  Modified tail lights
Modified tail lights by LornesGT
Started on: 10-04-2021 06:31 PM
Replies: 14 (660 views)
Last post by: kendell on 10-11-2021 11:18 PM
LornesGT
Report this Post10-04-2021 06:31 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trying different look out, using diodynamics.com halos. Black tape to cover portions of the halos and I am not leaving the left side white and probably a light tent to the lense. I didn’t want to waste paint yet. I wish I could get my 3d printer to work properly so far using 3x2 pvc reducers.
[This message has been edited by LornesGT (edited 10-04-2021).]
LornesGT
Report this Post10-04-2021 11:01 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kinda boring without a video. Duh.
[YOUTUBE] https://youtu.be/2BsxBF4XF1c [/YOUTUBE]
[This message has been edited by LornesGT (edited 10-10-2021).]
Report this Post10-06-2021 11:01 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Nice, if I were to mod GT tails thats how I'd do it, (all under a stock lens).
MichiganReefer
Report this Post10-06-2021 01:31 PM Click Here to See the Profile for MichiganReeferSend a Private Message to MichiganReeferEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm just starting to restore and build my 88GT and wanted to do something very similar to this. I've wanted the Pontiac to remain in the middle and do infinity taillights, two on each side. Could you share how you did this? Could you share and dimensions or specs of things that you used?
MichiganReefer
Report this Post10-06-2021 01:33 PM Click Here to See the Profile for MichiganReeferSend a Private Message to MichiganReeferEdit/Delete MessageReply w/QuoteDirect Link to This Post
MichiganReefer
Member since Sep 2021
IMSA GT
Total ratings: 253
Report this Post10-06-2021 06:41 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sent you an email.....
Report this Post10-08-2021 11:52 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here is what one Fiero guy did
https://www.youtube.com/watch?v=JZuGoKwx8ek
Check out his youtube channel GARAGELESS
I see him at Fiero events form time to time.
[This message has been edited by 2.5 (edited 10-08-2021).]
LornesGT
Report this Post10-10-2021 12:05 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm just starting to restore and build my 88GT and wanted to do something very similar to this. I've wanted the Pontiac to remain in the middle and do infinity taillights, two on each side. Could you share how you did this? Could you share and dimensions or specs of things that you used?[/QUOTE]
So far I have a pvc sheet 1/8” thick that replaced the original reflectors, they were is sad shape. I manage to get a second set in case I didn’t like the out come. I cut that to shape ( I will get a picture tomorrow) and adhered that in with a temporary adhesive. I am still trying different idea so nothing is permanent yet. I have projector headlight lenses in the center behind them is addressable LED halos and controlled by a BlueGhozt controller. Outer ring is diodynamics halos which can be cut but I don’t think I will because I believe I want the look off the smaller one on the left side. They can’t be cut multiple time just enough to take a section out. They are super bright and I start seeing double after awhile since I want to decide the look as they are lit. The fixture to hold them is currently drain fittings 3X2 with another reducer to hold the inner addressable LED halo. I will take more pictures tomorrow. I would like to order new custom lenses when finished and also have a matrix of LED’s behind the Pontiac if I don’t make changes to that. Thanks for the compliments, this has been many hours of deciding and testing. I just took them apart this evening to make a small change. I will post a video of that as well.
https://www.diodedynamics.c...halo-rings-pair.html
BlueGhozt.com
LornesGT
Report this Post10-10-2021 12:31 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
LornesGT
Member since Jan 2013
Picture I had already taken at the start with ABS sheet that was hard to shape. Also my fog light on the skitime bumper. I can’t get my 3d printer to print properly, I think due to the slicer program to print my housing for the lights. I need them a little smaller than the PVC drain fitting.
Photo shop from a Mazda 3 but I decided I didn’t want to replicate it. I do want to put the Pontiac emblem in the center somehow and light it up around it.
LornesGT
Report this Post10-10-2021 12:53 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
LornesGT
You will find the current addressable LED such as in the video above are not bright enough for all day light viewing or legal but you could swap out for shows. The projector lenses in front of mine definitely helps. I also have some day time running light I want to use for revere light but they just too bright and I may place them in the bumper so they go downward and don’t blind people.
LornesGT
Report this Post10-10-2021 11:32 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
LornesGT
More pictures. The Black housing LED is from TRS and I hope to place it behind the projector lens but it has a hot spot. I need some kind of diffuser. Different reducing fittings to hold the addressable led halos.
https://www.theretrofitsour...-M-MODPOD?quantity=1
Cut out this part
Installed 1/8 pvc sheet and adhesive to mount PVC fitting. The adhesive is easy to get loose to make changes.
Smaller LED halo behind the projectors but still washed out from daylight.
LornesGT
Report this Post10-10-2021 12:07 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
LornesGT
Try to embed
Just closed the garage door.
Combined effect of two halos and projector. I like it.
Total ratings: 328
Report this Post10-10-2021 10:33 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
While your creativity is admirable and you do nice work, I do not believe those tail lights are D.O.T. street legal. I would check with your local jurisdiction in Illinois and see if state inspection or motor vehicle laws will approve those.
LornesGT
Report this Post10-11-2021 05:53 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am quite certain they are not DOT approved. I doubt any of the modifications would be to lighting that many have done.
kendell
Report this Post10-11-2021 11:18 PM Click Here to See the Profile for kendellSend a Private Message to kendellEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's one interesting project!
