  Sunbird Turbo vent pics and advice please.... (Page 1)
Sunbird Turbo vent pics and advice please.... by Kitskaboodle
Started on: 08-07-2022 01:36 PM
Replies: 48 (1191 views)
Last post by: 2.5 on 09-13-2022 02:11 PM
Kitskaboodle
Report this Post08-07-2022 01:36 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have some Sunbird Turbo hood vents that I am going to be installing on my 85 GT.
I have never done a bodywork project like this before. (knowing where to place them, getting them lined up appropriately, measuring & cutting the holes in the front hood, etc...)
I would like to see a few pics of those who have done this. (Grand Am & Firebird vents are also welcome)
Also, do you have any pointers/suggestions on the install? (especially on how to determine where to place them in the front of the hood / spacing, etc.)`
Thanks, Kit
Report this Post08-07-2022 04:08 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used a different style vent... but the best advice I can give you is first, make sure the entire vent is behind the radiator (I know, seems obvious), and don't go back so far that you're cutting into the area that seats on the rubber seal of the spare tire compartment.
[This message has been edited by Patrick (edited 08-07-2022).]
cvxjet
Report this Post08-07-2022 04:49 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't particularly like the "Glue-on" look of a lot of the vents. I prefer where the vent is ducted into the hood a bit. I also really like using the Defrost (Dash) vent as the grill for a hood vent- possibly combining it with a slight "tunneling".....
[This message has been edited by cvxjet (edited 08-07-2022).]
IMSA GT
Total ratings: 250
Report this Post08-07-2022 07:09 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
In a nutshell, you'll notice that with all of the vents shown above, the opening is no higher than the top of the headlight doors. Keep your vents between the headlights and you'll be fine.
Basically follow the curves where the trunk seal sits that I marked in green. You can see the area between the headlights where you can cut and still be in the radiator area and not in the spare tire area.
[This message has been edited by IMSA GT (edited 08-07-2022).]
Kitskaboodle
Report this Post08-07-2022 07:20 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the good comments.
Anyone else?
Kit
qwikgta
Total ratings: 84
Report this Post08-08-2022 05:21 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
mine
Kitskaboodle
Report this Post08-08-2022 06:39 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow, those are quite close together.
I usually see more spacing between the vents.
Looks great though!
Thanks for the pic.
Kit
Report this Post08-08-2022 07:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I completely understand why qwikgta installed the vents where he did, as it looks great! However, if I was to have used those style vents, I think I personally would've mounted them as far back as possible... as I wouldn't want any part of the vents to be in front of and/or on top of the radiator. It's the pressure build up behind the rad and in front of the spare tire compartment that needs to be reduced. This image sort of shows approximately where I'd try locating the rear mounting holes.
Report this Post08-08-2022 10:03 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The area above, beside, and behind the radiator are all the same high pressure area (this is why headlight covers pop up). Vents in any of these directions/areas can help reduce the pressure build up and be effective vents.
Report this Post08-08-2022 10:43 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are two factors in play here... reducing overall air pressure build up under the nose, and effectively venting hot air (as opposed to air that hasn't gone through the radiator yet). I installed my hood vents more to aid with cooling than to prevent front end lift. (I seldom go fast enough for there to ever be an issue!)
I want as much vented air as possible to have gone through the radiator.
Yes, it's conceivable that their placement doesn't make any discernible difference in the cooling effect of the vents... but I don't know for sure, which is why I lean towards moving the vents rearward of the radiator as far as they can go.
[This message has been edited by Patrick (edited 08-09-2022).]
qwikgta
Total ratings: 84
Report this Post08-08-2022 10:44 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
swapped out the hood for this one anyway.
Report this Post08-08-2022 10:47 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice!
Report this Post08-09-2022 07:03 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Venting the high pressure zone (from any area) creates a pressure relief, which caused more more air movement behind the radiator, which aids in air flow through the radiator (assuming the top and sides of the radiator are still sealed to force air through vs. allowing it to pass around the radiator).
The two factors pressure and airflow (velocity) are directly linked.
Report this Post08-10-2022 03:41 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed.
Fieroguru, I always appreciate your opinion... even on the very rare occasion (like this one ) where I don't agree with you. It makes zero sense to me to reduce the high pressure zone in front of the radiator (instead of behind it) in regards to helping to cool the radiator/coolant.
Does not the high pressure zone in front of the radiator aid in air velocity through the radiator, especially when pressure relief is accomplished by way of the added vents behind the rad?
