  Turbo Slug is going back together!
Turbo Slug is going back together! by Frenchrafe
Started on: 02-16-2022 12:57 PM
Replies: 36 (885 views)
Last post by: Frenchrafe on 09-01-2022 12:44 AM
Frenchrafe
Report this Post02-16-2022 12:57 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
So after several months of undoing, checking and fabrication, I have finally started to put my car's engine back together.
The crankshaft and camshaft are back in the 3800 block!
Here is the redesigned deep sump pan just placed to keep the dust out between work sessions:
For more info on the sump pan mods and the rest of the rebuild, see my YouTube channel: https://www.youtube.com/cha...wZvWQlkYxTjivW_0XNg/
Or this vid for the baffled sump pan (very long, sorry!): https://youtu.be/oREt_jTDQMg
Best regards,
Rafe
P.S. New vid on engine assembly, piston ring gapping etc... soon.
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France!
https://youtu.be/c4Cu7_2OgYc
https://www.youtube.com/cha...1wZvWQlkYxTjivW_0XNg
Frenchrafe
Report this Post02-23-2022 08:45 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/y2lujREdZqo
Video on how not to get your big end back into spec! This is not the way to do it, but it's worksπŸ˜‰
Piston preparation as well.
[This message has been edited by Frenchrafe (edited 03-25-2022).]
Frenchrafe
Report this Post03-13-2022 02:47 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pistons and timing chain in:
πŸ˜‰
Frenchrafe
Report this Post03-13-2022 03:01 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Frenchrafe
Member since Feb 2017
I did a bit of work on the cylinder heads today; not much more than checking valve seats and cleaning. Very boring! No photos.
I started to look in detail as well at my clutch assembly. The flywheel insert is shot!
I've written to SPEC CLUTCHES to see if this wear is normal on a racing clutch with less that 5000km?
Otherwise, you can just click on my latest video, if you want to?
It's the work done last week:
https://youtu.be/dnlx4j5_2HA
Cheers and best regards,
Rafe
[This message has been edited by Frenchrafe (edited 03-13-2022).]
Don Kraus
Report this Post03-13-2022 03:17 PM Click Here to See the Profile for Don KrausSend a Private Message to Don KrausEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thgat pan looks too deep for a Fiero,low ground clearance.Better check it.
Don
IMSA 34
60' - 1.555
1/4 mi - 10.519
mph - 130.29
TOO FAR
60' - 1.491
1/4 mi - 11.323
mph - 116.4
Frenchrafe
Report this Post03-13-2022 03:24 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You did check out my rather long video on the subject, no?
I show in the first few minutes just how "low" (deep) I can go.
Regards,
Rafe
Don Kraus
Report this Post03-13-2022 03:35 PM Click Here to See the Profile for Don KrausSend a Private Message to Don KrausEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have to take into consideration that when you hit a bump the springs will compress and the car will be a lot lower.Just trying to help.
Buildt a few of these and have learned a lot.
Don
IMSA 34
60' - 1.555
1/4 mi - 10.519
mph - 130.29
TOO FAR
60' - 1.491
1/4 mi - 11.323
mph - 116.4
Frenchrafe
Report this Post03-13-2022 03:44 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I understandπŸ‘Œ
It will be my anti-roll bar that hits the ground first. It's just in front of the sump.
While my intercooler air dam is often scraping, I have never had the anti-roll touch the ground.
We'll seeπŸ˜πŸ˜‰
Frenchrafe
Report this Post03-26-2022 02:30 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just a silly little video about how we all love getting the parts delivered for our cars:
https://youtu.be/saeZuEW3Guo
Cheers,
Rafe
Total ratings: 463
Report this Post03-26-2022 04:15 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Frenchrafe:
Just a silly little video...
Rafe, the "silliest" thing about your little video is that it only fills the middle third of my PC screen!
Frenchrafe
Report this Post03-26-2022 05:39 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Because it was filmed in vertical format to be watched on a smartphone screen.
