| quote | Originally posted by fierofool:
It's listed as TUBE, ENG AIR HT STOVE
The GM part number is 10045291.
Awesome, thank you FieroFool! I found this:
https://www.amazon.com/dp/B0BS13HLMGIt's 42mm... about the closest I could find (real measurement is around 40mm interior diameter). So, I'm thinking it should fit. It's about as close as I'm going to get. I'll need to cut it short, but it should work fine. My daughter is using the 88 exhuast manifold, rather than the tube that attaches to the exhaust piping... makes it a bit easier (and shorter length).
Thanks!!!
