  Never had a better view of my front underside
Never had a better view of my front underside by A_Lonely_Potato
Started on: 02-19-2023 05:32 PM
Replies: 11 (595 views)
Last post by: Notorio on 02-21-2023 07:34 PM
A_Lonely_Potato
Report this Post02-19-2023 05:32 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quite unnerving. i for sure thought i was going to flip when i felt the back wheel ride up the ditch and the front end starting to swing out. It all went very quickly, felt the slide begin, attempted to correct to the right, but i just got carried over. mocked up a little sequence of events. a ridge of packed snow caught the inside of my front tire and the outside of my rear, throwing me around.
Total ratings: 465
Report this Post02-19-2023 06:10 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kids!
Sorry, just teasing you. Are both you and the car alright?
Mike in Sydney
Report this Post02-19-2023 07:36 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I trust you were wearing your brown pants...
Report this Post02-19-2023 08:16 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Carefully check suspension etc on a lift.
Car can look, even drive, Ok now but can hind various problems that bite hard later without warning.
johnyrottin
Total ratings: 85
Report this Post02-19-2023 08:29 PM Click Here to See the Profile for johnyrottinSend a Private Message to johnyrottinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let me know if anything is bent. I’ll go through my bits to see if I have anything for ya.
cam-a-lot
Total ratings: 99
Report this Post02-19-2023 08:47 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad you are OK. Fieros never were great for winter driving... not to mention the damage the salt does to the frame/cradle/floors.
Hopefully you didn't need a diaper change after this happened!!
A_Lonely_Potato
Report this Post02-19-2023 08:57 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Me and the car are just fine. luckily was only a few minutes from home, so called and had someone bring one of our vans over with a tow strap and pulled myself out. drove home, felt okay.
jacked up the car, put her on stands and gave everything some wiggling and looking over, everything seems alright.
looking it all over was just reminding me that i should really do a front end refresh. change out control arm rubber bushings for poly, lowering ball joints, new end links because mine dont look too good, inner and outer tie rods both sides
one thing that isnt quite alright though, is my drivers rear wheel. it has some side to side wiggle to it, but the tie rod seems rock solid. looks to me like my strut tower is twisting slightly? im not sure, got some investigating to do. cant see how that would be from the accident though, drivers side didnt see any impact from it.
Trinten
Report this Post02-20-2023 04:25 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to know you are okay and the car is mostly unscathed.
My last Fiero had an odd issue with a rear wheel wobbling as you described, it would make one think it was a tie rod end or bushing, turned out it was the wheel hub! Replaced the wheel hub assembly and the issue went away.
Total ratings: 461
Report this Post02-20-2023 07:34 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm happy that you and the car are both relatively unscathed. Easily could have gone much worse.
That's kind of what went through my mind, too.
A_Lonely_Potato
Report this Post02-20-2023 07:54 PM Click Here to See the Profile for A_Lonely_PotatoSend a Private Message to A_Lonely_PotatoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmm, will look at it again tomorrow. I know i replaced one wheel bearing not too long ago, i think it was the passenger side. i ordered one for each side but i can't remember if i installed a new drivers side as well. ill try to get back about it in reasonable time. taking a trip to florida on thursday and won't be back home till the 5th, so fingers crossed on the car.
my exhaust seems to have gotten a little bent when it rammed into the ditch lol, and its pushing against the cradle now. i also picked up an odd droning vibration sound at maybe 2.5kRPM, gonna try to see if thats where the sound is coming from tomorrow as well between jobs.
David Hambleton
Report this Post02-21-2023 09:00 AM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
What kind and size tires?
When I bought my new '84 SE 4 speed, I erroneously thought that the weight distribution would provide VW beetle-like winter traction. Wrong... Lol!
Couldn't get going, couldn't steer & couldn't stop in snow. Goodyear Eagle tires provided toboggan-like experience.
Switched to skinny Continental all-season tires and got normal rear drive control and it was safe to drive.
Decided to restrict driving to dry, salt-free conditions to prolong vehicle life; now have 396,000 km (246,000 miles) on it and still going.
[This message has been edited by David Hambleton (edited 02-21-2023).]
Notorio
Report this Post02-21-2023 07:34 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to hear you both are safe. Thank God there wasn't a car (or truck) coming the other way. Excellent diagram, BTW.
