  Brand new CraneCams H-272 camshaft and lifters! (Page 2)
Brand new CraneCams H-272 camshaft and lifters! by 82-T/A [At Work]
Started on: 10-31-2023 07:47 AM
Replies: 49 (799 views)
Last post by: sleek fiero on 11-23-2023 11:11 AM
lou_dias
Report this Post11-16-2023 06:12 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Re: DAWG mod
I had mine done at a local machine shop. It's not rocket science once you show someone a picture of what you want done.
Total ratings: 200
Report this Post11-16-2023 07:45 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's called the Dawg mod, named after the person who documented it:
https://www.westcoastfieros...ntake_topic1806.html
LOL, that makes total sense now. I assumed it was some kind of acronym.
Originally posted by lou_dias:
Re: DAWG mod
I would be all over this myself if I knew how to weld in aluminum... (back on that). I think I may still try. I don't need the enormous throat like he did, but I do want to increase it near that major pinch point. I want to retain the EGR tube connector, and properly fit the vacuum line. Something I can fiddle with in the future. But I already have a ported throttle body, and port-matched (and blended) to an 87+ intake... just need to open up the neck now.
MarkS
Report this Post11-17-2023 07:51 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Re: DAWG mod
A few years ago, I saw a version of the Dawg mod offered on ebay. That did have the EGR port retained but wasn't sure the of its quality.
Total ratings: 200
Report this Post11-18-2023 03:25 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I just got my CamSaver lifters, and I finally get "how" they provide oil to the bottom. I kept thinking there would be a hole in the bottom like some of the others, but in this case they machined a very small part of the lifter along the side vertically, so that oil will shoot through there and onto the cam. It's only BELOW the oil ring groove, so it won't also shoot oil up into the galley (other than through where it's supposed to... via the pushrod). So that makes perfect sense now... and much better than me modifying the lifter hole I think.
lateFormula
Report this Post11-20-2023 08:28 AM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Regarding the Dawg mod:
While you might want to try it yourself; if you are not a seasoned, experienced welder, you should take this to a professional. The manifold is a primitive sand casting and has a fair amount of porosity. What this means is that the manifold has a fair amount of trapped air within the metal. If you were to start grinding on an intake, you would find tiny round voids in the metal. That is porosity, and that is problematic for welding.
Also here's another tip. You will want to buy a length of 3" ID aluminum tube with a wall thickness of 3/16" or 1/4". Then go online to find and buy a few cardboard shipping tubes that are 3" in diameter. You can cut the cardboard tube to fit against the manifold, and if you have enough length, or enough cardboard tubes, you can try different lengths and sizes on the manifold. But once you have a section of cardboard tube that matches up to the surface of the manifold, and will open the restriction where the neck of the manifold meets the plenum, then you can use that piece of cardbaord as a template to mark the manifold as where to cut it away. Then you can also use the cardboard as a template on the aluminum tube to cut and shape it, although you won't want to cut right up to the marked line, you'll need to cut close to the traced line (like 1/8"-1/4") and then do a fine shaping of the edge profile of the aluminum tube with a sander - think tabletop belt/disc sander.
Total ratings: 200
Report this Post11-21-2023 11:22 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Formula... I can definitely weld, but do not have the tools, etc., for aluminum welding... so that's definitely the route I'm going to take. Quick question... where exactly would I get a 3" aluminum tubing like that? The only thing I can think of is Home Depot and they really only have stuff for fence poles. Would a metal fabrication shop have this stuff? I'll go with thicker to increase the strength of the plenum neck. I should be able to get it just right so that it fits perfect before I take it in to a welder.
Thanks!
MarkS
Report this Post11-22-2023 08:57 AM Click Here to See the Profile for MarkSSend a Private Message to MarkSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
Try these guys-
https://www.mcmaster.com/pr...material~aluminum-2/
lateFormula
Report this Post11-22-2023 09:50 AM Click Here to See the Profile for lateFormulaSend a Private Message to lateFormulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let Google be your friend to find things like this. A quick search only found me a couple examples. If I spent more time, I could find lots of options for tubing that can be purchased in small quantities.
This one has wall thickness of 1/8", which might be risky for welding, as I'm pretty sure that due to the porosity in the cast manifold that a welder would need to make two passes all the way around to get a good weld. With this thickness, it is possible that a hole could be burned in the tubing while welding. https://www.speedymetals.co...061-t6-aluminum.aspx
These next two options are tubing with 1/4" wall thickness, but different ID/OD:
https://www.onlinemetals.co...6-extruded/pid/10447
https://www.onlinemetals.co...6-extruded/pid/21831
These two sellers don't offer tubing with a 3/16" wall thickness (0.1875") but it may be available out there from another supplier.
lou_dias
Report this Post11-22-2023 02:57 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
EGR in an engine is like going thru life as a chain smoker.
If you like your internals clean, get rid of EGR and PCV. I just put those little breather air filters on my valve covers... When my motor gets taken apart, my intake and intake ports on the heads are squeaky clean.
[This message has been edited by lou_dias (edited 11-22-2023).]
sleek fiero
Report this Post11-23-2023 11:11 AM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou;
don't get rid of PCV. It does several good things such as removing combustion moisture from your crankcase. It also maintains a slightly negative pressure in our crankcase which gives you longer seal and gasket life. also it will help reduce oil consumption at your valve seals and piston rings. sleek
