  Washing Engine
Washing Engine by hunter29
Started on: 08-22-2024 05:32 PM
Replies: 23 (345 views)
Last post by: hyperv6 on 08-28-2024 07:49 AM
hunter29
Report this Post08-22-2024 05:32 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is it safe to wash down the engine with a gentle spray of water?
Report this Post08-22-2024 05:38 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't. There's never any shortage of people who have ignition problems after getting water in their engine bay.
[This message has been edited by Patrick (edited 08-23-2024).]
Vintage-Nut
Report this Post08-22-2024 05:50 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Like many engines, the main keys are the 'pressure'; covering the distributor/sensors/exposed wiring/etc. and always with a cold motor; never 'spray' water on a hot engine!
Edit
I believe you want to wash the engine because oil leaks....
*Use a degreaser {mainly below the heads} / soak it / rinse the engine with very low-pressure water {avoid excessive pressure} / remove any covers you put on and warm the motor to dry it or drive it a few miles...
[This message has been edited by Vintage-Nut (edited 08-22-2024).]
hunter29
Report this Post08-22-2024 11:03 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Still chasing oil leaks, the oil is down below. Think its more than the O ring.
I live in a high dust environment, dirt road. My car will get dirty just sitting in the garage with the doors shut.
I wipe things down but water would work better for all the small stuff . Not keen on the idea thou..
[This message has been edited by hunter29 (edited 08-23-2024).]
Total ratings: 259
Report this Post08-23-2024 06:58 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I pressure wash my engine bay all the time. Hot or cold, doesn't matter. It is a later model swap, but I also did is back when I had a 2.8.
If this causes an issue, find it and fix it so it doesn't leave you stranded when driving in heavy rain.
Total ratings: 206
Report this Post08-23-2024 09:18 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same here, I hit it with the pressure washer with no problems.
Sage
Total ratings: 71
Report this Post08-23-2024 08:25 PM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Times 3.....I just don't "aim" for any electrical items! Plastic bags works for covers on coil, dist, etc.. Common sense win out (hopefully!)
HAGO!
Report this Post08-23-2024 09:01 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Sage:
Common sense wins out (hopefully!)
You'd think/hope so, but...
Total ratings: 329
Report this Post08-23-2024 09:01 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hose wash with soap a parts brush and just keep the flow away from the distributor ( coil pack on my swap) breather and C500 connector. Connectors are typically waterproof but if soap gets in there could be problems. I don't believe that you have to worry about plain water. Did you ever look at the engine after driving in a rain storm. Stop at a light and everything gets soaked. Get going again and the air flow gives the engine a wet-down.
Total ratings: 154
Report this Post08-24-2024 02:18 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wash my stock 2.8 and my DIS 3.4 with engine cleaner and a garden hose adjusted to a light fan spray. I've never protected any particular part and have had no problems. Not saying it couldn't happen, though.
steve308
Total ratings: 57
Report this Post08-24-2024 02:49 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
I 'wash' my engine using a pump up garden sprayer. The wand allows me to reach the areas in and around the distributor and other areas that should not be soaked with water. I wash with a degreaser like 'spray nine'. The combination of the directed spray and cleaner does a great job. I have a second garden sprayer with water that i follow up to rinse the degreaser off. I use a leaf blower to dry.
jelly2m8
Total ratings: 243
Report this Post08-25-2024 03:58 AM Click Here to See the Profile for jelly2m8Send a Private Message to jelly2m8Edit/Delete MessageReply w/QuoteDirect Link to This Post
This^^
jonrev
Report this Post08-26-2024 04:46 PM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
I only spray the transmission bell housing; removing the rear plug wires (V6), coil/shielding and intake tubes helps. Grocery bags over the top end, distributor and any openings. Dry any pool spots with a leaf blower. Reassemble and do the rest by hand, I use RAM cleaner, 303 Protectant and plain 'ol detail spray.
[This message has been edited by jonrev (edited 08-26-2024).]
Report this Post08-26-2024 05:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm beginning to think I'm the only member of this forum with a less than pristine looking engine. lol
hyperv6
Total ratings: 94
Report this Post08-26-2024 05:28 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
It just takes some common sense. No hard pressure. Use greased lighting and brushes. I have cleaned mine yearly since new.
This is not like some new engines with aluminum issues and more electronics.
I also use aluminum steamers and a hose nozzle with a soft shower mode. I blow dry with my master blaster airforce blow dryer.
[This message has been edited by hyperv6 (edited 08-26-2024).]
hunter29
Report this Post08-26-2024 05:37 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is that an egr valve ?
hyperv6
Total ratings: 94
Report this Post08-26-2024 06:28 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
EGR with GM cover.
hunter29
Report this Post08-26-2024 07:19 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
EGR with GM cover.
Interesting, I've never seen that..
BingB
Report this Post08-26-2024 08:20 PM Click Here to See the Profile for BingBSend a Private Message to BingBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I installed this 35" Thermostatic Rain Shower/Massage System in my garage to wash my engine bay
A good cleaning from that baby adds about 5 HP.
hyperv6
Total ratings: 94
Report this Post08-26-2024 08:45 PM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 88 I think had them as did sone other GM engines. They used to be all over eBay but I have not seen one for a whole. But I have not really been looking either.
Nice way to clean up the look. Just snaps on.
Total ratings: 206
Report this Post08-26-2024 09:12 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
We have never seen the EGR cover on the OEM 88's, but have seen several on the 3.1's in the FWD cars.
Unfortunately, I don't know the years of the multiple Cavaliers in the junkyards that I have liberated them from.
My son put one on his Formula and I have one on my 4.9 Formula.
It's a nice touch in the Fiero engine bay, I don't know why GM didn't include it to trim out a nice looking engine.
Maybe they came along after the Fiero was out of production?
jonrev
Report this Post08-26-2024 09:39 PM Click Here to See the Profile for jonrevClick Here to visit jonrev's HomePageSend a Private Message to jonrevEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remember scouring yards for Cutlass Cieras 10-15 years ago looking for those. This old thread has a few engines and models listed, mostly 3800-powered Buicks and Firebirds. I wonder if they could be 3D printed nowadays and withstand the heat.
Fiero Store also makes a metal cover but I've not seen one in person.
Total ratings: 200
Report this Post08-27-2024 08:35 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Man... that is amazing looking... it's like a work of art.
hyperv6
Total ratings: 94
Report this Post08-28-2024 07:49 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not hard to do. Just once a year cleaning.
No I don’t drive it daily now but in the 80’s I did.
I wish I had taken photos of the salt and snow On the car.
Some things like fine steel wool cleans heat shields. Aluminum cleaner the transaxle and Greased Lighting for the rest.
Being a Fiero and mid engined the engine becomes a focal point. Also with Pontiac dressing it up I like to have it clean.
Also when I put new wires on I cut them to the correct size. Many leave them too long.
[This message has been edited by hyperv6 (edited 08-28-2024).]