I'm sorry, but I don't see any advantage whatsoever in reducing the high pressure zone in front of the rad as opposed to behind it. Actually, I'll go further and say that IMO it's detrimental in regards to helping to cool the rad. As far as reducing front end lift, I'd say it's a wash either way.
Report this Post08-10-2022 07:05 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The top and sides of the radiator are sealed to keep the front/face of the radiator at a higher pressure (when the car is driving) and force the air through the radiator (and not allow it around it) - this allows the radiator to cool w/o the use of the fan above 35 mph. The back, top, and sides of the radiator are all part of the same space and at the same pressure that can be vented to increase airflow through the radiator. Air will change directions to take the path of least resistance, so any opening in this combined area will reduce the high pressure in the back, top, and sides of the radiator and create additional air flow through the radiator (through the radiator is the primary path into this high pressure zone)
Think of it like your house and the radiator is in the open door to your deck and the prevailing wind is pushing air through the radiator. There will be some breeze when you open it, but opening any other door or window on any of the 3 other sides of the house will increase the air flow through the door. Even if it has to flow down hallways, up stairs, under doors, etc.
hyperv6
Total ratings: 93
Report this Post08-10-2022 07:21 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dupe
[This message has been edited by hyperv6 (edited 08-10-2022).]
hyperv6
Total ratings: 93
Report this Post08-10-2022 07:26 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
hyperv6
Member since Mar 2003
This is the hood I am using.
It and the air dam have made a marked improvement on down for e in the fron. The stock nose actually generated lift per Pontiac at high speed. It really did feel bad at 90 mph.
The vent also makes a great bug deflector it blows them straight up at night.
Report this Post08-10-2022 10:07 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post08-10-2022 10:10 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
Same as quikgta just a little farther apart.
A_Lonely_Potato
Report this Post08-10-2022 12:46 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
i'll add another to the list. Same as 2.5 and qwikgta, but mine aren't aligned... ill have to see about fixing that some day. cursed p/o...
Kitskaboodle
Report this Post08-10-2022 12:50 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dear 2.5,
In the words of Paris Hilton...... "That's Hot!"
I would LOVE some pics of the underside to get an idea of where you cut in relation to the weatherstrip seal area.
Thanks, Kit
Report this Post08-10-2022 04:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Air will change directions to take the path of least resistance...
...which is exactly why I believe adding a vent in front of the radiator is counterproductive (for cooling purposes).
Fieroguru, I appreciate hearing your view on this, but I remain totally unconvinced.
A_Lonely_Potato
Report this Post08-10-2022 05:06 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Obviously the front radiator compartment is a positive pressure enclosure, given the headlight cover popping up with enough speed. With positive pressure, it will try to escape at ANY place. Flow matters, but pressure matters more. Think of it like a computer case. If you have a case with fans only driving air in, with a single opening unrestricted for air to escape, it doesn't matter which direction the fans are pointing within the case. Theres pressure, and it will escape through any path given. Be it through seams in the panels, or a vent. Same case with the hood vents. I will agree that the more in line with the flow the better, but with negligible real world difference.
Report this Post08-10-2022 05:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by A_Lonely_Potato:
Think of it like a computer case. If you have a case with fans only driving air in, with a single opening unrestricted for air to escape, it doesn't matter which direction the fans are pointing within the case. There's pressure, and it will escape through any path given. Be it through seams in the panels, or a vent. Same case with the hood vents.
So how is that supposed to convince me that air pressure escaping through hood vents located in front of the radiator (which would result in less air flow through the radiator than if the hood vents were located to the rear of the radiator) is not going to negatively affect the radiator's ability to do its job?
I appreciate the attempts to "set me straight", but they're not working.
[EDIT] I'm trying to understand where this disconnect is occurring in our discussions on air pressure. Possibly it's due to our individual understanding of where this high pressure area is actually occurring. I think we all agree that there is a high pressure zone in front of the radiator. I also believe there is a high pressure zone behind the radiator, due to the spare tire compartment being in the way of air flow which has not only gone through the radiator, but air flow that has also worked its way into that area through any number of small, and maybe not so small openings. In my opinion, creating an escape for the high pressure zone in front of the radiator does nothing to reduce the high pressure zone behind the radiator (in front of the spare tire compartment). Is the argument then that the high pressure zone in front of the spare tire compartment will force air forward through the radiator, and then out the hood vents located in front of the rad?
[This message has been edited by Patrick (edited 08-10-2022).]
