Update System
  Other Cars
  Ford F150 or the Silverado 1500?
by DanFiero
Started on: 11-20-2019 12:26 PM
Replies: 14 (586 views)
Last post by: hillcrest on 01-27-2022 08:35 AM
DanFiero
Total ratings: 96
Report this Post Click Here to See the Profile for DanFieroClick Here to Email DanFieroSend a Private Message to DanFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
So my daughter totaled our truck (Ranger) about a month ago and we are needing to replace it. I'd like to move up to a bigger (used)truck that can handle more things, especially towing. Trying to decide between the F-150 or the Silverado 1500.
F-150 - Prefer the V8, don't know much about the turbo charged Ecoboost v6 (not a fan of Turbos).
Silverado 1500- Don't know much about this truck at all.
Any tips or opinions would be helpful
Thanks,
Dan
Phirewire
Report this Post Click Here to See the Profile for PhirewireClick Here to Email PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks,
Dan
Do you have a year range you are looking at?
I can tell you newer and older wise but they years change the issues and consideration, also pros and cons to each.
As far as the new models go, I do test driving and condition reporting the new Ecoboost trucks i've found underwhelming. I don't know in regards to towing but overall performance wasn't anything to write home. Now Pro and con your fuel economy and how often you will tow and this could change. Don't forget to consider long term cost on turbos and maintenance though. In my opinion fords interiors are significantly better both in looks and how they hold up. Silverados really haven't changed much, pretty much point and shoot alot more simplicity where the ford have multiple options engine wise and have transitioned alot over the years. AVOID the old fords.
TM_Fiero
Report this Post Click Here to See the Profile for TM_FieroSend a Private Message to TM_FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depending on the years the F150 has has issues with engines, the Triton V8 had issues with spark plugs breaking off in the heads, the Ecoboost engines had issues with the timing chains stretching and needing replacement, which is very expensive. The Silverados had issues with the brakes throughout the years whether it was the brake lines rusting out or the ABS systems acting up and you put your foot to the floor and don't slow down.
The Rams/Dodges 5.7 Hemi breaks the exhaust manifold bolts every so often that results in an annoying exhaust tick. This happened on the 2013 Ram I had, which only had 35,000 miles on it. Traded it on a Tacoma that I have now.
If you live in a winter/salt environment you're probably aware they all like to rust out the rockers and bedsides, frame and so on.
Total ratings: 204
Report this Post Click Here to See the Profile for olejoedadClick Here to Email olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
My son has a Silverado - great truck....
DimeMachine
Report this Post Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a 74 ford and a 78 chevy. Chevy was much better.
I had a 98 ford and a 01 chevy. Chevey was much better.
Now I have an 08 chevy.
All were trucks b/t/w.
Still on the fence - look under the hood of each. Which one would you want to work on . It is obvious!!!
Good luck.
Total ratings: 465
Report this Post Click Here to See the Profile for RaydarClick Here to Email RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently traded my 05 Silverado 1500 for a new Ram 1500. The only reason I traded is because I needed 4WD.
The Silverado actually seemed happier about towing our small box trailer than the Ram does. Although this may be because the Silverado had the usual 4 speed 4L60/65E trans, while the Ram has an 8 speed. The Ram just seems to be "busier". Not necessarily a bad thing. Just different. Neither one was overtaxed.
With my lead foot, the Silverado got ~15 MPG in my day-to-day driving. Had the 5.3 (pre-DOD/AFM is preferred, IMHO) and was quite bulletproof. The later DOD/AFM models had issues with oil consumption, and chewing up lifters and (I think) cams.
Ford? Know nothing about them.
[This message has been edited by Raydar (edited 04-20-2022).]
hnthomps
Total ratings: 50
Report this Post Click Here to See the Profile for hnthompsClick Here to Email hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can speak a bit about the Ford products since I have owned several of them (99, 06, 10, 19). I do not have specific experience with the F150 truck, but have owned four Expeditions which are essentially F150s with a rear cover. All were rated to tow up to 9000 pounds without the factory tow package. Three of the Expeditions had the Triton V8 engine and I had no real issues with them other than a few alternators and one instance of battery harness corrosion. I also had to replace the coil packs in the 2006 vehicle due to failures over a period of a few months. All of these first three Expeditions had over 150K miles when showing on the odometer when sold and are still in service today.
