  Wish me luck! (Page 1)
Wish me luck! by Cliff Pennock
Started on: 09-03-2024 03:05 AM
Replies: 82 (1584 views)
Last post by: Frenchrafe on 10-16-2024 04:06 AM
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-03-2024 03:05 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I took the plunge and I'm bringing my Fiero to a garage today. Inspection is coming up soon and I know there are a few things that needs to be done before it makes even a slight chance of passing inspection. And I simply don't have the time or space to do it myseld. I trust the person who is going to work on my car - I've actually bought the car from the place where he used to work as a mechanic and he is one of the most knowledgeable persons (when it comes to Fieros) that I know.
That said, I know a lot needs to be done and first thing he is going to look at is if it is even worth it. If not, then I will need to part ways with the Fiero I've owned for almost 30 years.
So keeping my fingers crossed!
Report this Post09-03-2024 03:45 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
hyperv6
Total ratings: 94
Report this Post09-03-2024 06:27 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck and I hope many here appreciate how easy they have it here.
cliffw
Total ratings: 294
Report this Post09-03-2024 08:51 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
I myself am going to allow others to work on my vehicles.
We have all been in that sticky wicket. "Worth it", is up to the owner, not the mechanic. When I wonder, I always think of where would I be able to get another one.
Total ratings: 206
Report this Post09-03-2024 09:22 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck Cliff!
How much would it cost to replace, and what unknown problems would a different car present?
lou_dias
Total ratings: 67
Report this Post09-03-2024 09:36 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi Cliff - why will you need to part ways with it?
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-03-2024 09:48 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Money. If it's going to cost a few thousand dollars - that's not something I can afford.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-03-2024 09:51 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
That's a bit of the problem... If I would sell this Fiero and get another one, I would have no idea what repairs might be just around the corner. I might actually be worse off than my current Fiero. A fastback Fiero is at least $6,000 and again, it could very well be just another money pit.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-03-2024 10:06 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
Ok, so they did a first check to see what needed to be done for the inspection and it was mostly the things I expected except for one thing. It turns out one of the structural beams is badly rusted and needs to be welded. Since they don't do big welding jobs themselves, they need to consult with an external welder first.
I trust these guys 100% so if they say this needs to be done I know for a fact this needs to be done. Not sure what big of a job this is so I have no idea yet how much it's going to cost.
Total ratings: 200
Report this Post09-03-2024 01:42 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you know what beams it is they're talking about? Is it the cradle, or the upper frame rails?
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-03-2024 04:25 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure exactly which they were talking about but they said they could see my carpet through it. But come to think of it, I'm not sure which carpet either. From the interior or the rear compartment?
Total ratings: 200
Report this Post09-03-2024 04:59 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
They might be referring to the rear frame rails. Really, if the sheet metal around the trunk is rusted out, that doesn't really mean anything. Even light rust through on the upper frame rails isn't the end of the world, It's only when it starts to rot around the spring perch (significantly) that it creates a safety issue because your suspension / handling can be affected. The good news is... it doesn't have to be done "well," just done right... and with the rear shell coming off, as long as they can repair it, it doesn't really matter what it looks like.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-04-2024 01:57 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I don't think they were talking about the frame rails. It was under the car. I can now vaguely remember seeing it being rusted a few years back when I was doing some work on my rear brakes. I think me living near the sea now (and my car being parked outside 24/7) has sped up the rusting.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-04-2024 07:21 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
I got a "quote" from the garage. Not yet in moneys, but in hours. They think it will take them 40 hours in total. That's not only for repairing the things to get the car through inspection, but pretty much all repairs I asked them a quote for, which are:
- Replace exhaust headers and gasket
- Replace motor mounts (3x) and dog bone
- Repair small holes in exhaust
- Replace oil + filter
- Replace spark plugs
- Replace fuel filter
- Replace transmission oil filter + gasket
- Replace belt
- Replace oil sensor
- Replace brake pads
- Completely replace all transmission lines for copper tubes
- Weld the cradle
And they also said something about replacing the oil seals (while the engine is out of the car)
I've got all parts already but for the last thing, they said I needed an oil pan gasket and front & rear crankshaft seals. I will order those at RockAuto, but can anyone help me choose the proper one?
