  Uploading images made even easier!
Uploading images made even easier! by Cliff Pennock
Started on: 03-04-2022 07:48 AM
Replies: 36 (688 views)
Last post by: A_Lonely_Potato on 03-16-2022 11:46 AM
Cliff Pennock
Administrator
Total ratings: 699
Report this Post03-04-2022 07:48 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've added another way to upload images in your posts. In addition to the "Upload Image" button - which still works as before, btw - you can now copy & paste images straight into your post!
So for instance, let's say you want to post an image that you saw somewhere on the internet. On the original image, simply right click it and choose "Copy Image". Next, inside your post, either hit CTRL-V (on Windows) or right click and choose "Paste". The image will be uploaded to the PFF server and automagically be inserted in your post.
The source of the copied image does not matter. So it can be the internet, Windows' Snipping tool, or your favorite image editor, it doesn't matter.
IMPORTANT:
When you upload images using the "Upload Image" button, the system uses the filename to see if you have posted that images before and will tell you that the image already exists on the server. That way, no duplicates are stored. By using the copy & paste option, there's no way for the system to know if this image has been uploaded before or not. So do not copy and paste the same image over and over again, since this will create duplicates and waste precious storage space on my server.
IMPORTANT 2:
Please be aware you are still posting the images to my server. So please remember that storage space isn't infinite. Do not abuse the system by copying and pasting tons of memes.
IMPORTANT 3:
Okay, I know you want to. So go ahead and test it out in this thread. 😄
Sage
Total ratings: 71
Report this Post03-04-2022 09:43 AM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
LUVIT!
Footnote: Used the copy function, but when I tried to "paste" it didn't....but when I hit CTRL-V.....it popped in. (Your results may vary.)
Cliff Pennock------------still "got it"!
Thank you sir.
HAGO!
Total ratings: 403
Report this Post03-04-2022 11:32 AM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
To better days!
Thank Cliff
Total ratings: 461
Report this Post03-04-2022 11:35 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not seeing it when I do the paste/CTRL-V command.
Edit - Nope. Not working. But I'm fine with the button.
[This message has been edited by Raydar (edited 03-04-2022).]
Total ratings: 403
Report this Post03-04-2022 01:51 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
To better days!
Thank Cliff
The clipboard is not working but the button and the link work fine.
Newbfiero
Total ratings: 71
Report this Post03-04-2022 03:04 PM Click Here to See the Profile for NewbfieroSend a Private Message to NewbfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Newbfiero
Total ratings: 71
Report this Post03-04-2022 03:07 PM Click Here to See the Profile for NewbfieroSend a Private Message to NewbfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Newbfiero
Member since Mar 2006
Very nice and easy 😊 Thx Cliff 👍
[This message has been edited by Newbfiero (edited 03-04-2022).]
Report this Post03-04-2022 04:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's very handy, being able to select an actual image (and not just a file name) from within an image viewer utility.
So for instance, let's say you want to post an image that you saw somewhere on the internet. On the original image, simply right click it and choose "copy". Next, inside your post, either hit CTRL-V (on Windows) or right click and choose "Paste". The image will be uploaded to the PFF server and automagically be inserted in your post.
Slight correction. You need to Right Click on the selected image, choose Copy Image, and then Paste it in the posting text box.
And a friendly reminder to everyone posting images, especially now that it's getting easier and easier to do so here. Pay attention to where you're positioning the image link within the posting text box! We don't need to be seeing more and more images located in the middle of a sentence!
[EDIT] And maybe Cliff can address this... but I suspect to avoid a clickable image icon from appearing in a post (instead of an image), that the current maximum file size is still 2 MB (despite the icon indicating >300 KB)?
[This message has been edited by Patrick (edited 03-05-2022).]
Total ratings: 461
Report this Post03-04-2022 10:29 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's not working for me at all.
Might it be a Windows 7 limitation? Or Chrome, maybe?
Report this Post03-04-2022 11:33 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm having the same problem... with Win 7 and Chrome (if that makes a difference).
In my previous post, I was using Cliff's new system to copy an image stored on my hard drive accessed through an image viewer utility (ACDSee), and it worked great.
However, a moment ago I tried to copy (and paste) an image from an online source... and it doesn't work. Nothing happened.
[This message has been edited by Patrick (edited 03-04-2022).]
Trinten
Report this Post03-05-2022 12:07 AM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Using Firefox,
Copying and trying to Paste an image into the body of message had no reaction -- though I will say I hadn't even noticed the Upload Images button until it was mentioned in here! I've been using PIP for about a year!
Cliff Pennock
Administrator
Total ratings: 699
Report this Post03-05-2022 08:39 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
To copy an image from the internet, right click it and choose "Copy Image". Then right click in your message and click "Paste" or hit CTRL-V. Works fine here...
Australian
Report this Post03-05-2022 09:46 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Patrick:
Slight correction. You need to Right Click on the selected image, choose Copy Image, and then Paste it in the posting text box. [EDIT] This appears to only work while accessing an image stored locally on a hard drive. See post below.
And a friendly reminder to everyone posting images, expecially now that it's getting easier and easier to do so here. Pay attention to where you're positioning the image link within the posting text box! We don't need to be seeing more and more images located in the middle of a sentence!
