  My 3.4 swap finally complete
My 3.4 swap finally complete by Dccarguy05
Started on: 03-03-2023 11:56 PM
Replies: 12 (480 views)
Last post by: Notorio on 03-23-2023 11:03 PM
Dccarguy05
Report this Post03-03-2023 11:56 PM Click Here to See the Profile for Dccarguy05Send a Private Message to Dccarguy05Edit/Delete MessageReply w/QuoteDirect Link to This Post
I’m getting older and finally had time after 8 long years of stuff my wife piling stuff on top of my old 88 GT to bring her back to life ! I thought I would share some photos of it to some fellow Fiero lovers like me 😎[img]https://images.fiero.nl/userimages/Dccarguy05/8F773 B06-7350-4127-8980-1252DCCD81BE.jpeg[/img]This images is larger than 153600 bytes. Click to view.[img]https://images .fiero.nl/userimages/Dccarguy05/B140387D-6649-4BCA-A0A8-21EABE7FB97A.jpeg[/img][img]https://images.fiero.nl/userimages/Dccarguy05/4D9D89BC-107D-4ABA-985F-AAE8 D1B0670D.jpeg[/img][img]https://images.fiero.nl/userimages/D ccarguy05/5D1BEABD-6E1F-408D-B7C3-9ADF4B48120F.jpeg[/img][im g]https://images.fiero.nl/userimages/Dccarguy05/C4957EF3-0116-4187-BB07-7B2DD2926AC8.jpeg[/img]
Report this Post03-04-2023 12:13 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The images (that have shown up) are great! Here's a tip for posting images at PFF.
To allow your images to present properly (including the ones that currently aren't appearing at all), press your Enter key twice after each image upload. Otherwise, the image URL address gets corrupted on some of them (a gap is created in the address), and they then don't show up. Also try and keep the file size for each image below 2000 KB to avoid an image icon (which then needs to be clicked to view the image).
It may not be quite as noticeable on a phone (where you probably only see one image at a time on the screen), but on a PC monitor, the way the current images are presented is kind of a mess.
You can easily fix your post by clicking on EDIT and making these changes.
[This message has been edited by Patrick (edited 03-04-2023).]
Spadesluck
Report this Post03-04-2023 08:01 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats! Many never even reach the point of done, as the rest of us are in a never ending "build" process.
Dccarguy05
Report this Post03-05-2023 12:39 PM Click Here to See the Profile for Dccarguy05Send a Private Message to Dccarguy05Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you! It’s been a fun learning experience for sure. I’m thankful for all the resources out there! My son’s 79 TA is next .
lou_dias
Report this Post03-08-2023 10:17 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you buy those headers or make them?
TheDigitalAlchemist
Total ratings: 94
Report this Post03-08-2023 01:33 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Congrats, enjoy the ride!
da.slyboy
Report this Post03-08-2023 02:05 PM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was changing the springs needed for the 1.6 roller swap or something you decided to do while apart?
Notorio
Report this Post03-09-2023 11:58 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
And, how do you plan to get them past the smog police???
Dccarguy05
Report this Post03-11-2023 08:43 PM Click Here to See the Profile for Dccarguy05Send a Private Message to Dccarguy05Edit/Delete MessageReply w/QuoteDirect Link to This Post
Headers and crossover pipe are from Chris at West Coast Fiero’s . I decided to put a bigger Crower cam in the 3.4 block with the Fiero store SI valves and Crower’s springs & hardware package together with Summit’s 1.6 roller rockers. The block is bored & decked with high compression pistons and chrome moly rings. Believe it or not passed California smog with no problems! It runs and drives great but has a idle search problem only when cold tho.
R Runner
Total ratings: 98
Report this Post03-12-2023 05:51 AM Click Here to See the Profile for R RunnerSend a Private Message to R RunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
It looks like are really nice build. Congratulations on getting it complete. You have won a battle many of us struggle with.
Dccarguy05
Report this Post03-15-2023 04:43 PM Click Here to See the Profile for Dccarguy05Send a Private Message to Dccarguy05Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you! Trying to get my interior back to better than new now 😎 looking for a parking brake kick panel in Beechwood has been no luck ☹️
Report this Post03-15-2023 05:57 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm a little surprised you haven't edited/fixed your opening post, but the info is still Here if you wish to make use of it.
Notorio
Report this Post03-23-2023 11:03 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
The conventional wisdom is that higher compression increases NOx. Would you mind posting your smog report? There are at least two of us currently struggling to get our nearly-stock 2.8s to Pass, due to high NOx.
Add-on ... are the West Coast Fiero headers smog approved and have a sticker?? I don't see how these could otherwise pass Visual Inspection.
[This message has been edited by Notorio (edited 03-23-2023).]
