  trunk carpet removal.
trunk carpet removal. by richard in nc
Started on: 06-24-2024 07:15 PM
Replies: 10 (211 views)
Last post by: richard in nc on 06-27-2024 07:24 PM
richard in nc
Report this Post06-24-2024 07:15 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
i think my 2.5 head gasket may be blown so i was wondering if the trunk carpet is glued down?it seems standing in the trunk may be the best way to work on the engine.
Report this Post06-24-2024 07:32 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you taken the 30 seconds it might take to check for yourself?
And how would the carpet being glued down (I'm not saying it is) prevent you from standing in the trunk?
No offence Richard, but seriously, I think you're being a little more helpless than necessary.
Vintage-Nut
Report this Post06-25-2024 09:05 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
As Patrick said:
101 - Identify and Determine the Problem - Don't 'Guess'
Our advice is to put the effort to 'know' IF you HAVE a head gasket problem or not.....
How to Check For A Blown Head Gasket In Your Car
https://mechanicbase.com/en...ead-gasket-is-blown/
And "yes", standing in the trunk sometime is the best way to work on the engine; I cover the carpet with thick towels.
David Hambleton
Report this Post06-25-2024 10:01 AM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lol! Note Richard's occupation in his profile...
richard in nc
Report this Post06-25-2024 02:44 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
tell me how to see if the headgasket is blown in 30 seconds.and i thought it was obvious that i wanted to remove the carpet so i didn't damage it.its dumping clouds of white smoke out of the exhaust.i assume its the head gasket but i thought maybe something might have thrown the fuel mixture way off.
[This message has been edited by richard in nc (edited 06-25-2024).]
richard in nc
Report this Post06-25-2024 03:00 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
richard in nc
Member since Jun 2023
helpful link.
Vintage-Nut
Report this Post06-25-2024 03:34 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
You Are Most Welcome!
Report this Post06-25-2024 03:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
??? See below!
LOL... The heading of this thread is trunk carpet removal. I was simply referring to your inquiry (copied below) as to whether or not the trunk carpet is glued down. Determining if the head gasket is blown might possibly take a little longer than 30 seconds.
[This message has been edited by Patrick (edited 06-25-2024).]
Report this Post06-25-2024 03:50 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Apr 99
He might be pushing the limits.
David Hambleton
Report this Post06-26-2024 08:37 AM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Richard!
In all seriousness, I've had head gaskets go among a Corolla, 2 on 1928 and 1929 Ford Model A engines and 3 on Fieros over about 50 years.
One cloud producing failure was the 1984 2.5L thin block cracking problem resulting in a GM recall warranty complete engine replacement at 102,000 km in 1987.
Symptoms have ranged from steam from deck vents, white clouds from the exhaust and diminishing coolant level with no other evidence.
This was the latest Fiero incident: https://www.fiero.nl/forum/Forum2/HTML/146435.html
I drape an old blanket over and in the trunk so I can climb in and out and kneel on the ledge while protecting the lights, paint and carpet in the area.
richard in nc
Report this Post06-27-2024 07:24 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Richard!
i have a rare five speed ford areostar with the 3.0.it also has a blown head gasket.i really liked it but with the engine jammed into the bottom of the dash its beyond my ability to fix.the shop manual says to drop the engine out the bottom.
