Thats actually what I thought initially. I got that part and the spacer from the dealer thinking it had to be one or the other. Its not either. The lock nut is definitely there, I dont have the special tool to remove it so we had to use a hammer and punch to knock it out. This was done the same as the other side and locked in place by tapping an edge of the axle hub that sticks through into one of the hole (ie - imagine a tab that you tap flat to lock the nut)
If at the time I had known it was this cheap I would have bought
this I still might
Here is a good picture showing both components
Note: I believe this is a picture of the rear but this portion of the setup, the nut and the brass thingy, is the same.
This is a picture of the front showing the lock nut removed (you can alse see where it was most likely tabbed in to lock it) the brash thing is not shown.
