  Dropping a Fiero
Dropping a Fiero by skywurz
Started on: 11-29-2020 06:22 PM
Replies: 12 (390 views)
Last post by: skywurz on 12-06-2020 09:22 PM
skywurz
Report this Post11-29-2020 06:22 PM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Am I doing it right?
Report this Post11-29-2020 07:03 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
After you're crushed, can I have that hydraulic jack?
skywurz
Report this Post11-29-2020 07:17 PM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
What happened was.. Well it failed the shake test. My suv stands are more flat on top than id like leading to them to like to slip. I only use them on the Fiero when pulling a cradle. When I get them in place and the jack lowered i like to do a shake test to make sure its all good... Im thinking i should stop doing it this way because this isn't the first time they slipped ¯\_(ツ)_/¯
pmbrunelle
Total ratings: 63
Report this Post11-29-2020 07:57 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since you were able to take the picture afterwards, doesn't look like it went so badly!
Total ratings: 463
Report this Post11-29-2020 08:14 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
^ ^ ^ This! ^ ^ ^
But I'll bet it made some noise.
skywurz
Report this Post11-29-2020 09:23 PM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
^ ^ ^ This! ^ ^ ^
Ha yeah it went something like: a subtle thunk, followed by the sound a tree makes as it goes over, then the sound of me getting hit in with a jack handle while you hear the top section of the stand clattering across the ground with a loud tinging clatter, lastly a loud thunk as it hits the ground!...
Then my thoughts were.. well i dropped it.. is it going to fall more (as the stand that was left was cocked at a good angle) then i was like oh i dropped it this will make good word play IE lowering/dropping... Like suspension?.?..?
*Shows himself out*
Spadesluck
Report this Post11-29-2020 09:42 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
oops
Report this Post11-30-2020 08:05 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Place an 8 inch length of 2x4 between the jack and the chassis. Both the chassis and jack gouge into it and keeps things from slipping.
Not a fan of the jack lift technique for this very reason. Had you used a cherry picker, lowered it an inch and then did the shake test, the car would still be supported and be far less dramatic.
skywurz
Report this Post11-30-2020 11:08 AM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im Skywurz being overly dramatic is what I do.
Yeah the Cherry pucker was only 10ft away. I typically use it on my keepers where im being much more careful not to do horrible damage. Having stands that are extended 2ft in the air with sloppy tolerances doesn't help the safety of the jack method. I had used it last month because the picker was gone. This method seemed to work fine...ish..
cvxjet
Report this Post11-30-2020 12:01 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I do a shake test too...But I A) keep the jack close (1/8") so if things start to go wrong the jack can catch it, and B) I don't weigh a bunch so my shaking isn't that bad.
Story from 1980s; A fellow Aircraft mech at NAS Alameda (Who was also a Preacher) was working on his RV...He used CAR stands.....That was his final mistake.
Please be careful...and definitely be able to laugh at your own mistakes......(I have a LOT to luagh abuot!)
coolink13
Report this Post12-06-2020 01:18 PM Click Here to See the Profile for coolink13Send a Private Message to coolink13Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am glad your safe.. But you are correct. That is not the best way to do it. I am sure at this point you will be doing it differently. Was this your attempt of removing the cradle??
dremu
Report this Post12-06-2020 05:28 PM Click Here to See the Profile for dremuSend a Private Message to dremuEdit/Delete MessageReply w/QuoteDirect Link to This Post
Back when I had a lifted 4x4 truck, there was an incident in which I forgot to set the parking brake and it rolled right over me when I disconnected the driveshaft.
Thankfully on 37" tires there was lots of ground clearance, so it just rolled right past me, leaving me looking up at the sky ... and then slowly into the shed.
Truck obviously was unharmed, shed was largely repairable.
My ego, on the other hand...
-- A
[This message has been edited by dremu (edited 12-06-2020).]
skywurz
Report this Post12-06-2020 09:22 PM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah other times i just think certain cars are cursed and or don't like you.
"Dropped" the cradle today too
I promise this isn't my first rodeo this car is cursed.
