  Other Cars
  Regular spray paint on brake calipers?
Regular spray paint on brake calipers? by xquaid
Started on: 06-18-2013 04:47 PM
Replies: 8 (8117 views)
Last post by: FieroGT42 on 07-16-2013 09:31 PM
xquaid
Report this Post06-18-2013 04:47 PM Click Here to See the Profile for xquaidClick Here to visit xquaid's HomePageSend a Private Message to xquaidEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the difference between "high temperature" paint and regular paint?
Is there a difference?
Thinking about painting my calipers on my 1999 Ford Escort. Not wanting to spend $7 on black high temp paint when I have 3 cans of flat black $0.99 laying around!
Fitness Entrepreneur
Founder - www.fitnesspatterns.com +
www.gymgym.us
thesameguy
Report this Post06-18-2013 05:51 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Regular paint will burn/flake/disappear in short order.
V8 Vega
Report this Post06-19-2013 12:47 AM Click Here to See the Profile for V8 VegaSend a Private Message to V8 VegaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used regular paint on my del Sol and its been awhile now and no sign of any trouble with the paint.
BlackEmrald
Report this Post06-20-2013 03:31 AM Click Here to See the Profile for BlackEmraldSend a Private Message to BlackEmraldEdit/Delete MessageReply w/QuoteDirect Link to This Post
x2
I sprayed regular yellow on my Fiero brakes and had no issues.
Kitskaboodle
Report this Post06-23-2013 11:45 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might get away with it. The reason is the rotors are what absorb the heat & friction. (from the pads)
Worst case scenario it will burn off or start looking flat blackish in color. In that case you will simply need to reapply every now and then.
Kit
skuzzbomer
Total ratings: 92
Report this Post06-24-2013 12:14 AM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would assume it depends on the car. I highly doubt you're going to beat on your Escort with enough vigor to burn the paint off of the stock calipers but I know I'd put some quality high temp paint on my RX8's hardware.
Give it a try. All else fails, you learn you'll need to buy the good stuff anyway.
xquaid
Report this Post06-24-2013 12:57 AM Click Here to See the Profile for xquaidClick Here to visit xquaid's HomePageSend a Private Message to xquaidEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL.... I painted them with the $0.99 paint a few minutes after posting this thread. I couldn't wait! Looks like I will wait a month and see if half a can ($0.50 worth) worked!
rogergarrison
Total ratings: 551
Report this Post07-04-2013 07:37 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ive used plain old spray cans like Krylon and Rustoleum for years on brakes (rotor centers and calipers), and engines. Ive never had a problem with them lasting at least a few years. Ive painted a lot of guys engines with regular auto paint too, so that it matched the body color. Ive never seen the need for 'hi heat paint'. Ive used the best high heat paint you can find (for jet engine exhaust plates) on exhaust manifolds and it never lasts more than a few weeks. The only area that discolors for me on an engine is at the center intake ports of the intake manifold, and the bottoms of the heads below the exhaust ports.
FieroGT42
Total ratings: 67
Report this Post07-16-2013 09:31 PM Click Here to See the Profile for FieroGT42Send a Private Message to FieroGT42Edit/Delete MessageReply w/QuoteDirect Link to This Post
It'll look okay for a little while. I used high temp engine paint with ceramic and it lasted 10 years and counting and it was about the same price. Real caliper paint should last even longer. Proper prep is key, as with any painting.
