  5 spd Formula wont shift into gear
5 spd Formula wont shift into gear by fierofrenzy
Started on: 08-17-2024 05:04 PM
Replies: 10 (222 views)
Last post by: Frenchrafe on 08-22-2024 03:26 AM
fierofrenzy
Report this Post08-17-2024 05:04 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welp, after 24 years of dependability with my 88 Formula , it looks like I may have quite a problem here. Sure hope im wrong. Let me start by saying this car sits for months at a time inbetween driving it due to my busy schedule. But every time I go to start her back up, shell start without even cranking. Just fires right up. But many a time due to it just being parked, it wont shift into gear . I'll have to bleed the hydralic system, then it will shift fine. This time i cannot get the car to go into gear from start up. I put in a new slave cylinder and bled it very well. I can see the tranny lever moving back and forth more then it ever seemed to do. Just wont go into gear. I even tried putting it into 1st with the car off, then pushing the pedal all the way down. When i turned the key the car jumped like the clutch was fully engaged. Anyone have a simular problem, or have any advise ? Im thinking about taking out the starter motor and hoping to be able to ( barely ) see if the clutch plate is releasing. I dread to think about dropping the cradle for this indepth job of replacing the clutch. ( This Formula was completely rebuilt by none other than the very well know Jim Gilbert RIP. ) I miss him extremely.... what a wonderful person.
Report this Post08-17-2024 05:38 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's not telling us very much. How much is it moving exactly? Use a ruler or tape measure.
Since your car sits for extended periods of time, it's possible your clutch disc has rusted to the flywheel. It's been posted here a few times over the years how to break it free.
fierofrenzy
Report this Post08-17-2024 08:28 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
its moving a considerable amount more then when the car shifted fine, meaning it show be able to shift into gear fine. Ive been back there enough to know that. Can you lead me to the links instructing how to free up clutch disk from pressure plate ?
fierofrenzy
Report this Post08-17-2024 08:30 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierofrenzy
Member since Nov 2006
Correction on that... clutch disk from flywheel
fierofrenzy
Report this Post08-17-2024 08:50 PM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierofrenzy
Never mind... I found an extensive post on " Clutch wont release". I apply these methods to hopefully solve my problem.
CoolBlue87GT
Total ratings: 150
Report this Post08-18-2024 12:20 AM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Years ago I had a problem with my 5 Speed, I was not able to engage reverse or 5th gear. Turned out one of the two the shifter cables actually broke.
CLICK FOR FULL SIZE
[This message has been edited by CoolBlue87GT (edited 08-18-2024).]
Kitskaboodle
Report this Post08-19-2024 07:56 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
How’s your clutch pedal arm? As you know, they’re easily bent and may be contributing to your engaging/ disengaging issue.
Kit
fierofrenzy
Report this Post08-21-2024 09:41 AM Click Here to See the Profile for fierofrenzySend a Private Message to fierofrenzyEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIXED !!!! Just wanted to follow up with the outcome of my shift into gear problem. Once again , FIXED ! After many tries bleeding the system, and seeing the large amount of travel in the clutch lever, I just had a very strong feeling that the clutch disk was corroded to the flywheel. My hunch turned out to be correct. I jacked the back wheels off the ground, supported the car with MANY jackstands, then started the engine with the car shifted into first. Of corse the rear wheels will spin because of the frozen clutch. In just a moment i heard a loud "clunk" ( for lack of better words) . I shut the car off and took it out of gear. I then started her up in neutral, pushed in the clutch pedal, and the car simply shifted into gear. I went thru all the gears, and the car shifted fine. Took the car off the jacks, drove it around town, and alls good. So foranyone struggling with a " Cant get the car into gear" issue, trying out this somewhat simple remedy may be your answer. Jst be VERY SAFE with the car running in gear. Thanks to all who commented.
Report this Post08-21-2024 04:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your "hunch"?
Report this Post08-21-2024 10:30 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIXED !!!! Just wanted to follow up with the outcome of my shift into gear problem. Once again , FIXED ! After many tries bleeding the system, and seeing the large amount of travel in the clutch lever, I just had a very strong feeling that the clutch disk was corroded to the flywheel. My hunch turned out to be correct. I jacked the back wheels off the ground, supported the car with MANY jackstands, then started the engine with the car shifted into first. Of corse the rear wheels will spin because of the frozen clutch. In just a moment i heard a loud "clunk" ( for lack of better words) . I shut the car off and took it out of gear. I then started her up in neutral, pushed in the clutch pedal, and the car simply shifted into gear. I went thru all the gears, and the car shifted fine. Took the car off the jacks, drove it around town, and alls good. So foranyone struggling with a " Cant get the car into gear" issue, trying out this somewhat simple remedy may be your answer. Just be VERY SAFE with the car running in gear. Thanks to all who commented.
Running your engine with the transmission engaged while the wheels are off the ground is not a good idea. The unsprung strut/springs will allow the axles to drive the wheels at a sharper angle than when the car is driven. This could cause the CV axle boots to rip or tear. The proper way to do this is to rest the car on the support arms while testing so that the axle stays as straight as possible.
Frenchrafe
Report this Post08-22-2024 03:26 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm in here too late!
Rusted clutch was my call as well.
I had this happen to me with a 2CV when I was young.
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero
https://youtu.be/hUzOAeyWLfM
