  The story of two 2+2 Fieros:
The story of two 2+2 Fieros: by Midwest Fiero Clubs
Started on: 01-17-2022 01:55 PM
Replies: 17 (927 views)
Last post by: FIERO JOHN-WI on 01-27-2022 09:01 AM
Midwest Fiero Clubs
Report this Post01-17-2022 01:55 PM Click Here to See the Profile for Midwest Fiero ClubsClick Here to visit Midwest Fiero Clubs's HomePageSend a Private Message to Midwest Fiero ClubsEdit/Delete MessageReply w/QuoteDirect Link to This Post
"The chassis of the car started out as two of the very first pilot build Fieros built in January of 1983. All of the pilot build cars with the exception of the very first car built were virtually destroyed at Milford Proving Grounds in preparation for the production car build anticipated in July of 1983. The front half of the 2+2 is verified as pilot build Fiero #009. The back half, I have not been able to verify which car it might be, but it does have the early design spaceframe strut mounts that were changed in the months between pilot build and production start. The stretch in the frame was accomplished by cutting one car just after the door frame at the b-Pillar and cut the other car just before the cowl. The problem with the 2+2 is that the car was intended as a design study and not a car to be driven per say on the street. The frame joints are pop riveted together with plates and a couple of small tack welds in the corners. The car has a lot of flex in the frame and is actually quite fragile. After the car was built in the original notchback form, it made its rounds in 1984 as a show car for Pontiac and once its useful lifecycle was over, it went to the Pontiac Special Vehicle Collection.
When it came time to start defending the cancellation of the Fiero (yes, the battle to cancel the Fiero started in 1986), one of the brainstorm ideas was to restyle the old 2+2 to the current GT Fastback model to show the options of the flexibility of both the spaceframe and the body panels. The original 2+2 had already been placed on the Special Vehicle Collection Purge list to be destroyed when the guys grabbed it to use for the new design.
The car was sent to AutoFab, a outside prototyping service provider used by Pontiac for special projects where the old body work was removed and the clay modeling was formed right on the stretched chassis. Once the first clay model was finished utilizing a stock fastback rear clip, the designers realized that the stock B-Pillar was too tall and wide to have a continuous flowing arc across the roofline down the side buttresses to the taillights. An extensive modification was made to the B-Pillar to allow the proper lines of the bodywork. A second clay mock-up was made on the modified stretched spaceframe that resembles a fastback Fiero but is dimensionally completely different than a stock fastback Fiero to make the proportions look correct with the added 18" of frame stretch. A mold was pulled from the clay model and the entire upper roof section from the cowl to the tail lights was made in one piece. Once the body was finished and painted, the new custom interior was made and 16" wheels intended for future Fiero GT"s were fitted. Once the car was finished and on the ground, the front suspension was too tall. The quick last-minute fix was to tie wire the front springs together to bring the car down to the best ride height. The car was then presented for corporate review at the GM Tech Center, and was displayed in 1986 Detroit Auto show and then right to the Pontiac Special Vehicles Collection where it went unseen until the early 2000's. Both cars where running driving prototypes. The 84 version had the 2.5 four cylinder and the 86 version has a early development 2.8 V-6." -Fred Bartemeyer Jr.
See the fastback 2+2 Fiero at the Fiero 40th Anniversary event, Summer of 2023 in Pontiac Michigan! Follow our pages for the latest information:
http://midwestfieroclubs.aaca.com/
https://www.facebook.com/midwestfieroclubs
reinhart
Report this Post01-18-2022 05:05 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I like the targa top on the notchback. That would look good on the fastback I think.
Bluwolf
Report this Post01-18-2022 08:27 AM Click Here to See the Profile for BluwolfSend a Private Message to BluwolfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice read. Thanks
Notorio
Report this Post01-19-2022 12:12 AM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fascinating! What did they do with the extra 18" of interior space?
Australian
Report this Post01-19-2022 05:24 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
With all that engine space move the firewall not wrecking it just making it as intended.
