  New Owner and Member
New Owner and Member by Spartan467
Started on: 08-23-2023 01:16 PM
Replies: 9 (512 views)
Last post by: Mickey_Moose on 08-29-2023 05:02 PM
Spartan467
Report this Post08-23-2023 01:16 PM Click Here to See the Profile for Spartan467Send a Private Message to Spartan467Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello,
I just purchased an 87 GT fiero a few days ago and wanted to say hi on the forum. It’s got 78k miles, 2.8 with a 5-speed. I think it’s Getrac, but I’m not sure how to verify which 5-speed it is.
My current plans are to clean it up. It’s in incredibly working condition with all driving components and interior in almost perfect shape. A lot less of a project than I thought it would be. Needs paint. I plan on taking the doors apart to change outer dew wipes (new ones came with the car) and to do something about the window motors. Passenger needs a lot of help to roll up all the way and it won’t roll down all the way either. Both are super slow to go anywhere. (Could be a switch problem, as I’ve heard).
Anyways, hoping to do a suspension refresh and an 88 cradle swap if possible. Engine swap is on the table for the future (1yr +)
I’m 23 if that’s important. (That is not me in the pictures included)
-Matt
[This message has been edited by Spartan467 (edited 08-24-2023).]
fredtoast
Report this Post08-23-2023 01:37 PM Click Here to See the Profile for fredtoastSend a Private Message to fredtoastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice wheels too.
Be sure to get underneath and check for rust. Plastic cars might not look rusty but the frame/suspension could be rotten with it.
From the looks of that car I doubt rust is a problem, but you never can tell.
Spartan467
Report this Post08-23-2023 01:51 PM Click Here to See the Profile for Spartan467Send a Private Message to Spartan467Edit/Delete MessageReply w/QuoteDirect Link to This Post
I haven’t had a chance to lift the car yet, but none of the metal I can see by crawling around on the ground looks rusted. Frame components look good and the suspension components I can see from the wheel wells also look good. The only rusty thing I could find was surface rust on the decklid/engine compartment latch. Rust usually isn’t a big thing here in Texas since we don’t have salted roads.
I will be sure to take a look when I get the chance.
Vintage-Nut
Report this Post08-23-2023 03:01 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum and our addictive hobby.....
Spartan467: I haven’t had a chance to lift the car yet...
When you have the chance to lift the car; one area to inspect is the Engine Cradle for rust damage.
A lot to do when replacing the glass seals (a.k.a. dew wipes) like:
New Felt Window Guides
Look at the window regulator rollers (grease/replace) and clean the tracks
Grease motor gears to the regulator
Clean all the electrical contacts!
Include to clean the Power Window Switches and I suggest Rodney Electric Window Helpers too...
http://rodneydickman.com/pr....php?products_id=271
Dig into the PFF 'Search' feature and find the hiding 'gold' information inside....
[This message has been edited by Vintage-Nut (edited 08-23-2023).]
Report this Post08-23-2023 06:47 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Spartan467:
87 GT... 2.8 with a 5-speed. I think it’s Getrac, but I’m not sure how to verify which 5-speed it is.
If it's the original transmission, it's a Getrag. One way to identify it, is that the select (side to side) cable sticks more or less straight up in the engine bay under the grill (which unfortunately then allows rain water to enter the end of the cable and eventually corrode the innards).
By the way, the way to avoid image URLs from becoming corrupted (like your third URL), is to hit Enter twice between image URLs when posting. You can fix this in your post by using the EDIT function, do as I suggested with the Enter key, and removing the gap introduced in your corrupted URL.
[This message has been edited by Patrick (edited 08-25-2023).]
fierosound
Total ratings: 286
Report this Post08-25-2023 11:09 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome aboard Matt
EDIT your post so pics are on separate lines and a blank like apart like this
[IMG]https://images.fiero.nl/userimages/Spartan467/71409537917__33925C7F-006E-4763-B03B-5DF4E4E94A7F.jpeg[..IMG]
[IMG]https://images.fiero.nl/userimages/Spartan467/71409540037__C295786A-831F-4BF6-9B8E-ADB53FF3CBCB.jpeg[..IMG]
[IMG]https://images.fiero.nl/userimages/Spartan467/71409540888__1377624E-7061-41A9-A1B9-4C77E987F8FF.jpeg[..IMG]
[This message has been edited by fierosound (edited 08-25-2023).]
Report this Post08-25-2023 05:25 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
EDIT your post so pics are on separate lines and a blank like apart like this.
Just to expand on what you've posted...
I suspect that people posting/viewing this forum on their phones only see one image at a time and don't/can't appreciate the value of hitting the Enter key twice before and/or after each image URL.
CoolBlue87GT
Total ratings: 150
Report this Post08-26-2023 12:39 AM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Matt, Welcome, nice ride.
[This message has been edited by CoolBlue87GT (edited 08-26-2023).]
Report this Post08-29-2023 08:02 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the hobby. Nice acquisition. I would not recommend that you change the cradle for an 88. The work vs the reward becomes the question. I have rear sway bars on my Fieros and the difference between what I have and the 88 IMO is not that large but of course decide for yourself.
Mickey_Moose
Total ratings: 145
Report this Post08-29-2023 05:02 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
This - I also would not recommend installing the 88 cradle. Just solid mount the 87 cradle and new bushings (if required). Also if you want install a rear sway bar.
The headaches with dealing with hard to find (or expensive) 88 parts does not justify it. I own a 88 so know of the downfalls, I also had a 86 where I rebuilt the suspension and solid mounted the cradle and it performed just as well on the slalom track - in fact I actually preferred the 86 in this case.