Oil Pan Gaskets
Front & Rear Crankshaft Seals
Total ratings: 200
Report this Post09-04-2024 09:20 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've got all parts already but for the last thing, they said I needed an oil pan gasket and front & rear crankshaft seals. I will order those at RockAuto, but can anyone help me choosing the proper one?
For the oil pan gasket, DEFINITELY go with the molded rubber (the two last ones), and for the rear main seal and crankshaft gasket... go with the one made of viton (in my opinion). But please wait until you hear opinions from others.
Also... we all owe you... so I encourage everyone to send you beer money to help out:
Everyone Click This - Buy Me a Beer!
[This message has been edited by 82-T/A [At Work] (edited 09-04-2024).]
Total ratings: 460
Report this Post09-04-2024 09:41 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
If Cliff has an 86, the rubber gaskets likely won't work. 87 and 88 - and later V6s - used a front cover that is like a SBC V8.
The 86 and earlier had a sloped sealing surface on the bottom of the front/timing cover. Used the cork gasket. I can't say that I have ever seen a suitable rubber replacement.
[This message has been edited by Raydar (edited 09-04-2024).]
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-04-2024 09:47 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 86.5 to be exact.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-05-2024 04:51 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
hyperv6
Total ratings: 94
Report this Post09-05-2024 06:16 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not good but not the worst I have seen. I have seen over the axles the entire frame gone on clean looking cars.m
A good welder should be able to fix this.
It would be nice to cost the bottoms to seal it.
TheDigitalAlchemist
Total ratings: 94
Report this Post09-05-2024 01:54 PM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ugh, Please make sure you print out a few copies of the proper jack points and tell everyone you don't want them to crimp the coolant tubes - that coolant tube looks "ok", but still...
cyrus88
Report this Post09-05-2024 02:26 PM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! Looks like they're jacking on the coolant pipes!
[This message has been edited by cyrus88 (edited 09-05-2024).]
cvxjet
Report this Post09-05-2024 03:30 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Always stay away from the coolant pipes!!!!
Also, remember there is NO STRUCTURE in the last 2 feet of rocker on Fieros!!!
[This message has been edited by cvxjet (edited 09-05-2024).]
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-05-2024 05:19 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
The guy working on my Fiero has worked on literally hundreds of Fieros in his life. So yeah, I was wondering about that jack point as well but if he jacks it like this, I know he has a very good reason for it.
Seriously, this guy would probably run circles around theogre when it comes to Fiero knowledge. I have tried to get him on the forum but he simply lost interest in Fieros some time ago. He's now restoring old (as in 60s) Firebirds.
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-05-2024 05:20 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff Pennock
Member since Jan 99
I suspect someone else jacked up the car and made those pictures.
Total ratings: 200
Report this Post09-05-2024 08:26 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
That's awesome that you found another Fiero mechanic in the Netherlands to work on your car. That rust is a little bit brutal, never seen those rusted before, but the rest looks pretty good... AND, it's easily accessible for them to fix. So that's good!!!
Report this Post09-05-2024 11:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I added something to your image... to show where I believe the Fiero jack point is in this picture. There must be some "structure" at that point to support the car. When I'm removing wheels from a Fiero, I use a hydraulic floor jack where the vehicle's jack would normally go. I modified a hockey puck (Canadian, eh!) to use on the head of the floor jack to better fit and support a Fiero in that area. Would I get under a Fiero when supported in only that manner? Not a chance!
cyrus88
Report this Post09-06-2024 12:33 AM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Seriously, this guy would probably run circles around theogre when it comes to Fiero knowledge. .
Sorry Cliff, but that picture contradicts this statement. No amount of testimonials can undo that pic
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-06-2024 01:13 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, like I said, I don't think he was the one that actually jacked up the car and took those pictures.
RWDPLZ
Total ratings: 305
Report this Post09-06-2024 02:02 AM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
You call that rust?! 40 hours including welding and pulling the engine, with the list above, all sounds like maybe a couple grand, but not bad at all.
