After doing more than a half a dozen engine swaps I settled on the 3800SC/4T65eHD for my personal Fiero but that was 20 years ago, There are many things to like about this engine in the Fiero but there are a few things that I dislike and I'd like to mention them.
The dipstick is on the front of the engine near the firewall. You've got to stand in the trunk to reach that dipstick, pull it out wipe it, put it back in to get a reading. Then back in again. Its something that I can live with but just a PITA.
Changing the oil filter is not easy, It sits above the right axle and there is not much room to remove it. I have to get it out with a U joint socket bar and an an expandable filter clamp working from below. Then you need to wiggle and lift out the filter an you get a nice supply of oil on the garage floor. You also must use the GM short filter. A full size one won't fit
Putting the filter back you really cant hand tighten it firmly so again you need help from the wrench. Thank god we have the two post Rotary lift.
The exhaust runs with a three inch U pipe into a SpinTech muffler and then goes to the dual trumpets on both sides. We did it this way to save the trunk . There's not much room for a quieter full-size exhaust system there so we live what we have. The thirty-eight hundred engine doesn't have the best exhaust sound but it does provide excellent performance in gas mileage.
The other concern is that my series III engine is 21 years old and while it's low mileage and runs great ,it's a bit dated for today's automotive world
IMO, no swap is perfect so iIll give the 3800SC engine a 9 out of 10.
How do you see your engine swap?