Report this Post08-10-2022 08:18 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here are the pressure zones:
A_Lonely_Potato
Report this Post08-10-2022 09:09 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was going to try to draw something like that up guru, but im not much of an artist
Patrick, as is visualized in guru's drawing, the hood vents being "in front" of the radiator isnt relieving pressure from the front face of the radiator, because of the seal
Report this Post08-10-2022 09:25 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
With credit to fieroguru for the original drawing (nice!)... here's my view of the situation. Yes, I understand that in the original drawing, the seal perhaps looks more like it does in real life, but I've tried to alter the drawing to show how I believe it effectively functions. I could very well be wrong, but this is how I see the separation of the two pressure zones. The two short thick red lines show the relative locations of added vents positioned in front of the radiator, and/or behind it.
I'm going to have a good look-see at the front of my Formula before conceding anything. Good discussion!
Report this Post08-10-2022 09:46 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is reality:
nosaint
Report this Post08-10-2022 10:48 PM Click Here to See the Profile for nosaintSend a Private Message to nosaintEdit/Delete MessageReply w/QuoteDirect Link to This Post
i went with ZO6
hyperv6
Total ratings: 93
Report this Post08-10-2022 10:55 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
In racing they put it behind the rad for two reasons.
1 to relieve the high pressure area
2 to improve the air flow through the radiator to improve cooling.
Some spots may have be higher presume but any opening is like a pressure relief valve and does the job.
I know with mine the nose and steering got light around 90 mph and Pontiac claimed it actually produced some lift due to the high pressure.
Just getting air out from under the car helps.
Usually on the street aero has little effect but this was one thing that did improve my car.
Report this Post08-11-2022 12:02 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is reality:
Fine. Will you now insist that there is superior air flow out of the front mounted vents?
Report this Post08-11-2022 01:04 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
CLICK FOR FULL SIZE
Originally posted by nosaint:
i went with ZO6
CLICK FOR FULL SIZE
I like both of those hoods. Did either one of them require reworking of the spare tire compartment/seal?
[This message has been edited by Patrick (edited 08-11-2022).]
hyperv6
Total ratings: 93
Report this Post08-11-2022 06:03 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just had to push the leading wall back about 3/4 of an inch in a small section.
It seals and if I go back to the original hood I can just push it back in place.
No cutting or non reversible modifications were needed.
I think the key is one to make the vents molded in so they don’t look like a tape on vent. Also to get them in the right size for the style they are.
[This message has been edited by hyperv6 (edited 08-11-2022).]
nosaint
Report this Post08-11-2022 11:25 AM Click Here to See the Profile for nosaintSend a Private Message to nosaintEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure it required it, but i cut a huge chunk out of the middle to create a scoop for air to exit better
Report this Post08-11-2022 11:59 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Underhood pics please?
qwikgta
Total ratings: 84
Report this Post08-11-2022 12:59 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have one of those on my Red GT too.
longjonsilver
Report this Post08-11-2022 01:02 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i went for maximum air flow and minimum air restrictions, as well as clean air flow. Before i installed my radiator vent, Freya wud overheat easily in traffic. After installing it, it took a lot longer to overheat - cuz my fan was not working. When i fixed my fan, WOW it pushed a LOT of air. Car stays nicely glued to the pavement at any speed that i have traveled up to 90mph. Strings glued in and out of the vent show that at speed air moves thru at great velocity. i love my vent.
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 3800SC, 4-wheel drifts are fun!
qwikgta
Total ratings: 84
Report this Post08-11-2022 01:13 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is reality:
Yes, without the radiator seal on top of the radiator this would not work. I know it worked b/c when the fan was on, and the car stopped, it pushed air out of the vents. also, when driving the air over the scoops created a Bernoulli Effect and pulled air out of the lower pressure area behind the radiator.
I put the scoops where I did b/c I didn't like the way it looked when they were higher up on the hood, I liked the way they worked with the headlight covers. when I moved them up it just looked wrong. I did move them apart, to the left/right but again, I just felt the looked better where I put them. In the end, I also didn't like the "bolt on" look and I wanted to have them integrated into the hood but went another route.
hyperv6
Total ratings: 93
Report this Post08-11-2022 04:57 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
That is only the third on I know of.
One other is in Wisconsin.
hyperv6
Total ratings: 93
Report this Post08-11-2022 05:48 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
hyperv6
Just bent the front wall back k a small bit. Did French in the overflow cap.