FIERO JOHN-WI
Report this Post01-25-2022 01:14 PM Click Here to See the Profile for FIERO JOHN-WISend a Private Message to FIERO JOHN-WIEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was digging through some of my old magazines and I found that there is this 2+2 fiero photo
[This message has been edited by FIERO JOHN-WI (edited 01-25-2022).]
FIERO JOHN-WI
Report this Post01-25-2022 01:18 PM Click Here to See the Profile for FIERO JOHN-WISend a Private Message to FIERO JOHN-WIEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIERO JOHN-WI
Member since Jun 2001
Here you go
FIERO JOHN-WI
Report this Post01-25-2022 01:19 PM Click Here to See the Profile for FIERO JOHN-WISend a Private Message to FIERO JOHN-WIEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIERO JOHN-WI
FIERO JOHN-WI
Report this Post01-25-2022 01:21 PM Click Here to See the Profile for FIERO JOHN-WISend a Private Message to FIERO JOHN-WIEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIERO JOHN-WI
FIERO JOHN-WI
Report this Post01-25-2022 01:30 PM Click Here to See the Profile for FIERO JOHN-WISend a Private Message to FIERO JOHN-WIEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIERO JOHN-WI
I know in another magazine they have this same car from the rear 3/4 photo and it has GT taillights in it.
reinhart
Report this Post01-25-2022 01:53 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by FIERO JOHN-WI:
September of what year is that mag?
jonrev
Report this Post01-25-2022 03:16 PM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a tight fit...
Valkrie9
Report this Post01-25-2022 06:34 PM Click Here to See the Profile for Valkrie9Send a Private Message to Valkrie9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bertone's Marcello Gandini drew this balanced form of the mid-engined GT.
From the rear, a sculpted derriere, raised, and exposed, so hot.
looking up ! :
The original's drawing, wheelbase of 100.4".
Dressing up a project with similar lines of cloth, a new sharp lined suit, a retro '70s form for the 2+2 Fiero.
A accolade to Gandini's concept, derived from the Miura's planform with room for more on a longer wheelbase, very tight.
The beauty of Pontiac Fiero's skin-mount method, known dimensions.
The purpose is not to replicate the shape, but to adapt and emulate the concept for the Fiero's stretched wheelbase.
Building a bus, or van out of a chassis is not the objective.
Bertone did the design....perfectly.
Bertone Pirana 1967
FIERO JOHN-WI
Report this Post01-26-2022 09:01 PM Click Here to See the Profile for FIERO JOHN-WISend a Private Message to FIERO JOHN-WIEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wish I still had mine I built, but it ended up going to the junkyard from the very last owner that had owned it..
Fred's was a 2ft stretch mine was a 4ft stretch
[This message has been edited by FIERO JOHN-WI (edited 01-27-2022).]
FIERO JOHN-WI
Report this Post01-26-2022 09:03 PM Click Here to See the Profile for FIERO JOHN-WISend a Private Message to FIERO JOHN-WIEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIERO JOHN-WI
FIERO JOHN-WI
Report this Post01-26-2022 09:14 PM Click Here to See the Profile for FIERO JOHN-WISend a Private Message to FIERO JOHN-WIEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIERO JOHN-WI
jonrev
Report this Post01-26-2022 11:04 PM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remember that car sitting at Archie's shop back in 2008...
FIERO JOHN-WI
Report this Post01-27-2022 09:01 AM Click Here to See the Profile for FIERO JOHN-WISend a Private Message to FIERO JOHN-WIEdit/Delete MessageReply w/QuoteDirect Link to This Post
The car was first sold to Boomtastic friend CHESTER (his car was dirty rat)
then
He traded it to V8 Archie for some V8 engine to his car
then
A Foxy Fiero13 in Racine bought it from V8 Archie
then
sat in his parents driveway and they wanted gone
then
he called me asked me if I was interested in it or its going to the junkyard
then
it went to Sturtevant junkyard
then
crushed.
https://www.fiero.nl/forum/...130314-1-084609.html
