  C500 Connector Bodies
C500 Connector Bodies by Will
Started on: 12-10-2022 04:50 PM
Replies: 4 (449 views)
Last post by: Will on 12-11-2022 10:12 AM
Total ratings: 237
Report this Post12-10-2022 04:50 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
From this thread:
https://www.fiero.nl/forum/Forum2/HTML/128029.html
Originally posted by phonedawgz:
http://i386.photobucket.com.../fieroX/IMG_2009.jpg
Only this part of the connector was made. To purchase contact FieroX. I have some also but I would have to charge more than he sells them for, so you might as well go directly to the source.
They are lacking the secondary terminal retention fork, but you can use your old one. Same thing for the missing back cover.
Use dielectric grease instead of the goo that was in the old ones.
He also has some new C203s
I've tried using contact info on the forum and what I can find on Google to contact PhoneDawgz and FieroX with no success.
Does anyone know these individuals IRL or have current contact information so I could pursue obtaining a C500 connector body or two or three?
IMSA GT
Total ratings: 253
Report this Post12-10-2022 05:39 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you try to call PhoneDawgz from his website phone number?
Total ratings: 207
Report this Post12-11-2022 09:18 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The C-100 connector plugs and receptacles ( front compartment / intterior) are exactly the same with the exception of wire color.
Total ratings: 237
Report this Post12-11-2022 10:09 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've emailed at the email address on that site, which is common to his profile here. It had slipped my mind that he has a phone number there. I guess that's next.
Total ratings: 237
Report this Post12-11-2022 10:12 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jun 2000
Correct. If you're building a harness from scratch, you still have to obtain one.