Frenchrafe
Report this Post03-27-2022 03:03 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oil pump/timing cover fitted:
Just before, I had to get another oil pump cover machined down. The previous one cracked, and my weld repair didn't hold:
Last thing done yesterday was a crank journal oil seal sleeve. Thanks a lot brand new reman crank!!πŸ€ͺ
Videos to follow, but I'm about a month behind in editing the footage☹️
Regards,
Rafe
Frenchrafe
Report this Post04-03-2022 08:56 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Latest video, piston ring gapping:
https://youtu.be/Y-YE0CQ1ePE
RegardsπŸ˜‰
Frenchrafe
Report this Post04-27-2022 09:13 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/knrk0rtTF7M
Latest video.
Regards,
Rafe
Frenchrafe
Report this Post05-19-2022 12:22 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Short-bloc finished:
https://youtu.be/gde6P7hJohw
Dog football at 05:01 is the most interesting part πŸ˜‰πŸΊπŸΆβš½
In fact the motor is assembled:
I'm just behind in editing my videos!
Regards,
Rafe
Total ratings: 463
Report this Post05-19-2022 04:33 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can't view/turn your smartphone screen 90 degrees ?
Your other videos are great.
[This message has been edited by Patrick (edited 05-19-2022).]
Frenchrafe
Report this Post05-19-2022 05:04 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
ThanksπŸ‘ As well, I think you were the 100th person to watch this video. Good job to push my YouTube stats upπŸ˜„
CheersπŸ˜‰
Frenchrafe
Report this Post05-27-2022 01:49 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Latest video, with less boring bitsπŸ˜‰ and more fun!
https://youtu.be/Gp7TZML7bZo
Head job by handπŸ‘πŸ˜
pmbrunelle
Total ratings: 63
Report this Post05-28-2022 01:01 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you have a magical head gasket that just peeled off, leaving a clean surface (what we see in the video), or did you have to clean off gasket residues?
I never noticed that the 3800 head has a bump where the spark plug is, which would bring the spark plug more towards the middle of the combustion chamber.
Frenchrafe
Report this Post05-28-2022 02:55 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I may have not filmed it? πŸ€”As was said in the video, here's the finished item that I did earlier!πŸ˜‰
I probably stoned the mating surface before, along with the block.
Here's me stoning the intake mating surface (same technique):
[This message has been edited by Frenchrafe (edited 05-28-2022).]
Frenchrafe
Report this Post06-18-2022 09:06 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/y0jCOt9fyJ4
Latest stuff on sub-frame repairs and mods.
Regards,
Rafe
[This message has been edited by Frenchrafe (edited 06-18-2022).]
Frenchrafe
Report this Post06-28-2022 03:27 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine, gearbox and sub-frame/cradle back together:
There is a good chance that this will all go back in over the weekend πŸ‘πŸ˜
The videos are way behind as it takes time to edit and make something that even I don't get bored watching!
I probably won't bother with doing this YouTube thing very much in the future; nobody watches them!πŸ˜‹ Apart from my loyal 82 subscribersπŸ‘πŸ˜‰ (thanks to you few fellow like-minded gearheads!)
Here's the latest, sub-frame renforcement pt2:
https://youtu.be/LExUCcdfJ3M
I've got others half done/rushes/ideas like:
Fuel pump mods and tank restaration.
Getrag clutch fork repairs (recharging the fork tips with weld beads)
Header insulation and engine bay heat management.
PCM pinout and wiring.
Etc....
But in the end I'll just finish putting the car back on the road and maybe film the 1st start up on a livestream. No editing required! Ha Ha!πŸ˜„
Best regards,
Rafe
Frenchrafe
Report this Post07-20-2022 10:06 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
After recharging and hand filing the gasket flanges (warped/heat distorted; especially the turbo T3 flange!), I finally got the exhaust manifolds fitted:
Last job:
Fit the turbo and the power train can go back inπŸ˜„
rourke_87_T-Top
Report this Post07-21-2022 05:34 PM Click Here to See the Profile for rourke_87_T-TopSend a Private Message to rourke_87_T-TopEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is interesting placement for the air to air and oil cooler. I’m looking at accumulator’s trying to decide or what would be best placement to feed and other plumbing.
