  Gen-Z-Garage - Replacing the Fiero Sending Unit!
Gen-Z-Garage - Replacing the Fiero Sending Unit! by 82-T/A [At Work]
Started on: 04-30-2023 08:20 PM
Replies: 4 (557 views)
Last post by: 82-T/A [At Work] on 05-08-2023 02:27 PM
Report this Post04-30-2023 08:20 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Fourth episode, thanks for watching!
Total ratings: 465
Report this Post05-01-2023 01:55 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The lavalier mic sounds good... although your daughter will need to refrain from pounding her chest (00:01) while being recorded.
And thanks for the info on the shaker siphon. I'll never have to buy gasoline again!
[This message has been edited by Patrick (edited 05-01-2023).]
Report this Post05-01-2023 02:21 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't see if has same pads on the tank to install...
Tank pads keep space between tank and car and stop noise as tank grows/shrinks some for heat cycling etc. Plus the pad are can shape some for uneven spaces.
armos
Report this Post05-05-2023 05:48 PM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Sending unit" is ambiguous. The words "fuel level" or "gas tank" should probably be in the title somewhere.
Report this Post05-08-2023 02:27 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, it sucks... we couldn't find replacement pads, but the original ones are still on there, they just got painted over.
We put some adhesive felt padding on top of them to give back a bit more cushion for the (2) pads that are on the tank before we re-installed it. I "think" you can see that when she's sliding the tank under the car... but not sure.
Yeah, thanks for that. That mike has made all the difference in the world, seriously!
Yeah, it kind of is... we put all of those words in the "tag words" section of the video (which you can't see, but it references it in search). But yeah, I struggled with that. I may change it later, but really the focus is just on getting this car done before the summer.
We picked up my engine hoist and engine stand from my storage unit this weekend... so we're going to pull the motor later this month.
[This message has been edited by 82-T/A [At Work] (edited 05-08-2023).]
