2020 12:45 AM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
CORRECT!
anaverin
Report this Post10-27-2020 05:17 PM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Working on the mods for putting 88 suspension into the 86, so that is what is holding us up. We took a lot of pictures so let us know is we need a separate thread about that.
da.slyboy
Report this Post11-06-2020 01:41 PM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a great idea...Now about those ideas that include the more common 84-87 cars
anaverin
Report this Post11-12-2020 12:21 AM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I MEAN techically we are putting 88 front suspension into an 86. So i guess it is a mod for an 84-87 fiero
Iain
Report this Post11-12-2020 10:52 AM Click Here to See the Profile for IainSend a Private Message to IainEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would you know what ratio is in the RX-8 rack?
cheers, iain
anaverin
Report this Post11-12-2020 01:05 PM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
i'm told it 16:1 but, it seems to be able 2.5+ turns lock to lock iirc.
Next up we needed to modify the column to add the torque sensors ONLY, which should not interfere with footroom, making the entire project viable.
I started by using the guide in https://www.fiero.nl/forum/Forum2/HTML/138106.html and then modified the process so we just cut at the collar instead of disassembling the entire column. It should be noted that we also cut down the length of the torque sensor input spines, but the new length has the same amount of bite , just allows for less collapse. So i guess, don't get an accident where you need full column collapse.
[This message has been edited by anaverin (edited 11-12-2020).]
anaverin
Report this Post05-26-2021 01:57 AM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
just a heads up... this is in the car and working well. It isnt very picture impressive though being under the car and the column being hidden. Feel free to ask questions. Alot of the RX8 guys doing Ls swaps want to know how we did it. I have walked a few of them through it.
Australian
Report this Post05-26-2021 09:29 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sweet be interested in your road test.
predmeister
Report this Post05-29-2021 06:31 PM Click Here to See the Profile for predmeisterSend a Private Message to predmeisterEdit/Delete MessageReply w/QuoteDirect Link to This Post
kit??
fireboss
Total ratings: 58
Report this Post05-29-2021 08:34 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by predmeister:
kit??
Report this Post05-30-2021 09:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It should be noted that we also cut down the length of the torque sensor input spines, but the new length has the same amount of bite, just allows for less collapse. So i guess, don't get an accident where you need full column collapse.
People don't generally get a chance to choose the circumstances. I don't know if it's such a good idea to be reducing the effectiveness of an important safety feature... but as long as everyone knows what they're up against. And hopefully not literally!
[This message has been edited by Patrick (edited 05-30-2021).]
ricreatr
Report this Post08-29-2024 10:15 PM Click Here to See the Profile for ricreatrSend a Private Message to ricreatrEdit/Delete MessageReply w/QuoteDirect Link to This Post
read this 4 times, and i think i have figured out what you did. You are using the vue p/s column with the motor cut off or removed to use just the sensors. Still using the vue module, also using the vue adapter module, then running the rx-8 rack with the vue module. not using the rx-8 sensors at all.
yes?
(what is asterix)
and you have been running this on the track? liking how it feels?
Report this Post09-05-2024 11:40 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting post and I admire your fabrication skill mod work but you'd have to be pretty weak not to be able to steer a Fiero.
ricreatr
Report this Post09-06-2024 10:05 PM Click Here to See the Profile for ricreatrSend a Private Message to ricreatrEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Dennis! You have plenty of projects to be proud of yourself!
This has been discussed plenty in these p/s threads. Agreed, it is not really needed. Wouldnt want the weight/complexity on my dd.
But i want more control while pulling a hard corner with sticky tires, using a faster ratio rack, and a smaller diameter wheel. It would help.
Would love to know how they did it.
da.slyboy
Report this Post09-07-2024 12:11 AM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
While there are two sides to the steering strength argument. Everyone has to agree they’ve been in the position like I was this evening trying to back out of a packed and narrow parking lot with just about a car length and 2 feet of room from a truck behind me. Took about a 4 point turn around to get out and would have welcomed a little assistance with my 17” wheels/tires. Not all instances of turning the wheel happen while moving.
Report this Post09-07-2024 08:54 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't misunderstand me. The OP's fabrication skills and work are super nice and he deserves compliments that I will give him. I'm not putting it down. I just feel for my type of driving the need was never there for controlling 40% of the weight in the front. I could be mistaken but when drag racing, I've always felt manual steering gives you more control not less but let me end it here and just say this a great project and an interesting thread, .
xetura
Report this Post10-07-2024 01:01 PM Click Here to See the Profile for xeturaSend a Private Message to xeturaEdit/Delete MessageReply w/QuoteDirect Link to This Post
After seeing all the options, I think this is the way I want to go. But my Fiero is an 86, so I'm not sure the difference in the steering rack mounts on an 86 vs an 88.
Total ratings: 236
Report this Post01-06-2025 08:54 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Slow steering hurts track driving. Speeding up the steering to 2.0 turns lock-to-lock makes the effort go up significantly. Power steering is needed when going to a faster ratio.
AND going lock-to-lock while stationary executing a multi-point turn in a parking lot is nuisance.
And... Some people just want to do things to their cars that are different than yours. Get over it.