CoolBlue87GT
Total ratings: 151
Report this Post09-06-2024 09:25 AM Click Here to See the Profile for CoolBlue87GTSend a Private Message to CoolBlue87GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hang your Christmas stocking out early this year, maybe the members here will want to contribute a bit towards helping you out for the repairs.
Good luck, sounds like the guy knows what's needed.
[This message has been edited by CoolBlue87GT (edited 09-06-2024).]
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-10-2024 10:48 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I finally got a quote...
€3,500 (US$ 3,900) 😥
That's actually quite a bit more than I had hoped... Do you think that's reasonable for all this work?
Vintage-Nut
Report this Post09-10-2024 11:34 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes, "it is going to hurt" when paying a shop to work on your Fiero and obviously, the main portion of this cost is labor....
Do you trust the quality of the work?
To me, I 'hate' paying a lot of money to find poor workmanship!
IF you have a firm belief of the reliability on 'this' mechanic; trust the estimate.
[This message has been edited by Vintage-Nut (edited 09-10-2024).]
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-10-2024 12:05 PM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually, this is only labor since I already have every single part needed for all repairs...
And yes, I trust this mechanic. Like I said he has worked on countless Fiero's before and if there's one person in the Netherlands who knows everything about Fieros, it's him.
Report this Post09-10-2024 03:01 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cliff, my concern would be how much "rot" would still be left on your GT. If that labour includes actually remedying the cradle/frame rust problem, then fine... but if after spending all that money, you're still left with a rust-bucket, then it might be time to move on from that particular Fiero.
Total ratings: 329
Report this Post09-10-2024 05:13 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
IMO, $3,900 is a fairly high estimate but you probably will not be able to purchase another Fiero for that. A good metal man should be able to fabricate contoured patches, and mig weld in new metal to make the frame as good as new. They may have to remove the carpet and that is a lot of work
css9450
Total ratings: 87
Report this Post09-10-2024 05:23 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
+2
Here in the Salt Belt that is considered "almost rust-free"!
TheDigitalAlchemist
Total ratings: 94
Report this Post09-11-2024 10:10 AM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for mentioning this, that's the same as saying "quarter panels", right?
TheDigitalAlchemist
Total ratings: 94
Report this Post09-11-2024 10:27 AM Click Here to See the Profile for TheDigitalAlchemistClick Here to visit TheDigitalAlchemist's HomePageSend a Private Message to TheDigitalAlchemistEdit/Delete MessageReply w/QuoteDirect Link to This Post
TheDigitalAlchemist
Member since Jan 2012
40 hours of work alone would be $6,000 around here...
Thought experiment: They repair the Fiero 4K and its "good"(reliable). Now, pretend its not your car. You walk up to them and you agree to lease a Fiero for 4K. You plop down 4 K and you are able to own the car 3-4 years. Lets say 4 years. Its 1,000 a year to own your favorite car. Under 100 a month for your car payment. Then, after 4 years, you part ways with it. Is that worth it? 100 bucks a month to continue the relationship. The car COULD last longer, but even if it goes for another few years, and you enjoy it, that's worth it to me.
To get a different Fiero is a crap shoot...
One problem is that at this point, almost every Fiero found in the wild has its share of hidden torments...even a "pristine" one for 15-20k has all old rubber and sensors and whatnot... the current one I got seemed ok, but wow, there were a lot of issues.
If the engine is 'good', I'd say its worth the repair. You recently had other stuiff replaced, rediator or coolant system or heater or somethin'(sorry, brain stinks now) but that's other stuff you shouldn't have to worry about for a few years...
I'd say, stick with that Fiero - It's pretty (just like YOU!)
xoxo
cvxjet
Report this Post09-11-2024 04:38 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here are some pics to show you where I mean;
pmbrunelle
Total ratings: 63
Report this Post09-11-2024 06:48 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
It seems like a lot of money, but your Fiero needs a lot of work, so overall it seems ok to me.
If you want a better understanding of the costs, perhaps you can ask for the cost/time related to each task.
[This message has been edited by pmbrunelle (edited 09-11-2024).]
