  Help with rims and tires..
Help with rims and tires.. by Easy8
Started on: 07-21-2021 11:07 PM
Replies: 5 (425 views)
Last post by: Easy8 on 07-25-2021 07:34 PM
Easy8
Report this Post07-21-2021 11:07 PM Click Here to See the Profile for Easy8Send a Private Message to Easy8Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I am looking to replace my current rims, the car has coilovers on the rear as well as big brakes. I am looking at these
https://www.summitracing.com/parts/KNG-MY8851043R
So for an off set rim size uneducated.... am I looking at failure or will these work?
IMSA GT
Total ratings: 253
Report this Post07-21-2021 11:28 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll let more people chime in but if my math is correct, those should fit just like the stock 15" wheels.
Edit to add......assuming this is NOT a 1988?
[This message has been edited by IMSA GT (edited 07-21-2021).]
Australian
Report this Post07-22-2021 06:10 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't imagine being a great look once they are on have you ever seen them on a car? Show off crappy brakes.
cvxjet
Report this Post07-22-2021 12:30 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
They may fit but; I had some relatively heavy 15" aftermarket wheels on my car from 1990 thru 2007....I was looking for good performance tires and couldn't find anything for 15" wheels....So, i decided to move up to 16s...But I had recently read an article which really emphasized the problems of un-sprung weight.
I did some research and found some great wheels (16 x 7 VOXX Monza) that were lighter than my 15s....I also went with General G-Max tires which are very highly rated All-Season performance tire....They were a few lbs lighter than my previous BFG Comp TAs.
I reduced the weight at each front corner by 6 lbs and 3 lbs at each rear...Doesn't sound like much but the difference in feel on the car was amazing. The car road and handled better (Not talking traction- Talking the feel)....And the straight-line performance was very obviously better.
Moral of the story; It is well worth your time and effort to try to find the lightest wheels for your Fiero- Modern cars have fancy electronic shocks, aluminum suspension, etc to help them deal with the huge wheels they now must put on them for "Style"...The Fiero suffers very badly by going to a very heavy wheel/tire setup.
Total ratings: 461
Report this Post07-23-2021 11:31 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wheel Size:
18x8
Offset:
+43.00mm
It's quite possible that the inside lip will hit some of the machinery. (Struts, control arms, etc.)
Try to find something with a 35mm offset. I'm pretty sure those will fit.
Edit - Sorry. I missed that you have coilovers. That will help. What year is your car? Is it lowered?
[This message has been edited by Raydar (edited 07-23-2021).]
Easy8
Report this Post07-25-2021 07:34 PM Click Here to See the Profile for Easy8Send a Private Message to Easy8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Raydar:
Wheel Size:
18x8
Offset:
+43.00mm
It's an 86, with stock ride height. The car currently has MSR 20'S with 245/35 tires. I am not sure of the offset on these rims (I did not install them) it also has Vet/Viper brakes. So small rims are out of the question.
[This message has been edited by Easy8 (edited 07-25-2021).]
