  DAGNABIT ! How do I use the Pennocks search engine
DAGNABIT ! How do I use the Pennocks search engine by JT CROWNS
Started on: 04-21-2023 05:51 PM
Replies: 15 (379 views)
Last post by: Australian on 05-09-2023 08:00 AM
JT CROWNS
Report this Post04-21-2023 05:51 PM Click Here to See the Profile for JT CROWNSSend a Private Message to JT CROWNSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tried all the permutations of
four speed will not shift into reverse
and get "no results"
I know I'm as dumb as a rock, but...
Thanks in Advance - JT
[This message has been edited by JT CROWNS (edited 04-21-2023).]
flimbob
Report this Post04-21-2023 06:08 PM Click Here to See the Profile for flimbobSend a Private Message to flimbobEdit/Delete MessageReply w/QuoteDirect Link to This Post
shift in reverse
Rick Vanderpool
Report this Post04-21-2023 06:21 PM Click Here to See the Profile for Rick VanderpoolSend a Private Message to Rick VanderpoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just put "reverse" in the search box and look through the results.
Report this Post04-21-2023 07:10 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Within five seconds, I found 19 potential hits using shift into reverse
Cliff Pennock
Administrator
Total ratings: 699
Report this Post04-23-2023 04:37 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
A good place to start, is reading the Search Help page. PFF's search is a bit finicky, but once you get the hang of it you should be able to find what you want.
Another way to search PFF, is by using Google Seach. Just type your search query as you would normally do on Google, but at the end, write "site:.fiero.nl". It will then only search through pages on fiero.nl. There's one downside however, and that's that Google has only indexed 30,000 pages or so. PFF search will search through all 1,000,000+ pages.
I'm not sure why Google only has about 30,000 pages in its index. It used to have well over 500,000 pages indexed but that number drops almost daily. Looking at Google's Webmaster page, it tells me it simply hasn't indexed those pages yet. So there are no issues with those pages, it just hasn't come around to indexing them. Which is weird because they were indexed in the past. Google works in mysterious ways, I guess.
Report this Post04-23-2023 08:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suspect a lot of users simply don't click on the two dropdown boxes, and end up only ever searching through Subject/Username in All Active Forums. This unfortunately eliminates a lot of information!
Another way to search PFF, is by using Google Search. Just type your search query as you would normally do on Google, but at the end, write "site:.fiero.nl". It will then only search through pages on fiero.nl
Cliff, is it even necessary to include "site:."? When I do a Google Search, I just use "fiero.nl" (along with whatever words/phrases I'm looking for), and it seems to do the trick.
I'll also add that Google Search is excellent for trying to find images that have been posted in the forum.
[This message has been edited by Patrick (edited 05-24-2023).]
fierosound
Total ratings: 286
Report this Post04-24-2023 07:57 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed. Google is the easiest way I can find pictures I know I have posted somewhere on PFF.
Total ratings: 403
Report this Post04-26-2023 10:05 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I miss my Fiero, this probably due to the cables stretching and the shifter is out of adjustment.
See you don't need to search just ask and someone will tell you. Or they will search for you and call you a dumb ass.
But end of the day you have an answer.
Report this Post04-26-2023 10:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your response is rather odd... especially considering the heading of this thread, as given by the OP.
DAGNABIT ! How do I use the Pennocks search engine?
Total ratings: 403
Report this Post04-27-2023 02:18 AM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull the stick out of your ass, its a joke.
Report this Post04-27-2023 02:21 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, you're a laugh a minute.
Total ratings: 403
Report this Post04-27-2023 10:06 AM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm here all week.
JT CROWNS welcome to the forum. Perhaps you could post your question in the TQ section as well.
qwikgta
Total ratings: 84
Report this Post04-28-2023 08:35 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
start your search in Google with this. site:.fiero.nl then put what ever you want to search after the .nl with a space. like this
site:.fiero.nl 3800
site:.fiero.nl engine swap
site:.fiero.nl shift reverse
works every time.
Rob
IMSA GT
Total ratings: 253
Report this Post04-28-2023 09:32 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
And once again, where is the OP?
Total ratings: 403
Report this Post05-05-2023 06:56 PM Click Here to See the Profile for Jake_DragonSend a Private Message to Jake_DragonEdit/Delete MessageReply w/QuoteDirect Link to This Post
One post, I hope he found what he needed.
My 4 speed was a bear, I managed to adjust the shifter and added a "helper" spring and it functioned pretty well after that.
Backup lights didn't work all that great because the switch alignment was off due to the cable stretch.
Some people just would rather not interact, perhaps he rage quit and was just posting this before he left.
Australian
Report this Post05-09-2023 08:00 AM Click Here to See the Profile for AustralianClick Here to visit Australian's HomePageSend a Private Message to AustralianEdit/Delete MessageReply w/QuoteDirect Link to This Post
Type in DAGNABIT and you will find this thread.
