  Fuel pump/sending unit connector
Fuel pump/sending unit connector by PhatMax
Started on: 10-22-2022 05:19 PM
Replies: 5 (259 views)
Last post by: MaxxPower1968 on 10-24-2022 05:42 PM
PhatMax
Report this Post10-22-2022 05:19 PM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Trying to locate the connector or connectors for the fuel pump/ sending unit where it plugs into the harness. Anybody have part numbers ?
PhatMax
Report this Post10-22-2022 07:30 PM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, after a bit more searching I found this wonderful site !
https://www.customconnectorkits.com/
Hope it helps someone as well.
Report this Post10-22-2022 09:04 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If replacing Weather Pack @ C502... You can get most parts @ many places.
Not sure C502 is custom keyed. I believe it made for a "locking pin" to keep both shells lock to each other and often hard to find these...
Example: The shells are mod'ed to take the white part in this called "Connector Position Assurance"
From https://www.tti.com/content...pack-connectors.html
(Aptiv is new name for Delphi that was GM parts.)
But can replace both shells w/ standard 3 position shells.
for connector on pump pickup @ the flange...
See also https://www.fiero.nl/forum/.../HTML/145778.html#p4
The "Universal" one is likely to fit most Fiero.
If you get extra Weather Pack pins... can reuse the shell of C502 and never splice the wires there.
[This message has been edited by theogre (edited 10-22-2022).]
PhatMax
Report this Post10-23-2022 01:23 PM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah…my connector is toast. The plastic is literally crumbling. I have two sets coming, wasn’t sure of the gauge of the wire so I got two.
I will post on the outcome.
Report this Post10-24-2022 01:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can replace just the Shells for Weather Pack connections.
You need a "tool" that's "screwdriver" or other handle w/ small tube to compress the ears on terminals then pull out the back.
Lisle and more make this. Lisle 14900 Terminal Tool for GM
Many sell release tools likely has weather pack tube like https://www.amazon.com/Vign...pin+removal+tool+kit
Don't splice pigtails unless the terminals etc are bad too.
Adding more wire for C502 just makes more issues and easier to snag or hit the exhaust.
MaxxPower1968
Report this Post10-24-2022 05:42 PM Click Here to See the Profile for MaxxPower1968Send a Private Message to MaxxPower1968Edit/Delete MessageReply w/QuoteDirect Link to This Post
Deleted
[This message has been edited by MaxxPower1968 (edited 10-24-2022).]
