  Man... why did I buy this?
Man... why did I buy this? by 82-T/A [At Work]
Started on: 12-03-2024 07:35 PM
Replies: 16 (309 views)
Last post by: Corsair231 on 12-06-2024 11:15 AM
Total ratings: 200
Report this Post12-03-2024 07:35 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
I couldn't help myself. I know how rare these are, and I needed to get it...
I'm thinking about that Sunfire Turbo motor... :/
rbell2915
Report this Post12-03-2024 09:30 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
At least it's saved from the trash!
I have two, one day soon I'll do a 3800SC swap and get one installed.
Can always sell, probably will make more than you paid for it.
Total ratings: 329
Report this Post12-03-2024 11:43 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
They fit the Fiero gauge cluster look cool on a boosted engine. If used it's difficult to read the exact boost going into the engine as it provides a 180° scale.. I believe that guage is calibrated to the map sensor.
css9450
Total ratings: 87
Report this Post12-04-2024 07:50 AM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
+2
I think I said it in the other thread: If I had one of those gauges looking for a home I would consider turbocharging my car just so I could use the gauge!
Total ratings: 200
Report this Post12-04-2024 08:40 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by css9450:
+2
Ugh, I know... that's the problem right now.
I'm trying (not) to now go buy a the Sunbird Turbo engine...
cliffw
Total ratings: 294
Report this Post12-04-2024 10:11 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I saw that the Sunbird thread I googled Sunbird replacement guages. They exist, new.
Total ratings: 200
Report this Post12-04-2024 10:39 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well, this wouldn't be the first dumb thing I've done before in my life, haha...
But I'm going to have to call your bluff... are you sure you weren't looking at reproduction 70s Sunbird gauges? I just looked and didn't see the Turbo gauges for the 80s Sunbird...
mmeyer86gt/gtp
Total ratings: 73
Report this Post12-04-2024 01:46 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
this is not a sunbird gauge. It is a typhoon / syclone gauge. FYI no need for the potentiometer.
cliffw
Total ratings: 294
Report this Post12-04-2024 03:46 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
They were not OEM, but look the same.
I did look up cyclone gauges.
cliffw
Total ratings: 294
Report this Post12-04-2024 03:53 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
cliffw
Member since Jun 2003
Hmm, Would that turbo gauge look like it "worked", hooked up to a vaccum port ?
css9450
Total ratings: 87
Report this Post12-04-2024 04:44 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Don't they use the same gauge, kind of? Sunbird has a higher redline if I remember right.
[This message has been edited by css9450 (edited 12-04-2024).]
rbell2915
Report this Post12-04-2024 07:29 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, can hook up to any engine as a vacuum gauge. Like one of those old MPG efficiency gauges hypermilers use.
Total ratings: 329
Report this Post12-05-2024 10:01 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Typhoon/Syclone, and Sunbird turbo engines all used 2 bar MAP sensors. If these gauges read off of the MAP signal as I suspect, be aware normally aspirated engines use a 1 BAP MAP that uses a different output scale. Your readings will be off by a factor of two.
Corsair231
Report this Post12-06-2024 03:24 AM Click Here to See the Profile for Corsair231Send a Private Message to Corsair231Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, Sy/Ty gauge. These are electronic and not mechanical so you can't hook them up direct. It's as Dennis said, they run off a two-bar MAP sensor. In my Sy, I have a three-bar sensor and matching chip so my computer gets the correct reading, but my dash only shows half of actual boost/vac.
Total ratings: 200
Report this Post12-06-2024 07:39 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero gauges are electronic as well, not mechanical... what did you mean by not mechanical?
Thanks!
Total ratings: 329
Report this Post12-06-2024 10:08 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
Mechanical gauges use a direct engine connection. Electronic is connection to a sensor. The Ty/Sy, Turbo Sunbird, GN and 3800SC boost gauges are all electronic meaning that they receive inputs from sensor signals.Now with electronic connections you must have a sensor capable of sending the right signal to the gauge. You just can't use any sensor but one particular to that gauge for the right reading.
Corsair231
Report this Post12-06-2024 11:15 AM Click Here to See the Profile for Corsair231Send a Private Message to Corsair231Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, what Dennis said. Someone earlier said they could be hooked up to any engine to read vacuum but that's not possible if the engine doesn't have a pressure sensor whereas a mechanical one hooks directly to a vacuum source on the engine with a tube that runs to the back of the gauge itself and uses a diaphragm or spring to move the needle.
As far as GM's boosted 80's and early 90's stuff, I think the '89 Turbo Trans Am was the only one that used a three-bar MAP from the factory.