I was tripping so hard thought i saw a 4wd mera.
LT188GT
Total ratings: 100
Report this Post03-05-2022 01:12 PM Click Here to See the Profile for LT188GTSend a Private Message to LT188GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just testing the cut/paste method.
R Runner
Total ratings: 98
Report this Post03-05-2022 05:04 PM Click Here to See the Profile for R RunnerSend a Private Message to R RunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
testing
[This message has been edited by R Runner (edited 03-05-2022).]
RCR
Total ratings: 102
Report this Post03-05-2022 05:30 PM Click Here to See the Profile for RCRSend a Private Message to RCREdit/Delete MessageReply w/QuoteDirect Link to This Post
Works...From snippet and FB...thnx Cliff.
Bob
[This message has been edited by RCR (edited 03-05-2022).]
Report this Post03-05-2022 05:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I'm telling ya... it didn't work yesterday. Not just for me, but for several others here.
However, it does appear to be working today, so that's great!
Cliff, you might want to slightly edit your first post (to cut down on any confusion), as there are actually three different "Copy" options to choose from when an image is right-clicked.
Report this Post03-05-2022 07:02 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
Great, my posted image had the desired effect!
Report this Post03-05-2022 11:41 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMPORTANT:
Add a MD5 or other hash to copy/past imgs would help...
"Adding" the hash can as simple as file naming.
The warning if new c/p imgs has same showing first img.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post03-06-2022 08:54 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's actually a pretty good idea. I'll look into it.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post03-06-2022 08:55 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
Done!
johnyrottin
Total ratings: 85
Report this Post03-06-2022 02:25 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Testing
[This message has been edited by johnyrottin (edited 03-06-2022).]
Fierochic88
Report this Post03-06-2022 10:30 PM Click Here to See the Profile for Fierochic88Send a Private Message to Fierochic88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 461
Report this Post03-07-2022 11:16 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Edit - You cannot copy from the Windows Photo Viewer, and paste here.
[This message has been edited by Raydar (edited 03-07-2022).]
Cliff Pennock
Administrator
Total ratings: 699
Report this Post03-07-2022 11:33 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Works fine here...
Report this Post03-07-2022 03:33 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Something is definitely weird with this new image upload system, as I originally had no problem copying and pasting from ACDSee (my usual image viewer), but today it won't work. And just for the heck of it, I tried to use Windows Photo Viewer, and it doesn't work to copy and paste from there either (as Raydar had mentioned).
Cliff... I don't know what's up, but something seems to be changing from day to day.
I am still able to Copy Image and Paste from an online source though.
[This message has been edited by Patrick (edited 03-07-2022).]
A_Lonely_Potato
Report this Post03-07-2022 06:36 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very interesting. I can copy paste from Sketch & Snip, its outdated counterpart Snipping Tool, Paint, Paint 3D, Chrome, and darktable(an image editing software) but NOT directly from file explorer, or the "Photos" Win10 default photo viewer.
Windows 10 64 bit, version 21H2, build 19044.1526. Running latest version of Chrome for my browser
Fie Ro
Total ratings: 132
Report this Post03-09-2022 05:52 PM Click Here to See the Profile for Fie RoSend a Private Message to Fie RoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can I make a screenshot and paste it here?
Yes!
Report this Post03-09-2022 07:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes!
But can you Copy Image and Paste from your favorite photo viewing program?
armos
Report this Post03-10-2022 10:11 AM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tried from 2 local photo viewers, not internet.
Worked for me only *after* I got logged into my account, then reloaded the posting page.
When I merely had my username/pass filled in on the posting page but wasn't actually logged in yet, then it didn't work.
[This message has been edited by armos (edited 03-10-2022).]
fierosound
Total ratings: 286
Report this Post03-10-2022 10:17 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just have to be logged into system first.
[This message has been edited by fierosound (edited 03-11-2022).]
Report this Post03-10-2022 11:37 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been that way ever since Cliff implemented the Image Upload box. From 2-1/2 years ago...
Originally posted by Cliff Pennock Here:
Yes, you need to be logged in because all images are stored in your own private album. But once you have posted a message (or logged in through the main forum page) you should stay logged in for a year or so. If you are not logged in the next time you visit PFF, then there's something odd going on with your cookies (maybe you block them?).
Just tried to copy and paste with two different photo viewing programs... still no dice.
[This message has been edited by Patrick (edited 03-10-2022).]
Report this Post03-10-2022 12:02 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post03-10-2022 09:46 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used this a couple time. Works for me.
Note:
If you copy directly from some web sites... the copy will fail.
Many sites have blocked copying and/or saving images.
Either site blocked right click etc or have layers of images making copy/saving fail.
Many images are "Dynamic" and while you see them... fails to save etc even if you save the whole page.
But often can use a "screenshot" to save them.
exoticse
Total ratings: 108
Report this Post03-15-2022 08:53 PM Click Here to See the Profile for exoticseSend a Private Message to exoticseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post03-15-2022 10:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://i12.photobucket.com/...227/exoticse/b-1.jpg
Fail.
[This message has been edited by Patrick (edited 03-15-2022).]
A_Lonely_Potato
Report this Post03-16-2022 11:46 AM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fail.
Hey, they tried. C+ for effort
