  Water pump Replacement advice? (Page 2)
Water pump Replacement advice? by Kitskaboodle
Started on: 05-13-2024 03:45 PM
Replies: 46 (825 views)
Last post by: Anthony196 on 06-12-2024 06:28 PM
Kitskaboodle
Report this Post05-30-2024 03:21 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update: Water pump is in and no leaks! 😀
This job was a pain but at least I learned a lot. When/if I have to do this same job again on my 86 GT, I got it down.
One big word of advice I have that nobody mentioned is…., it helps to test fit (without any sealer or the gasket) how it goes on the engine. It’s tight quarters down there and you don’t want to bump into stuff, disturb the gasket, etc.. while you got sealant all over the water pump and gasket l. Also, once you have it in position on the block, you want to avoid having to re-position it.
Lastly, I ran the engine while the back end was up in the air and checked for leaks before finishing the job. Kit
[This message has been edited by Kitskaboodle (edited 05-30-2024).]
Vintage-Nut
Report this Post05-30-2024 10:02 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome - Well Done!
Now is the time for an adult beverage and relax.....good job!
Kitskaboodle
Report this Post05-30-2024 10:09 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you.
Yes, I already had two Rolling Rocks today.
I do need to take a nap though……😀
Kit
Total ratings: 465
Report this Post05-30-2024 11:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well geez Kit, that's a given!
Congrats on getting the job done successfully.
Kitskaboodle
Report this Post05-30-2024 11:30 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Patrick. 😌
Now on to an even more difficult project: making 1990 Buick Regal rear struts work in the back of a Reatta. Kit
Total ratings: 328
Report this Post06-12-2024 03:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some great tips here and I believe that they covered it all. The only thing I can add when you work on the water pump side is to make sure that you tape plastic ( garbage bags) over the fiberglass liner material in the engine compartment where you work. If you don't be prepared to suffer some serious itching afterwards.
Anthony196
Report this Post06-12-2024 06:28 PM Click Here to See the Profile for Anthony196Send a Private Message to Anthony196Edit/Delete MessageReply w/QuoteDirect Link to This Post
Man, I wish I had read this thread before I ordered that same Gates water pump that claimed to have the cast iron impeller.
Thanks for the Bosch part number. I just ordered on Ebay, hope it arrives by Saturday!
