  Sunbird Turbo vent pics and advice please.... (Page 2)
Sunbird Turbo vent pics and advice please.... by Kitskaboodle
Started on: 08-07-2022 01:36 PM
Replies: 48 (1129 views)
Last post by: 2.5 on 09-13-2022 02:11 PM
hyperv6
Total ratings: 94
Report this Post08-11-2022 05:52 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
hyperv6
Total ratings: 94
Report this Post08-11-2022 05:54 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
hyperv6
Member since Mar 2003
The hood used the stock under support. The top is all one piece molded.
Total ratings: 259
Report this Post08-11-2022 07:40 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
My hood vent is a modified STM vent from thadriver. The leading edge of the hood vent opening was reshaped to be parallel with the front edge of the hood and intersect the center of the headlight opening. The lower portion of the opening was also trimmed to make it parallel with the leading edge of the opening as well as to make the opening larger. Seal surface for the frunk was left stock.
hyperv6
Total ratings: 94
Report this Post08-11-2022 08:19 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here is one scoop I saw at the I!SA race this year. Benz has the scoop between the radiator and the engine. It is used for down force and better cooling for the radiator. It removes the high pressure and remove air from under the car.
Fiero_Adam
Report this Post08-12-2022 12:25 AM Click Here to See the Profile for Fiero_AdamSend a Private Message to Fiero_AdamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Look what you've started, Kit! This was the most active thread on the forum, lol.
[This message has been edited by Fiero_Adam (edited 08-13-2022).]
Kitskaboodle
Report this Post09-11-2022 10:17 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, Sunbird Turbo vents have been installed.
See pics.
Kit
Kitskaboodle
Report this Post09-11-2022 10:44 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kitskaboodle
Member since Nov 2004
For a few “behind the scenes” looks, here are a few more pics of the marking / taping / cutting process.
Kit[img]https://images.fiero.nl/userimages/Kitskaboodle/ 89244D61-4B16-417F-8A6A-070D5F12194B.jpeg[/img]
Kitskaboodle
Report this Post09-11-2022 10:48 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kitskaboodle
Report this Post09-13-2022 02:11 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks good Kitskaboodle , should make a noticable difference.
