  RIP to another one
RIP to another one by SunsetChaser
Started on: 09-12-2024 09:26 PM
Replies: 13 (569 views)
Last post by: qwikgta on 10-19-2024 07:48 PM
SunsetChaser
Report this Post09-12-2024 09:26 PM Click Here to See the Profile for SunsetChaserSend a Private Message to SunsetChaserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Saw this on the news during coverage of some pretty devastating wildfires this week.
shemdogg
Report this Post09-14-2024 11:32 AM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can save it!!!!!!!!! lol
shem
cvxjet
Report this Post09-14-2024 02:52 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dude- that is your ADDICTION talking!
(Deep breaths, deep breaths...calm, calm)
Total ratings: 200
Report this Post09-16-2024 09:22 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
So, serious question... when we see burned out husks like this. Why CAN'T we save the frame? I see people mentioning that the frame becomes fatigued, etc. But is that actually true?
When I send my control arms and steering knuckles to the machine shop... they basically put it in a kiln that strips off all the paint (burns it off), and even totally burns off the rust. It "floats" the metal a bit to the point where it restores the surface to perfectly clean metal. Is that not more or less what's happening here?
I realize of course that everything on the car is totally gone... I just wonder if the frame itself couldn't be re-used... like... if someone actually needed one.
At least no one is changing the heading to say, "Pontiac Fiero causes airport fire that burns out of control!"
Report this Post09-16-2024 10:06 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
When certain steels get red hot in a fire for a prolonged time it changes its properties. I am not a metallurgist but I believe the steel is both weakened and its dimensions change.
SC_Robert1999
Report this Post10-03-2024 03:43 AM Click Here to See the Profile for SC_Robert1999Send a Private Message to SC_Robert1999Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dam thats sad!!
hyperv6
Total ratings: 93
Report this Post10-03-2024 08:56 AM Click Here to See the Profile for hyperv6Send a Private Message to hyperv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes fires tempers, warps and damages steel.
The cost to restore would be much more than the value too.
I love Fiero’s but you need to temper the attachment. Some you need to let them go.
They scrap Ferraris and part out Dusenberg too.
cartercarbaficionado
Report this Post10-04-2024 03:23 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes and no. you would need to put the whole car in an industrial powdercoating oven to temper after heating everything with a torch. now the fiero metal is pretty soft already so honestly if you straightened it and bolted in a few braces or a cage it would be totally fine.
now it's a completely different story if the carpet or body was only slightly melted.
edfiero
Report this Post10-11-2024 12:31 PM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Come on guys, That will probably Buff right out.
Kitskaboodle
Report this Post10-11-2024 04:11 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Technically, you could also say “RIP to another one” to these as well because they’re both going to end up at the same place. (the crusher)
Kit
NewDustin
Report this Post10-11-2024 04:30 PM Click Here to See the Profile for NewDustinSend a Private Message to NewDustinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kit
GET THE TAIL LIGHTS
Report this Post10-11-2024 08:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by NewDustin:
GET THE TAIL LIGHTS
...AND THE BRAKE CALIPERS AND THE FRONT HUBS
[EDIT] NEVER MIND, I THOUGHT IT WAS AN '88.
That rear decklid is looking rather grim.
Looks like whomever butchered the decklid while prying it open also damaged the left taillight. Idiots abound.
[This message has been edited by Patrick (edited 10-11-2024).]
Kitskaboodle
Report this Post10-11-2024 09:08 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
That pic is at least 3+ years old. 😊
The tail lights look ok in the pic but they were pretty much toast.
qwikgta
Total ratings: 84
Report this Post10-19-2024 07:48 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I get the heat issue and its effect on the steel, but I think putting an Upper/Lower A arm into a furnace to remove the rust/oil/paint is a lot different then the very thin sheet metal that makes up the frame. I just cut the top off a T-Top car in my local Pick n Pull and I can tell you the frame is made up of very thin sheet metal that is boxed for strength. The sawzall cut right threw it like it was paper. I don't think I could cut threw an Upper/Lower A arm as easy. I would think that the heat would really mess up the thin metal of the frame. In this pic you can see that the strength comes from the boxing and over lapping of the sheet metal. Its thin but when all welded together its strong.
Rob
[This message has been edited by qwikgta (edited 10-19-2024).]
