  Welding up a cracked subframe/cradle
Welding up a cracked subframe/cradle by Frenchrafe
Started on: 04-24-2025 06:53 AM
Replies: 3 (97 views)
Last post by: Dennis LaGrua on 04-25-2025 09:51 PM
Frenchrafe
Report this Post04-24-2025 06:53 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had some footage which wasn't used elsewhere in my videos, so here's a quick 4 minute vid:
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero
https://youtu.be/hUzOAeyWLfM
pmbrunelle
Total ratings: 63
Report this Post04-24-2025 07:41 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The slot there is for a hook which holds the factory parking brake cable. You don't seem to be using that hook.
Maybe by welding the slot closed, there will be less stress concentration, but probably you should weld a doubler plate over that area for more durability.
Frenchrafe
Report this Post04-24-2025 10:58 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, thanks I couldn't remember what that slot was used for.
The crack appeared to follow the edge of a spot weld?
The extra force applied by the backing plate of the gearbox mount seemed to have stressed that area.
As I said above, this was old footage (from over a year ago).
The car has since passed inspection with no remarks, and the crack hasn't come back.
We'll see if it stays welded up after some drag racing this summer!
Total ratings: 328
Report this Post04-25-2025 09:51 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Great job on the repair but I would consider welding a steel plate over the cracked area for extra reinforcement and strength.
