  Fiero headrest speakers
Fiero headrest speakers by Wichita
Started on: 07-03-2024 12:25 PM
Replies: 8 (264 views)
Last post by: 82-T/A [At Work] on 12-07-2024 10:16 PM
Wichita
Total ratings: 322
Report this Post07-03-2024 12:25 PM Click Here to See the Profile for WichitaSend a Private Message to WichitaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are the headrest speakers on the Fiero considered good quality, even if they are OEM?
I'm about to recover the seats and have been contemplating either upgrading/replacing the speakers or keeping them factory.
They sound good to me, but maybe wondering if aftermarket makes a big difference in sound quality and what really works with them being close to your ears.
Many thanks for any advice or input.
cvxjet
Report this Post07-03-2024 03:31 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think they sound good- but, although I am a "connoisseur" of music, I have never been a fanatic about great audio quality. Years ago I replaced the speakers with some nice ones from a company located in the Sacramento area...they were specifically for Mazda Miatas, but came with an adapter plug to fit Fieros.
I suspect that the company has gone under- but Crutchfield may sell replacements....
hyperv6
Total ratings: 93
Report this Post07-03-2024 03:48 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
They are good but old. They could lose a cone. I would look for a suitable replacment before putting on new covers.
1985 Fiero GT
Report this Post07-03-2024 05:20 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've loved mine, and for being gm speakers, they are really high quality, cloth surrounds, so they don't rattle like the dash speakers after all these years, but they are pretty limited, no really high treble, no bass, limited volume, etc. I put in a set of pioneer 4" 2 ways, with a metal grill and some cotton over top to provide padding (grill and padding reduced volume a good bit, but not clarity) they aren't the best speakers, but for the price, much better than OEM, they vibrate the seat with the bass, and the treble is great, but not ear piercing. I wired the 2 seats in series instead of the factory parallel, so the ohms match up for the radios sake (new ones are 4 ohms, factory is 10)
IMSA GT
Total ratings: 250
Report this Post07-03-2024 06:02 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is key when using a factory deck. You could fry the factory GM decks if the ohms are too low. Aftermarket decks are sometimes safe down to 2 or even 1ohm.
1985 Fiero GT
Report this Post07-03-2024 07:55 PM Click Here to See the Profile for 1985 Fiero GTSend a Private Message to 1985 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, volume stayed balanced with the wiring change (until I added the grills and cotton haha, then it has to be adjusted rearwards), I added wiring between the 2 seats, and wired it to the drivers side connector, so I didn't touch the in car wiring, just added a breakout from the drivers side for the passenger side to connect to.
Report this Post07-04-2024 10:11 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
When the head/radio is only made for 4 speakers, GM etc often "use tricks" to have more speakers on an output like the 84 Fiero Seat Speakers.
OE Seat speakers are 10Ω because wiring in parallel is 5Ω to the head. Plus speakers that close to ears doesn't need same output as other speakers.
When wire low Ω like 4Ω in Series the Output is ~ ½ like sim to HL in Series as DRL is ~ 50% bright but the Head see 8Ω so Output now maybe ⅓ of output.
The main point is seat speakers give "true stereo" to mid range tones to the people so can each hear way better & @ lower volume.
Vs.
Later B pillar speakers if set so Driver gets Stereo the passenger gets "hammered" by right channel & often sounds like crap to them.
GM likely stop installing the first because of high cost for them.
Speakers can "die" just sitting in storage for years. More so w/ Foam Surround types but Paper often fails or gets brittle in storage & fails fast when use.
Dash speakers get Heat & UV from Sun & most speakers Hate this, aftermarket more so, & will have problems often in < 5 years, many < 1 or 2 years, but may not Hear the problems depending how loud you use them.
High tones are often lost in most vehicles for many reasons even if the Speakers can generate them. You bury a speaker in a Seat, you loose a lot of high tones just by the OE seat cover, worse if added aftermarket covers. High Tones are more directional, can boucne off Hard stuff but easily block by other things. (About same as comparing 2.4GHz to 5GHz now 6GHz WiFi that later can't go thru walls etc like lower freq.)
< 200-300 Hz is better handle w/ larger speakers like Dash speakers in Fiero even ignoring Sub Base.
OE iMac G3 & more have small speaker w/ "big sound" but often they "Played Tricks" to get that sound. Even when you take iMac speaker w/ the small ball case out & try to use on other things, won't sound same because whole machine was design to have this speaker set. Same for Bose & other small speakers only sound right w/ OE case.
[This message has been edited by theogre (edited 07-04-2024).]
IMSA GT
Total ratings: 250
Report this Post07-04-2024 01:21 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hell, just do 1 speaker per head rest at 4 ohms like this guy did
[This message has been edited by IMSA GT (edited 07-04-2024).]
Total ratings: 200
Report this Post12-07-2024 10:16 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
If, like me... you're looking for the wiring diagram ... specifically to tell you positive and negative for the seat wires in the 84-85 seats... I found this from E.Furgal in a post he made several year ago. Reposting it to this post...
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Note, the wire colors matched up perfectly to this. I wanted to make sure I wired my headrest speakers in the correct phase (and not backwards).