Frenchrafe
Report this Post07-22-2022 01:24 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, but it wasn't my idea. I first saw this type of setup many years ago on this forum; Darth Fiero I believeπŸ˜‰
It has been working well for me (trackdays etc...) since 2014!
As for oiling, I have now made a deep baffled oil pan. The accumulator idea would maybe run out of reserve on the long hard left turns that I encounter? Maybe not. Anyway, good luck with your setupπŸ‘πŸ™‚
Frenchrafe
Report this Post08-15-2022 05:27 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK. We have a powertrain back in the car:
I've still got to reassemble the rear suspension, but I managed to get the motor running today.
https://youtube.com/shorts/...E6m37M?feature=share
Not fitting the long driveshaft helps me with checking for potential leaks, turbo problems, etc ...
It ran fine, but the AN fuel fittings that feed the fuel rails leaked! (Thanks cheepo/crap made AN fittings!😠. There are 2 new ones ordered; quality aero grade units at 25€ each.)
I should get the car back on its wheels for next weekend πŸ˜‰
rourke_87_T-Top
Report this Post08-17-2022 03:19 PM Click Here to See the Profile for rourke_87_T-TopSend a Private Message to rourke_87_T-TopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice Work!
Frenchrafe
Report this Post08-17-2022 04:44 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice Work!
Thanks! πŸ‘
Today I finished fitting the rear suspension + driveshafts. The gearbox got it's Motul race gearoil fill. Wouldn't want to forget that before the first test drive?!
The cars goes for the 2 yearly inspection (contrΓ΄le technique) next monday. I've got my work cut out to get everything finishedπŸ€ͺ
Videos to follow, when I've got a bit more timeπŸ˜‰
Frenchrafe
Report this Post08-31-2022 04:51 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's alive!
https://youtu.be/wgBDw5xlOfQ
Turbo Slug is back!
Total ratings: 463
Report this Post08-31-2022 05:22 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's alive! Turbo Slug is back!
Excellent!
Funny how you speak to les chiens in French.
Frenchrafe
Report this Post08-31-2022 05:38 PM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
They're french dogs. They don't understand englishπŸ˜‰
When I say "woof", they reply "wouf?"🐺🐢
Total ratings: 463
Report this Post08-31-2022 06:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you speak to your dogs in English, do they just look at you funny... or do they still seem to comprehend what you're saying? I've always felt that dogs tend to go by the tone of our voices, moreso than the actual words. Even my cat understands when I state authoritatively... "No!"
cvxjet
Report this Post08-31-2022 07:36 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have trouble understanding when my DOG says "No".....But, hey, when she barks once I roll over once, barks twice I roll over twice, but three times I don't know what to do...I am an ex-gov-mint worker, so my way of counting is bit different than others; One......too.......many.....
By the way, I want to see your car do a lap....wish I was closer to see it in person.
pmbrunelle
Total ratings: 63
Report this Post08-31-2022 09:02 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're able to do a bunch of big work on a car in a small garage!
Running the engine 20 minutes unloaded to seat the rings is unconventional; other folks recommend some load on the engine so the cylinder pressure forces the ring into the bore.
Frenchrafe
Report this Post09-01-2022 12:09 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys for the repliesπŸ‘
Yes, my dogs do understand the 2 languages. And it is a the tonality of the voice that counts. (I was trying to be funny; aspergers humour?πŸ˜„)
For the running in, my explaination was a little off. Yes, it is the running under mild loads, and varying the engine speed, that beds the rings.
As for the garage space, I would love a double garage one day! But we make do with what we have; it's not the size that counts, it's what you do with it that matters!πŸ˜‰πŸ˜†πŸ€˜
Total ratings: 463
Report this Post09-01-2022 12:27 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh heh, no problem. I was genuinely curious, as alas, I'm not able to speak to my critters in more than one language. My dearly departed husky had the uncanny ability to totally ignore any/every language whatsoever... but I loved her anyway.
Frenchrafe
Report this Post09-01-2022 12:44 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
....My dearly departed husky had the uncanny ability to totally ignore any/every language whatsoever... but I loved her anyway.
Yeah, they can do that. Our old bulldog had selective hearing, bless her soulπŸ’šπŸ’™