Three of them (06, 06, 10) were used for towing 5K+ loads. I did see a MPG drop of 4 to 5 MPG when towing the car trailer and a Fiero/Mera on 1000 mile plus trips. Normal MPG on the road was in the 18-20 range without a towed load. The new Expedition has about 3500 miles on it now, but I have not used it to tow anything so far. It has the twin turbo V6 engine and routinely sees 23-24 MPG on the highway even when running the A/C. I do not believe that you can even purchase an Expedition with the Triton engine anymore so I decided to see how the V6 worked out. The HP rating for both engine types are in the mid 300 range (IIRC) and torque is also somewhat similar.
In my opinion (for what it is worth) the F150/Expedition is a decent vehicle. If I purchase a specific truck to be used for towing, I would also consider one of the diesel powered vehicles and would look closely at the Dodge Ram truck.
Nelson
robymon
Report this Post Click Here to See the Profile for robymonSend a Private Message to robymonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I own a '16 Ford F150 SuperCrew and I'm very happy with it. It rides nice and the build quality is good. The 5.0 has plenty of power and gets decent gas mileage. The interior is quite roomy. The rear passengers can sit comfortably. I installed a CAI and leveling kit from 4wheelonline and the rest is stock.
DanFiero
Total ratings: 96
Forgot about this post last December we ended up finding a 2011 F150 with the 5.0 V8 with about 72k on the clock. So far it's been a great truck, getting a few bugs fixed on Monday.
ls3mach
Total ratings: 222
Report this Post Click Here to See the Profile for ls3machSend a Private Message to ls3machEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not that keen on the Coyote engine. I do love my Ford trucks. The 5.0 is tons better than the 4.6 though. I've had almost all the engines except EcoBoost.
mmeyer86gt/gtp
Total ratings: 73
Report this Post Click Here to See the Profile for mmeyer86gt/gtpClick Here to Email mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 2020 diesel f150 (super rare) and they just stopped making that engine. there is no way i would ever touch a ecoboost engine from ford after finding out the waterpump is behind the front cover and when it starts weeping it weeps into the oil pan. A truck is a truck it all depends on what you plan to do with it. I have been hearing that 2017 newer ford f250 anytime you have to work on it the body needs to be split from the frame. All work starts at 3k and goes up.
User00004902
No longer registered
Report this Post   Send a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
My father has had a couple of the newer ones, a 2016 and 2018 with the V8. The newer one has the engine start/stop 'feature' and it's horrible. Luckily it can be disabled, otherwise you have to turn it off every time you turn the car on.
https://www.autostopelimina...-autostop-eliminator
Otherwise he LOVES those trucks. He only got rid of the first one because it was a lease, and he got rear-ended at one point, causing some damage (totaled the other uninsured crap box that hit him).
kendell
Report this Post Click Here to See the Profile for kendellClick Here to Email kendellSend a Private Message to kendellEdit/Delete MessageReply w/QuoteDirect Link to This Post
My uncle hates that engine start/stop features on his newly acquired 2018 V8. We'll disable that when it returns from the installation of the new set of tires from 4Wheelonline this weekend.
cvxjet
Report this Post Click Here to See the Profile for cvxjetClick Here to Email cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ford recently brought out a PUSH ROD 2 VALVE V8 so they could compete with the GM LT V8s and Dodge Hemis........4V engines are not very good truck engines where you need low-end torque for loads and towing. And 2 valve engines in trucks get better MPG.
My ex-GFs Tundra (2012 vintage) was low on torque and a gas hog.....Best highway mileage was 13 mpg...My friend's LS-V8 GMC was getting close to 20 mpg.....
hillcrest
Report this Post Click Here to See the Profile for hillcrestClick Here to Email hillcrestSend a Private Message to hillcrestEdit/Delete MessageReply w/QuoteDirect Link to This Post
love both of these trucks. I heard that the Silverado, having a Leaf rear suspension is not very comfortable, but I cannot confirm that as I never drove one.
